Old 08-08-2005, 01:02 PM   #1
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Default RS ECU wow - Knock Correction
So I was pretty sure that my shortblock was blown for about a week. I had just installed my Emanage Ultimate and the car was running extremely slugish and with almost no power. I had the boost way down till I had time to do some significant retuning and was hoping that it was just my learning curve and the new nature of the ultimate that was causing my issues.
Well I decided to log the stock ECU to see if everything was happy sensor wise and came accross an interesting MIL code "Knock Sensor Circuit Malfunction".
I had never seen that code but decided to check it out and swapped out the knock sensor... no luck
Looking at the dataloggs closer revealed that the ECU was droping to 4 degrees of advance at partial throttle!!!! 4! and holding at 4 seemingly indefinitely! If that is what limp mode entails thats pretty extreme!! I am pretty sure I wasn't in limp mode cause I could rev past 4k If I really tried. The car made absolutely no power at all with good reason!
SO I found that the Ultimate was pulling the knock sensor up! I haven't got the knock detection on the ultimate running yet but wired it regardless to see if it would work. So basically it was causing the stock ECU to see intense knock ALL the time.
After fixing the pull up issue the car now runs as smooth as ever again. Looks like I'll go back to using the J&S for knock detection till I find a better solution / get the ultimate detection compairible.
So the moral of the story is the Stock ECU is incredible in its capacity to remove timing with respect to knock. I see almost 40 degrees sometimes on light throttle and for it to drop it to 4! Thats pretty extreme!
On the other hand its good to know that the stock ecu has the capibility to trim ignition to that degree. I suggest everyone RSt buy a cable from http://tactrix.com/ and get the free ECU logger from http://www.tari.co.za/ and check out the iGN timing and knock correction that your ECU is currently running while turbo - send me the logs too just out of curiosity - hydraedit@gmail.com
Hitokiri is offline   Reply With Quote
Old 08-08-2005, 03:23 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
wow that is interesting info, your car was really retarded, hopefully it didnt rub off
Ben
PHATsuby is online now   Reply With Quote
How come I Can't see feedback knock correction, fine learning knock correction? AraSh Open Source Reflashes 13 05-12-2013 11:06 PM
fbkc, knock sum, knock correction advance, help kh15 Open Source Reflashes 7 06-05-2009 12:56 PM
Correlations between Knock Lite and negative knock correction xFactor Engine Management & Tuning 1 01-12-2006 07:36 PM
ECU reset-> 16 IAM = "aggressive" knock correction BIGSKYWRX Engine Management & Tuning 13 05-10-2005 10:18 AM
Knock Correction and timing (long!) Ryan23 Factory 2.0L Turbo Powertrain 14 06-28-2002 07:18 PM
Message Board Statistics All times are GMT -4. The time now is 02:32 PM.
