Old 08-05-2005, 03:42 PM   #1
Catch
Member#: 89883
Default Too much oil
When changing the oil on my wife's 2002 Subaru Outback 4 cyl. I replaced the oil and filter and used only 4 qts instead of the 4.2 the owner's book calls for so that I could top it off to the proper lever. I started it and checked the oil and it was right at the proper place. (the top notch for the 4 cyl). After a short trip of about 7 miles, I checked the oil just to make sure and it was way over the full mark. I actually had to drain about 1/3 of a quart out to get the right reading. What is happening here. Am I missing something. I don't want to blow every seal in the engine, but it looks like they would come close at least in telling you how much oil it holds. Thanks for the help.
Catch is offline   Reply With Quote
Old 08-05-2005, 03:45 PM   #2
BeeGee
Member#: 27724
1970 F100
Black/White
Hot oil expands and will give a higher reading on the dipstick. Your wife's dipstick probably has a mark for full cold and one for full hot, although not all do.
BeeGee is offline   Reply With Quote
Old 08-05-2005, 04:57 PM   #3
hondaeater69
Member#: 60324
the notch above the full mark is where your oil should NOT exceed when it's hot. as long as it's below that notch you're fine.
hondaeater69 is online now   Reply With Quote
Ekk think I added too much oil for my oil change.. sti. NewShockerGuy Service & Maintenance 13 03-17-2005 05:15 PM
Effects of too much oil JenisonWRX Newbies & FAQs 9 01-28-2002 02:22 AM
Too much oil causing sluggishness? Marc Sawaya Normally Aspirated Powertrain 10 07-08-2001 02:36 AM
need answer fast! too much oil, bad? pbnj9786 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-06-2001 09:55 AM
