Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 08-08-2005, 10:19 PM   #1
emyselfandi
Member#: 83701
Default WTB 95-99 Legacy 2.2L exhaust headers
I'm looking for a set of exhaust pipes for my 95 Legacy. It is for a 2.2L and the headers or exhaust that connects to the cylinder head is fine. The part that Iím really looking for is the two pipes that connect to the Y pipe. My driverís side one is rattling like crazy. I'd like to find a set out of a 99 or 98. If not something that is low mileage. email me cuz Iím not on this board much. emyselfandi@yahoo.com. I attached a pic of the parts that Iím looking for. Thanks, Tim
emyselfandi is offline   Reply With Quote
Old 08-09-2005, 12:03 AM   #2
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
You Should Take A Look At Your Ports On The Bottom Of You Engine If You Have A Dual Port 2.2 You Can Also Use The 2.5 Headers For The Gt The Only Time You Should Worry About Having The 2.2 Headers Is If You Have A Single Port 2.2-i'm Not Even Sure Of The Engine Years Those Are I Have 95 Dual Port Ej22
~mike
pilfflip is offline   Reply With Quote
Old 08-09-2005, 12:16 AM   #3
spdracr00
Member#: 65823
1996 Impreza L
Red
$100 at the local subie boneyard... got mine there.. works great, even has the good welds not the cheap fold welds on some of the headers...
spdracr00 is offline   Reply With Quote
Old 08-09-2005, 10:54 AM   #4
boostinwrx
Member#: 14715
09 Rigdeline RTL,
07 Burgman 650 Modified
check the heat shield mime was loose and making crazy noise so i had a shop tack welded back on no problem since
javier
boostinwrx is offline   Reply With Quote
Old 08-09-2005, 08:54 PM   #5
emyselfandi
Member#: 83701
~mike
mike, how do i check if it's a dual port or single? mines a 95 LSi 2.2. the header part is one single metal tube on either side. Then it has a clamp on each side of the pipe that is connected to the Y. I have a picture posted here:
http://www.i-club.com/forums/showthread.php?t=108030
sorry for listing the other site.. we all know NASIOC kicks all thier butts...
Old 08-09-2005, 08:57 PM   #6
emyselfandi
Member#: 83701
javier
Javier, the tube is loose and rattling like crazy. I thought it was a bad bearing in one of the timing belt pullies. Had my wife take her suby into the stealership for a free estimate. They said it was the head shield on the Y pipe... Quoted 450 to fix it. I called and only suby has the exhaust parts.. Is the heat shield just covering the exhaust tube? How did they tack it up? Might go this route b/c it will be 10-20 bucks... thanks, Tim
Old 08-10-2005, 08:45 PM   #7
emyselfandi
Member#: 83701
no one wants to answer? TIA, Tim
Old 08-11-2005, 01:53 PM   #8
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Strip the heat shields off. They're not critical. And they will just start rattling again anyway.
Huffer is offline   Reply With Quote
Old 08-11-2005, 02:18 PM   #9
Dobes
Member#: 164
1997 Legacy GT-T
You can either take the heat shields off completely or take your car to Midas or Meineke and have them tack weld the sheilds for a couple bucks. $450 sounds like the stealer is quoting a new header which is completely unnecessary.
JD
Dobes is offline   Reply With Quote
Exhaust for 99 legacy 2.2L darbronnoco Legacy Forum 3 05-17-2014 11:13 PM
99 Legacy 2.2L question Drat Legacy Forum 1 10-16-2007 11:02 AM
External automatic transmission filter on a 99 Legacy 2.2L puchma Transmission (AT/MT) & Driveline 2 11-10-2005 01:40 PM
wtb 95-99 legacy side skirts/front bumper serious Legacy Forum 1 09-16-2003 09:12 PM
