Old 08-08-2005, 04:03 AM   #1
zroom tsuchiya
Member#: 28959
Default Are the brake pads on the 98 2.5RS the same as the 02 WRX?
I've been searching on the forum for this answer and looking up the part number but it's either I'm not a good searching star or that there is no answer!
So some that knows, please answer:
Are the brake pads on the 98 2.5rs same as the 02 WRX?
zroom tsuchiya is offline   Reply With Quote
Old 08-08-2005, 10:46 AM   #2
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
I don't think so..... 98's backing plate is different from 99-01 if I recall right.....
I use 02 wrx brake compenents on my 99 as the front calipers are identical.... only needed rotors/caliper braket for the upgrade....
if you can post a pic of the brake pad on your 98, i could confirm... I have spare 99 pads (could take a pic)....
Robin
Robin2 is offline   Reply With Quote
Old 08-08-2005, 02:41 PM   #3
zroom tsuchiya
Member#: 28959
Old 08-08-2005, 02:42 PM   #4
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Yes up till 12/02 for the WRX, then subaru changed the brake pad design.
jdmimpreza is offline   Reply With Quote
Old 08-09-2005, 11:08 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Here's my brake pads..... from my 99.... which are identical to 2002wrx....
The bottom pads are the rear... which I might do h6 upgrade too.....
Robin
98 legacy GT 5mt same as 01 rs/wrx execept ratio?! serious Transmission (AT/MT) & Driveline 4 08-12-2009 02:16 PM
Brand new Hawk HPS brake pads for Subaru Impreza 2.5RS/WRX/FXT - moving sale CALIBAN Suspension/Brakes/Handling 2 07-28-2009 02:04 PM
Is the BPV for an 06 STi the same as an 02 wrx? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-22-2006 07:17 PM
is the 2.5 rs(2002) same as the sti motor? DennisAltered Mid Atlantic Impreza Club -- MAIC 5 03-10-2005 06:27 PM
2.5RS airbox same as 2002 OBS 2.5NA? HolyCrikey Normally Aspirated Powertrain 9 02-11-2005 01:09 AM
