Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 08-06-2005, 01:39 PM   #1
syoung0298
Member#: 84772
2005 GDB STI
Default Diagnosing knock event: 05 sti w/gt35r and Hydra ems
Just wanted to get some opinions from the guys in the forum:
I was doing some tuning the other day and noticed that after a shift at near or at redline, I would occasionally get an afterfire follwed by a logged knock event. I assume that the sensor was just picking up noise from the afterfire, which was not really knock, but just wanted to make sure. Here is the log.
HTML Code:
AFR        RPM       TPS     BOOST   KNOCK v   Knock ret   Ig ADV
12.4	4,050.00	0	0	0.1	0	35
12.7	4,050.00	5.2	0	0.1	0	35
12.9	4,050.00	5.6	0	0	0	35
13	4,050.00	19.2	0	0.1	0	33
13.1	4,100.00	25.2	0	0.1	0	32
13.1	4,100.00	39.6	0	0.1	0	31
14.5	4,050.00	50.4	0	0.2	0	31
14.9	4,200.00	79.6	0	0.1	0	31
15.2	4,200.00	93.2	0	0.1	0	31
14.7	4,300.00	102	0.9	0.1	0	28
14.7	4,400.00	102	1.2	0.1	0	28
14.4	4,450.00	102	1.6	0.1	0	27
14.1	4,550.00	102	2.8	0.3	0	26
13.5	4,650.00	102	3.4	0.3	0	25
12.6	4,750.00	102	4.4	0.2	0	25
12.1	4,850.00	102	5	0.1	0	23
12	4,950.00	102	5.9	0.2	0	22
11.9	5,100.00	102	7.2	0.3	0	22
11.7	5,200.00	102	8.7	0.3	0	22
11.7	5,400.00	102	10	0.2	0	22
11.9	5,550.00	102	12.2	0.3	0	22
11.9	5,700.00	102	13.1	0.3	0	21
11.7	5,850.00	102	14.4	0.3	0	21
11.5	6,100.00	102	14	0.3	0	21
11.1	6,200.00	102	14	0.5	0	21
11.1	6,400.00	102	14.4	0.5	0	23
11	6,550.00	102	13.7	0.5	0	23
11	6,700.00	102	14.4	0.5	0	23
11.2	6,850.00	102	14	0.4	0	23
11.2	7,000.00	102	14	0.5	0	24
11.2	7,450.00	71.6	13.1	0.5	0	16
11.2	7,600.00	0	0.9	1.3	0.9	31
12.9	7,300.00	0	0	1.1	0	17
14.5	7,000.00	1.6	0	0.9	0	13
14.4	6,700.00	28.8	0	0.7	0	18
14.8	5,900.00	78.4	0	0.5	0	27
16.3	5,500.00	102	3.4	0.3	0	28
14.1	5,300.00	102	4.4	0.3	0	25
12.2	5,550.00	102	6.9	0.2	0	24
11.9	5,500.00	102	8.1	0.3	0	23
11.9	5,650.00	102	10	0.1	0	22
11.9	5,700.00	102	12.8	0.5	0	22
12.1	5,850.00	84.4	14.4	0.4	0	21
11.9	5,850.00	39.2	10	0.5	0	24
11.2	5,450.00	0.4	0	0.4	0	31
14.6	3,600.00	4.8	0	0.2	0	34
14.4	3,600.00	5.6	0	0.1	0	34
14.1	3,550.00	11.6	0	0.1	0	36
14	3,600.00	16.8	0	0.1	0	35
13.7	3,600.00	22.8	0	0.1	0	34
14.6	3,550.00	27.2	0	0	0	35
14.9	3,600.00	28	0	0.1	0	33
15.3	3,600.00	27.6	0	0.1	0	33
15.2	3,600.00	27.6	0	0.1	0	33
14.8	3,600.00	26	0	0.1	0	33
14.2	3,650.00	24.4	0	0.1	0	33
13.6	3,650.00	24	0	0.2	0	33
13.4	3,650.00	24	0	0	0	33
13.4	3,650.00	24.4	0	0.1	0	33
13.5	3,650.00	24	0	0	0	33
13.5	3,650.00	24.4	0	0.1	0	32
13.4	3,700.00	24	0	0.1	0	32
13	3,700.00	10.8	0	0.1	0	34
12.7	3,550.00	7.2	0	0.1	0	36
12.4	3,500.00	46	0	0.1	0	34
12.1	3,950.00	43.6	0	0.1	0	30
14.1	4,300.00	6.4	0	0.1	0	30
13	4,100.00	9.6	0	0.1	0	32
12.4	4,000.00	26.4	0	0	0	31
12.9	4,250.00	59.2	0	0.1	0	30
13.9	5,050.00	102	0.3	0.3	0	29
12.5	4,900.00	102	1.2	0.2	0	28
11.7	4,900.00	102	2.2	0.1	0	26
12	4,950.00	102	2.8	0.2	0	24
11.4	5,000.00	102	4.1	0.2	0	24
11.2	5,050.00	102	5.6	0.3	0	23
11.2	5,150.00	102	7.2	0.2	0	22
11.6	5,200.00	102	8.1	0.2	0	21
11.9	5,300.00	102	9.7	0.2	0	20
12.2	5,350.00	102	11.5	0.2	0	20
12.2	5,450.00	102	13.7	0.6	0	19
12	5,550.00	102	14	0.6	0	20
11.7	5,650.00	102	14.4	0.5	0	20
11.5	5,750.00	102	14.4	0.5	0	20
11.5	5,850.00	102	14	0.4	0	20
11.5	5,950.00	102	14	0.5	0	20
11.5	6,050.00	102	14.4	0.6	0	20
11.5	6,100.00	102	14.4	0.4	0	20
11.5	6,250.00	102	14.4	0.6	0	21
11.4	6,300.00	102	13.4	0.6	0	21
11.4	6,400.00	102	14.4	0.4	0	22
11.2	6,500.00	102	14.4	0.7	0	22
11.4	6,600.00	102	13.7	0.5	0	22
11.5	6,700.00	102	14.4	0.5	0	22
11.5	6,750.00	102	14.4	0.4	0	22
11.5	6,800.00	102	13.7	0.6	0	22
11.5	6,950.00	102	14.4	0.4	0	24
11.4	7,000.00	102	14.7	0.5	0	23
11.4	7,650.00	37.6	11.5	1.6	3.5	22
12.9	7,450.00	2.4	0	1.4	6	25
15.3	7,200.00	0	0	1.2	4.4	22
16.9	6,900.00	28.4	0	1	3	28
17.2	6,000.00	73.6	0.6	0.8	1.6	28
17	5,400.00	102	4.1	0.6	0.6	25
14.7	5,350.00	102	5.9	0.4	0	22
12.6	5,500.00	102	7.2	0.2	0	22
12	5,500.00	102	10	0.3	0	20
12.1	5,550.00	102	12.8	0.5	0	20
12.1	5,600.00	88.4	13.1	0.3	0	20
12	5,700.00	80.8	14.4	0.5	0	20
11.9	5,700.00	62.4	13.4	0.3	0	21
11.6	5,750.00	31.6	8.7	0.4	0	23
11.1	5,450.00	2.4	0	0.4	0	30
11	5,750.00	0	0	0.2	0	29
14.7	5,200.00	102	0	0.2	0	30
13.5	5,250.00	102	0	0.3	0	30
12.9	5,300.00	102	1.9	0.4	0	29
12.4	5,300.00	102	2.5	0.2	0	25
11.9	5,300.00	102	4.4	0.2	0	24
11.5	5,350.00	102	5.6	0.2	0	23
11.5	5,400.00	102	7.2	0.2	0	22
11.6	5,450.00	102	8.1	0.2	0	21
12.5	5,550.00	102	10.3	0.3	0	20
12.2	5,500.00	102	12.2	0.3	0	20
12.2	5,600.00	102	15	0.2	0	20
12	5,650.00	102	14.7	0.4	0	20
11.6	5,700.00	102	14	0.5	0	20
11.5	5,750.00	102	13.4	0.4	0	20
11.5	5,800.00	102	13.4	0.2	0	20
11.5	5,900.00	102	14.4	0.4	0	20
11.5	5,950.00	101.2	14.4	0.2	0	20
11.5	5,950.00	14.4	8.7	0.5	0	23
11	5,600.00	0	0	0.4	0	30
12.1	5,350.00	0	0	0.3	0	30
11.9	5,200.00	0	0	0.3	0	28
11.6	5,000.00	0	0	0.2	0	30
As you'll notice in the logs, when the knock sensor picked up noise, the TPS was at near 0% and the afterfire just occured. Is this knock or justr noise from the afterfire?
BTW.. the reason the runs began so late was due to me trying to determine whether the afterfire was causing the increased knock noise.
Thanks in advance.
syoung0298 is offline   Reply With Quote
Old 08-06-2005, 03:21 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
You're hitting the rev limiter and this is why you're hearing the "popping." It's set at 7300 soft and 7600 hard.
9 out of 10 times when the TPS is at 0% on the Hydra it's just noise or the rev limiter. I have yet to hear knock at zero TPS on the Hydra while using a knock headset since I program fairly low ignition timing during those conditions.
Thanks,
Phil
www.elementtuning.com
240.246.0302
Element Tuning is offline   Reply With Quote
Old 08-06-2005, 04:06 PM   #3
syoung0298
Member#: 84772
2005 GDB STI
Thanks for the info Phil.
Front / Rear 05+ STI aftermarket rotors and Axxis Ult pads , and stock 04 sti grill -AspenSTi- NWIC Private Classifieds 7 04-11-2009 11:10 AM
FS: 05 STi Heads (Complete) and 05 STi Block SlammedREX Engine/Power/Exhaust 31 07-06-2008 01:14 PM
exedy triple plate, and hydra ems cbourbs Private 'Wanted' Classifieds 6 05-30-2007 11:47 PM
Agile Protuned 05 Sti w/ GT35R Agile Auto Proven Power Bragging 2 04-13-2007 03:05 AM
WTT: 04 STI door cards and switches for 05+ STI door cards and switches sc00ter Interior/Dressup/Audio & Security 1 01-21-2007 10:12 PM
