Old 08-06-2005, 01:01 AM   #1
hotshot172
Member#: 85253
06 Beast Mode
I survived an F5
Default What wires to tap for boost gauge illuminatin
I just installed my autometer sport comp boost gauge, ran the lines to the bypass valve, everything works great and reads fine, but there is one exception
I have not wired the gauge to light up at night, because i do not know what wire to tap into. The gauge has a black and white wire, does anyone know what wires i should attach these too? (what color and where they are located), i took off the steering wheel column cover and looked under there so i have a general idea as to what it looks like.
Any help would be great, thanks.
hotshot172 is offline   Reply With Quote
Old 08-06-2005, 01:24 AM   #2
Jason0488
Member#: 81907
2002 impreza wrx
I just hooked up the same boost gauge today and i spliced into the fog light relay. I believe the colors on the relay are Purple is Positive and Orange is negative.
Also if i were you i would use Vampire clips instead of splicing so you dont wreck the wire just in cause you want to remove it ever.
Jason0488 is offline   Reply With Quote
Old 08-06-2005, 01:25 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...the spare plug on the radio harness....it is 'dimmed' with the gauges....put a #168 bulb in the gauge and it will approximate the gauge illumination....run a couple wires and use spade connectors so ya don't have to cut/tap anything
Old 08-06-2005, 01:27 AM   #4
Jason0488
Member#: 81907
2002 impreza wrx
FYI
I used the white wire on the boost gauge for positive but i dont think it matters. Also the foglight relay is the foglight switch on the bottom left side. Hope i helped. Let me know if you have any more questions
Old 08-06-2005, 07:25 AM   #5
toke513
Member#: 16272
2004 WRX Wagon
I tapped into the fuse for the parking lights. It comes on with the head lights and you dont have to pull apart the dash to wire it. The only thing is that it doesnt dim....If that is important to you.
toke513 is offline   Reply With Quote
Old 08-06-2005, 10:27 AM   #6
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
Which one is a Vampire clip? I think I know but want to be sur eI'm using the right one
scoobtothenoog is offline   Reply With Quote
Old 08-06-2005, 11:02 AM   #7
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Forester
When doing my IC Spray switch I used the existing fog lamp wires and just tapped in to the dash lighting. If you go here:
http://www.scoobymods.com/forums/showthread.php?t=3642
and look about 7 posts down to "wiring up the switch" I have some pics and wiring diagrams. It's for the Forester but the dash lights are on the same pins across the line AFAIK. Here are a couple of pics that are there but you should look at the post to get a better idea. If you can't see the pics on the page you need to register, it's free to do so though.
Don't go by my wire colours as they may not be the same across the years but the pin positions are the same.
Peaty
Peaty is offline   Reply With Quote
Old 08-06-2005, 11:21 AM   #8
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
Well, that answers my question. Those r what I though vampires where =). Thanx for the post
Old 08-06-2005, 01:42 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
....all that is well and good.....but will it make the lights 'dim' with the rest of the gauges or not???? That was important to me so that's what I did.
I spent a long time figuring out the autometer thing.......just my 2
Old 08-06-2005, 02:01 PM   #10
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Yes, the way I did it, it will dim with the stock system since you are hooking directly into the stock dash light system.
What wire to tap for MAF to Snow Controller Irishman Water/Methanol Injection, Nitrous & Intercooler Cooling 2 08-11-2007 10:22 AM
Where to Tap for Boost Gauge Dimmer? USF97J4x4 Electrical & Lighting 10 11-30-2005 11:04 AM
Best place to tap for boost gauge on 05 STI? Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-20-2004 01:06 PM
HELP. I don 't know what wire to tap for my autometer boost gauge tcarter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-21-2002 12:28 AM
