Old 08-06-2005, 07:04 PM   #1
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Default which is better for track and autox
which setup is better
17X7.5 with 225/40/17
or
18X7/5 with 225/40/18
mainly i want to use for daily driver and occational track and autoX
Kenji815 is offline   Reply With Quote
Old 08-06-2005, 07:57 PM   #2
thesmokingman
Member#: 17751
The smaller ones for competing.
thesmokingman is offline   Reply With Quote
Old 08-06-2005, 08:11 PM   #3
Call_me_Tom
Member#: 60972
Prodrive recommends a 18x8 wheel with a 225/40-18 tire for a good street track combo...if that helps.
Call_me_Tom is offline   Reply With Quote
Old 08-06-2005, 08:17 PM   #4
thesmokingman
Member#: 17751
18's for the street set the car off right. However on a track, especially autox, a smaller wheel is better.
Old 08-06-2005, 08:27 PM   #5
Call_me_Tom
Member#: 60972
I guess it all boils down to what he is going to use the car for because track time is different then AutoX is different then street.
That being said I was brought up being told that the only reason to go to a larger diameter tire is fit a BBK. Sense most BBK's fit under 17's that would be the best trade off between the two.
Old 08-06-2005, 10:50 PM   #6
SolidSnake
Member#: 74034
2004 426whp 403wtq
Top Speed Tuned STi!
17's are best performance size, and 18's or 19's for street bling bling
SolidSnake is offline   Reply With Quote
Old 08-07-2005, 02:18 AM   #7
gregr01
Member#: 49333
04 STi
java pearl black
18s may be a viable choice for autox if your most favorable width is only available in that diameter. Otherwise, the (likely) lower weight of a 17 is the way to go.
Since you're going to be using one set for street and autox/track, you aren't looking to be nationally competitive, and you probably won't be at the top of your region--so go with what you like and let the performance chips fall where they may; you'll be fine on either.
gregr01 is offline   Reply With Quote
Old 08-07-2005, 08:41 PM   #8
cooleyjb
Member#: 55727
#533 Spec Racer Ford
You can get a tire that is both competitve nationally and streetable.
That is what we find in the STX class with the Kumho, Hankooks, Azenis etc.
17 is much better for performance in most every way. Weight, Diameter and so on.
Also 17's are cheaper.
More tires to choose from in 17.
No Brainer here. Go 17
cooleyjb is offline   Reply With Quote
Old 08-08-2005, 09:16 AM   #9
Tire Rack Moderator
Member#: 1215
ext. 4362
I would recommend 17's for track use
Old 08-08-2005, 03:11 PM   #10
ratt_finkel
Member#: 46218
06 EVO 9
They are also hoping you will buy 18" rims from them.
ratt_finkel is offline   Reply With Quote
Old 08-09-2005, 11:57 AM   #11
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
yeah. i was thinking 17 was better for the weight diameter and initial takeoff..
18 just look better visually.
mainly i want to run track
which is better for track dem1k Brakes, Steering & Suspension 15 04-09-2009 08:38 AM
utec vs ap and protune, which is better for me? borlarex88 UTEC 4 11-15-2008 03:45 PM
Electronic boost controller or ECU upgrade, which is better for a stock car and why? WRXWAGON04NYC Newbies & FAQs 5 11-01-2004 10:17 AM
Electronic boost controller or ECU upgrade, which is better for a stock car and why? WRXWAGON04NYC General Community 12 11-01-2004 12:49 AM
WRX or RS wheel. Which is better for Auto-X? Corey Motorsports 8 01-16-2002 01:16 AM
