Old 08-08-2005, 10:45 PM   #1
DamnYank!
Member#: 38293
1995 M3
Avus Blue
Default 7" wheel one side, 7.5" other side??
i have a set of wheels that are 17x7. i ruined one after a 'spirited encounter' with a curb
i have located a replacement of same style, diameter, and offset but the width is 7.5
do i run any chance of damaging my differentials by running a wheel a half inch wider on one side of the car?
i can't imagine so but i wanted to get some input before proceding...
DamnYank! is offline   Reply With Quote
Old 08-08-2005, 11:35 PM   #2
Rail
Member#: 38287
2005 Honda S2000
NFR
Well, it'd require more torque to spin the wider(heavier) wheel, so the diffs would be working even when you're driving in a straight line. It might not be significantly more wear, but I wouldn't recommend it.
Also, you need to consider driveability. I'm not sure what effect running like that would have, but I can't imagine it would be anything but negative. If you're insistent on running different width rims, try and get a pair of them. You want the drivetrain to be balanced left to right.
Rail is offline   Reply With Quote
Old 08-09-2005, 12:11 AM   #3
esteve
Member#: 28716
2006 STI
I would maybe try to get the wheel repaired if possible.
Not sure if your diffs will get damaged, but you might have some pulling or tracking problems. Wheel width affects tire width, even if they're the same size tires, so one might have a bigger footprint than the other 3. Also if they're all the same offset but one is 1/2" wider, that might have an effect too.
esteve is offline   Reply With Quote
Old 08-09-2005, 01:34 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....ya could put 2 7.5's on the front and 2 7.0's on the back....or the other way.....but I would NOT mix them side to side......NO.
four (4) Weds Sport Racing Wheels, 17" x 7.5", weigh only 13.8 lbs each azca Wheels/Tires 39 01-23-2012 08:30 PM
205 for 7", 215 for 7.5" ? Zak Shaker Tire & Wheel 17 10-01-2007 03:51 PM
SSR Comp Wheels - 17" X 7.5", Silver, With Toyo T1-S Tires MisterX Wheels/Tires 12 04-30-2007 09:10 AM
7" vs. 7.5" wheels. avantages and disadvantages cppchrisdh Tire & Wheel 11 10-09-2006 10:26 AM
7" vs. 7.5" Rims Wildman Brakes, Steering & Suspension 4 07-20-2001 01:48 AM
