Old 08-06-2005, 07:43 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Laptop help needed. Won't turn on, or turns on then dies
I have a Dell Latitude laptop, about two years old. It's having some type of power issue. It just shut off one day while plugged in and with the battery in it. Then it would turn back on for between 10 seconds and 5 minutes before it died. Now it won't turn on at all. I can hear a reaaally low humming sound when I plug it in or hold the power down. I'm not a computer expert, but I assume it is a power issue and the harddrive is fine. So I'm basically just looking for a possible source of the problem. Motherboard, power, etc. Thanks for any help.
garface is offline   Reply With Quote
Old 08-06-2005, 08:41 PM   #2
VSG
Member#: 19435
I had a similar problem with my 4 year old power book. Replaced the AC adapter and it's been fine since.
VSG is offline   Reply With Quote
Old 08-06-2005, 08:44 PM   #3
StuBeck
Member#: 19546
2009 Honda Fit
It is probably the power brick which is dead, if it isn't charging you won't get power anywhere else.
StuBeck is offline   Reply With Quote
Old 08-06-2005, 08:44 PM   #4
incorporeal
FTW RIP
Member#: 1820
its because of the ice cream
FTW
incorporeal is offline   Reply With Quote
Old 08-06-2005, 08:45 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
JDM dell swap time.
Soon2Bgreat is offline   Reply With Quote
Old 08-06-2005, 09:08 PM   #6
StuBeck
Member#: 19546
2009 Honda Fit
IBItsADellItsAPieceOfCrap
Old 08-07-2005, 12:30 AM   #7
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
my sony laptop had the same problem
kevinh211 is offline   Reply With Quote
Old 08-07-2005, 12:39 AM   #8
GlobalWaste
Member#: 74792
my laptop had the same problem, it'd turn on for a few minutes and then shut off, then eventually the on light came on but nothing actually happened... turned out i had burnt out my motherboard and shorted a few wires... something like that
GlobalWaste is offline   Reply With Quote
Old 08-08-2005, 09:44 AM   #9
garface
Member#: 1581
MY00 RS/STi7
Thanks guys. I have tried two different batteries which are both fully charged, so I don't think it is the ac adaptor. It won't work plugged into the wall or running off the battery. This actually happened about a year ago and then worked fine after a week. So what exactly is the power brick? Should I just replace the mobo? Thanks again.
Old 08-08-2005, 09:47 AM   #10
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
No idea what's wrong...
But since we are on laptops...I've been thinking about something. What do you do regarding surge protection on laptops? I mean you don't always have a surge protector on the outlet to plug into, so are there small portable ones? Or does the AC adaptor have inherent surge protection built in?
Neek is offline   Reply With Quote
Old 08-08-2005, 10:02 AM   #11
garface
Member#: 1581
MY00 RS/STi7
I would think the ac adaptor has it. That's why it has that big box on it normally.
Old 08-08-2005, 10:04 AM   #12
aod
Member#: 7121
Install FreeBSD on it.
aod is offline   Reply With Quote
Old 08-08-2005, 10:07 AM   #13
gongzero
Member#: 25040
Up with skirts,
down with pants!
The "big box" is an AC-DC converter, isn't it?
I imagine it could incorporate a surge protector too.
-A
gongzero is offline   Reply With Quote
Old 08-08-2005, 10:46 AM   #14
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Does anyone know for sure?
Old 08-08-2005, 10:48 AM   #15
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Old 08-08-2005, 11:23 AM   #16
DrBuzzad
Member#: 1345
2005 Legacy
Atlantic Blue
Shut off the computer and remove:
RAM
Battery
any wireless cards
Then put back in one by one to see which is causing the problem
I had this happen a few months ago. It turned out it got power fine except for when the RAM was in...then it would die in 4 or so seconds. I bought new RAM and it was fine after that....but I still sold the POS.
DrBuzzad is offline   Reply With Quote
Old 08-08-2005, 11:27 AM   #17
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
IBhowdidyoupostthisthen?
Machine Age Victim is offline   Reply With Quote
Old 08-08-2005, 11:42 AM   #18
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
+1 laptop power supply (internal)
try what dr buzzard said
your probbaly screwed
Old 08-08-2005, 12:09 PM   #19
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
All I do all day long is work on Dell laptops. If you have swapped batteries then my guess is the motherboard is shot. You can try to remove the RAM cards, optical drive ect but don't bet on it working.
I am sure it is just a small part that is bad but with laptops if its not the HDD or the optical drive you almost have to replace the entire board as everything else is on board.
bhall is offline   Reply With Quote
Old 08-08-2005, 12:20 PM   #20
Machine Age Victim
Member#: 29961
2008 Honda Element
IBdon'topenletdie
god, I'm bored
Old 08-08-2005, 12:41 PM   #21
Thug
Choke Artist
Member#: 603
I had an old Dell doing the same thing. I had to take the battery out and start up the computer on AC power only.
Thug is offline   Reply With Quote
Old 08-10-2005, 10:18 AM   #22
garface
Member#: 1581
MY00 RS/STi7
It doesn't work on ac power or battery. I'll have to figure out what's what in there. I took it apart last night, but it's a little more confusing than a desktop inside. There were two wires that were kind of taped down, but I can't tell if they were taped together or to a certain part. Very ghetto looking, maybe grounds?
Old 08-10-2005, 10:30 AM   #23
DrBuzzad
Member#: 1345
2005 Legacy
Atlantic Blue
Were the ram and other cards out when you tested in on ac power only?
Old 08-10-2005, 10:39 AM   #24
garface
Member#: 1581
MY00 RS/STi7
I haven't figured out exactly where they are yet. Would they be accessable after removing the keyboard section?
Old 08-10-2005, 10:59 AM   #25
BacDoc
The Shaw of OT
Member#: 75141
My Dell Insipron 3800 did that last year = Motherboard.
EEEEEEEEbbbbbbbbbaaaaaaaaaaaaaaaaaayyyyyyyyyyyyyyy yy!!!!
BacDoc is offline   Reply With Quote
New laptop help needed ANZAC_1915 Off-Topic 15 05-12-2008 02:17 PM
Laptop help needed....OT I turn to you for help The Tree Off-Topic 16 07-19-2006 02:07 PM
Laptop Help needed!! Sephro Off-Topic 12 01-18-2006 10:00 AM
Tongue Rings: Turn on? or Turn off? MidnightSti05 Off-Topic 37 06-09-2005 11:26 AM
was that lift, turn,break, or turn, lift, throttle?????? joe z New England Impreza Club Forum -- NESIC 26 02-20-2001 06:30 AM
