Old 08-16-2005, 11:27 AM   #51
BlkWRXWag
Member#: 31821
2015 DS WRX
Originally Posted by PossumK
As Mako was saying, we missed you at the autocross. I don't remember if Max sprays his R-S2's; I either forgot to ask or forgot what he said. I bought a sprayer anyway from Home Depot to use at least for practice days and probably for the championship events if it feels like the tires are hot after each run.
I was not spraying at "Night of the Living Dead" simply because it was pretty chilly outside. I certainly did not feel any drop off in tire performance over the three runs. I did bleed pressure between each run. However, I probably would spray them in the summer heat. I was running pressures of 39/37, but if Mr. Hoppe says 36 is the optimal number, I'll give that a shot at the practice next month.
-Max.
BlkWRXWag is offline   Reply With Quote
Old 08-16-2005, 12:14 PM   #52
element533
Member#: 37575
2012 WRX Std 4D
I should not have to change my camber when changing tire brands. I will try more pressure, but I am not very confident.
element533 is offline   Reply With Quote
Old 08-16-2005, 12:21 PM   #53
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Keep on dreaming there champ
You have to optimize a car for a tire.
-Tom
trhoppe is offline   Reply With Quote
Old 08-16-2005, 12:21 PM   #54
BlkWRXWag
Member#: 31821
2015 DS WRX
I'm not sure Tom was saying that - he said that he found 36psi to be the ideal pressure if you have 4 degrees of camber. If you have less camber than that, perhaps a different pressure is better, but I bet it's not far off from 36.
Old 08-16-2005, 12:22 PM   #55
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I would say that with stock camber you will have to go up on the pressure a bit as to not roll over. The tire won't be at the optimium pressures, but you can't help that as you don't have optimum camber. So go as low as possible with good wear.
-Tom
Old 08-16-2005, 12:23 PM   #56
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
I don't think 36psi is going to work with like, -1 camber. That said, they do seem to work well with less pressure than the Azenis 215.
ChrisDP is offline   Reply With Quote
Old 08-16-2005, 12:23 PM   #57
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
No I was saying that. I found that these tires will need a bit more camber then other tires that I have tried. Partly because they stuck more and I got a bit more roll out of the car with these tires. If you have the means to adjust camber, go with some more.
-Tom
Old 08-16-2005, 12:26 PM   #58
BlkWRXWag
Member#: 31821
2015 DS WRX
Good to know - thanks Tom. I've been running 4 degrees of camber with these tires and have certainly been very happy with them.
Old 08-16-2005, 05:15 PM   #59
element533
Member#: 37575
2012 WRX Std 4D
Hey BlkWRXWag,
Do you experience any of the things I was complaining about?
I'm worried that I'm just being overly analytical of the tires.
Old 08-16-2005, 05:20 PM   #60
element533
Member#: 37575
2012 WRX Std 4D
Tom, keep in mind that I'm not getting scuff marks past the shoulder line on the tire. Doesn't this mean roll-over is not what I'm experiencing?
Old 08-16-2005, 05:33 PM   #61
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Yea, you are also running a frikkin 205.55.16. Thats almost a truck tire Get a smaller size, 215/45/16 would eliminate a LOT of the problems you are having.
-Tom
Old 08-16-2005, 06:52 PM   #62
BlkWRXWag
Member#: 31821
2015 DS WRX
Hey BlkWRXWag,
No I'm not but then again, as Tom said, I'm running 235/40/17
Old 08-18-2005, 05:38 PM   #63
AUTOwrXER
Member#: 5817
2005 STi
I'd be interested to know what the hydroplanning resistance of these tires is like once they get down below 50% tread. I guess I'll have to wait and see. I was going to buy these for daily drivers on my SE-R, but I bought the Yoko ES100s since I know those will do 25k miles and still have good hydroplanning resistance at the end of thier life. We get such heavy downpours here in the durty durty that an Azenis or a Kumho MX at 50% tread is a hazard as a daily driver.
AUTOwrXER is offline   Reply With Quote
Old 08-18-2005, 07:19 PM   #64
nate49509
Member#: 22452
2016 WRX
I was kinda thinking the same thing. But figured they couldn't be any worse than the Azenis.
nate49509 is offline   Reply With Quote
Old 08-18-2005, 10:33 PM   #65
AWDrifter21
Member#: 51112
2004 WRX-sold T_T
now 2005 STi ^^
Well I have about close to 15,000 miles....
been on trips all over east coast lately, haha
and I think I have about 60-70% tread left
Ill post up pics later tonight...
last weekend in NJ, we had a crazy rain storm for a couple of hours
and I was cruising pretty normal because it felt safe.... didnt feel hydroplane and even running through deep long puddles I was able to control it. Car never felt unsafe really.... i dont know if there are certain tests I can do to check how good or bad the condition of my tread is for rain, but so far so good... when they start to suck in the rain, ill update again, hahaha
AWDrifter21 is offline   Reply With Quote
Old 08-19-2005, 12:32 AM   #66
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....ya shoulda got the 451's.....
Old 08-19-2005, 07:01 PM   #67
AUTOwrXER
Member#: 5817
2005 STi
Not a big fan. I like the Yokes for a daily driver.
Old 08-20-2005, 12:35 AM   #68
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and you drive an STi....
Old 08-20-2005, 01:17 AM   #69
F1WRXRACING
Member#: 36370
I have the Z212's in 225/45/17, and I really like them compared to my Toyo T1-S rubber.
With an identical 04 WRX following, I was able to take turns considerably faster with no squealing, while he was sliding with his Toyo T1-R's. The Hankooks are very predictable, and their grip in the rain are amazing.
Great overall, no complaints. I have only had them for 1800KM's so far, so I can't comment on treadware. But I will say that they look like they have been on the car for a summer already. I can't see them lasting very long. But with the extra grip they provide, I don't mind it at all.
Chris
F1WRXRACING is offline   Reply With Quote
Old 08-20-2005, 05:44 PM   #70
AUTOwrXER
Member#: 5817
2005 STi
No. I race an STi. It wears 285/30/18 Kumho V710s. I drive a 91 Sentra SE-R.
Old 08-24-2005, 12:07 AM   #71
speednby
Member#: 86316
2003 WRX Wagon
I eat rice...Its good 4 u
Tom,
Would the optimal pressure be different for a higher profile tire, say 225/50-16's on the OEM WRX wheels? The max camber I can get is -1.5 with stock adjustments (for stock class). The wear for this combination looked about right with my pressures at 44-45 psi on a fairly tight course:
Justin,
Justin,
After running these for a couple of weeks do you have any more input about the 225/50-16's on stock wheels? Do the sidewalls feel stiff enough?
speednby is offline   Reply With Quote
Old 08-24-2005, 12:15 AM   #72
Vikingmoose
Member#: 50319
2006 STI
Wrong guy...your question should be addressed to PossumK.
Vikingmoose is offline   Reply With Quote
Old 08-24-2005, 12:45 AM   #73
speednby
Member#: 86316
2003 WRX Wagon
Uhhmmmm....
I thought I was???
Old 08-24-2005, 12:51 AM   #74
Vikingmoose
Member#: 50319
2006 STI
Originally Posted by speednby
Justin,
^My bad...I saw my name so I thought you were asking me.
Old 08-24-2005, 01:13 AM   #75
PossumK
Member#: 53548
2004 WRX PSM (sold)
2007 S2000
Justin,
Yeah, it looks like you're asking Justin (VikingMoose)... my name's Greg.
I guess I notice a bit of a floaty/balloony feel on the street as others have said, mostly when going over rough roads. This doesn't really bother me though. I still have the flappy noise when I go over any bumps in the road... this concerns me a bit, but I haven't seen anything bad come up yet. I'm willing to tolerate the street feel of these tires for their performance on an autocross course.
EDIT: Flappy noise was from the front swaybar clunking.
-Greg
PossumK is offline   Reply With Quote
Initial Impressions: Rota Tarmac II's with Hankook Ventus R-S2 Z212 Paradenu Car Part Reviews 0 05-11-2006 08:58 PM
Hankook Ventus R-S2 Z212 vs. Good Year Eagle F1 GS D3 Pete Holt Tire & Wheel 13 03-12-2006 10:20 AM
HANKOOK VENTUS R-S2 Z212 VS AZenis RT-215 SeattleWRX Tire & Wheel 3 07-13-2005 09:43 AM
should i get Hankook Ventus R-S2 or Falken Azeins sport RT215 Dark Tire & Wheel 4 06-11-2005 12:29 PM
Falken GRB FK451 or Hankook Ventus R-S2? ommmjido Tire & Wheel 10 04-12-2005 09:25 PM
