Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 08-08-2005, 08:29 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Version 6 STi RA and RA SE gears back in stock!!! Transmissions too!!!
Hey all,
Version 6 STi RA and RA SE gear sets are finally back in stock. As we all know, the transmission is really the weak point of the WRX. These gears are much stronger than your stock gears and also have shorter ratios which will lead to better acceleration at the expense of top end speed.
As taken from our website:
Do you need to hold more power put cannot afford the STI 6-speed transmission? Don't want the inconveniences of a dog-box or the price? Looking for a more track friendly gear ratio? Then our STI RA gear-set is the perfect solution for you!
The STI RA V6 gears are a found in the rally-bred Version 6 Impreza STI RA and is designed to be a much beefier swap for your WRX 5-speed transmission. The thicker gear teeth as well as the inherently stronger gears and shaft are a perfect solution for customers looking for gear-sets that will hold more power. For further strengthening all gear-sets are CRYOGENICALLY TREATED.
We recommend these gear-sets for customers looking for gear-sets to hold 275-350awhp. For higher power levels we would recommend either a STI 6-speed tranny or a synchroless dog-box.
All gearset kits include STI RA Gears 1-5, main shaft, properly matched speed-o gear, and shifter fork. Please see our bearing and synchro sections for a complete rebuild kit. Rebuild time is generally 5-6 hours of bench time (not including removal & installation) and if your transmission is damaged will usually require new bearings and synchros.
*Also, we have we now have the RA SE gears. Do you want to have better acceleration and save gas? Looking for the best of both worlds? The STI RA (Special Edition) V6 gears are a great upgrade for guys that want to keep the stock 5th gear, but still have a shorter ratio down low. 4th and 5th gear ratios are retained, which allows for a smoother transition to 5th (instead of the grinding when you just leave the stock WRX 5th gear in). But 1st, 2nd, and 3rd gear are the same as the normal RA gears.
Version 6 STi RA gears - $1349 shipped
Version 6 STi RA SE gears - $1349 shipped
Subaru Genuine Bearing Set- $255 shipped
Thanks,
Preston
510-783-5300
preston@gruppe-s.com
Gruppe-S is offline
Old 08-08-2005, 08:32 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default Transmissions!!!
TURBO TRANSMISSIONS / CLOSE RATIO BOXES - Will bolt to any turbo Impreza with matching final drive rear diff.
2001 WRX JDM 5-SPEED 4.44 Final Drive (Two at this price)
-Super Rare JDM 4.44 5-Speed
-Factory Production Overstock, less than 1000KM
-Great for Road-Race and Rally-X
-Priced to Move!!!
$1099 + Shipping!!
With 4.44 Rear Diff $1599 + Shipping!!
NON-TURBO PUSH-TYPE TRANSMISSIONS
2005 Subaru Legacy Transmission
$699 + shipping ! IN STOCK READY TO SHIP ! >ONE< AT THIS PRICE
-Non-Turbo Push Type 5 Speed
-1st 3.454, 2nd 2.062, 3rd 1.448, 4th 1.088, 5th 0.871, Final 4.111
2005 Subaru Impreza 2.5RS Transmission
$699 + shipping ! IN STOCK READY TO SHIP ! >TWO< AT THIS PRICE
-Push Type 5 Speed
-1st 3.545, 2nd 2.111, 3rd 1.448, 4th 1.088, 5th 0.78, Final 3.9
Subaru Mystery Transmission
$649 + shipping ! IN STOCK READY TO SHIP ! >ONE< AT THIS PRICE
-Push Type 5 Speed
-1st 3.545, 2nd 1.947, 3rd 1.366, 4th 0.972, 5th 0.738, Final 3.9
Thanks,
Preston
510-783-5300
Gruppe-S is offline
Old 08-08-2005, 10:02 PM   #3
oneoverWRX
Member Sales Rating: (14)
Member#: 74793
02 WRX
BLAZE YELLOW
Are the gears in these trannies stronger than the usdm wrx gears? What hp and tq are they rated for? Are the ratios the same as the usdm wrx? Do you offer any warranty on these trannies? Please respond asap. Car is broke need to fix asap.
oneoverWRX is offline
Old 08-09-2005, 12:05 PM   #4
JoBoo
Member Sales Rating: (9)
Member#: 23423
05 STi / 08 Dmax
IDP Racing Tech Monkey
preston-
email's ya last night
JoBoo is offline
Old 08-09-2005, 03:56 PM   #5
hyp36rmax
Member Sales Rating: (5)
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
will the legacy tranny fit a my04 wrx? waht are the differences...?
hyp36rmax is offline
Old 08-11-2005, 10:09 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
oneoverWRX - These trannies are not any stronger than the USDM trannies... they aren't rated for any specific horsepower rating but it would basically be the same as a stock WRX tranny.
hyp36rmax - The Legacy tranny in this post is from a non-turbo legacy which uses a push (instead of pull) type clutchs sytem so it won't bolt on without serious modifications.
Thanks,
Max
510-783-5300
Gruppe-S is offline
Old 08-12-2005, 11:00 AM   #7
Kreeger
Member Sales Rating: (4)
Member#: 37558
2003 TS wagon
JDM bukkake white
Thanks,
Max
510-783-5300
Actually, the Leg tranny WILL bolt up perfectly, but you would have to use the weaker push-type clutch and flywheel.... It would be a serious step backwards. I am still running a stock 2003 TS tranny with an upgraded clutch on my STi ver 7 motor... and hating it.
Kreeger is offline
Old 08-14-2005, 09:42 PM   #8
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
which synchros are those in the synchro set that you have on your website?
spankaveli is offline
Old 08-15-2005, 03:45 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Those are the Subaru genuine synchros that are needed for the 5sp WRX transmission.
Thanks,
Geoff
Gruppe-S is offline
Old 08-15-2005, 04:08 PM   #10
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
Right, I meant which gears are those synchros for? I'm not too familiar with the inner workings and your site says that those are the ones that most commonly fail so I just want to make sure I don't need any other synchro's also...
Old 08-16-2005, 01:20 AM   #11
trbowrx
Member Sales Rating: (20)
Member#: 50770
08 STi
04 536whp STi Sold!
will the 01 jdm wrx tranny listed bolt right up to a 02 wrx with no modifications? or do u need a diffent rear diff
trbowrx is offline
Old 08-16-2005, 06:44 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
PM sent
Thanks
Preston
Gruppe-S is offline
Old 08-17-2005, 04:40 PM   #13
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
Info?
Old 08-18-2005, 09:01 AM   #14
mpaone
Member Sales Rating: (30)
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Lightbulb
PM'ed you Preston.
-Mike.
mpaone is offline
Old 08-18-2005, 01:14 PM   #15
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
I'll be ordering this ASAP but I need to know if I need any other synchros other than the ones that are in your kit. Can you tell me which gears the synchros in the kit is for?
Old 08-18-2005, 03:24 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
spankaveli - PM sent
Thanks
Preston
Gruppe-S is offline
Old 08-18-2005, 06:19 PM   #17
BurtonCR
Member Sales Rating: (6)
Member#: 7138
Do you have the RA SE gears in stock?
Thanks,
Chris
BurtonCR is offline
Old 08-18-2005, 09:43 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey Chris,
We're actually already out of RA SE gearsets. We are expecting more in in about 3 weeks but the best way to guarentee yourself a set of these is to preorder them (because they are so popular).
Thanks,
Geoff
Gruppe-S is offline
Closed Thread
MSI endlinks and anti-lift kits back in stock Fine Line Imports Suspension/Brakes/Handling 1 04-15-2010 01:52 PM
Titek Equal and UnEqual Length Headers BACK IN STOCK!!! *Limited Supply!! SpeedElement Engine/Power/Exhaust 3 02-26-2010 04:09 PM
2002-2005 WRX Tranny with Version 6 STi RA Gears, bearings and synchro set Jus Blaze Drivetrain 2 12-10-2008 10:19 PM
Version 6 STi RA close ratio gear set ZpSand Transmission (AT/MT) & Driveline 2 03-14-2005 11:16 PM
