Old 08-09-2005, 02:18 AM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default hydra nemesis vs MAP or Link question???
Can you tell me if the plug and play Hydra EMS for Impreza RS come with a base map or we have to start of noting if we want to tune it for a RS-T??
How much time can it get to a tuner who tune normally ecutech to tune a hydra if he never toch it before??
OB2 is offline   Reply With Quote
Old 08-09-2005, 03:28 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Depends on who you buy it from i believe. The Hydra should be amazingly easy to tune even for someone who hasn't used it before. Check out the Element tuning guides. Phil may have a base map for a RS
Old 08-09-2005, 03:46 PM   #3
420-Rex
Member#: 61506
2003 Impreza WRX
I got a wrx with a Hydra, Well had I just wrecked it a week ago. It camed tuned already for me from Phil himself Plug and play. Anyways Im sure he could do the same for you, just let him know your mods. Z in ATX.
420-Rex is offline   Reply With Quote
Old 08-09-2005, 09:24 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
While we do not specialize in the RS we do have a large selection of tuned base maps that are available to Element Tuning customers. If you have an RS with a turbo engine then we have many maps to choose from. If you have a high compression RS engine with a turbocharger then we'll have to guide you with tuning the ignition curve.
The benefit to purchasing your unit from Element Tuning is the tech support since no one knows the Hydra better than we do and most of the mapping is fully tuned. What’s left are the fuel and ignition maps and how much work they need depends on the modifications.
Send an email or call and I'll let you know if we have maps that are close and need minor work or need major work.
Thanks,
Phil
www.elementtuning.com
240.246.0302
PS I'm rarely in this section I just seen Hydra pop up on the main page.
Element Tuning is offline   Reply With Quote
Old 08-10-2005, 09:21 AM   #5
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
OB2
RSts have had mixed feeling about the hydra. My personal experience is that it never worked perfectly for us. Tuning wise it wasn't overly difficult as Phil said he has set some of the correction maps to be in the ball park for you.
I would be cautious with the Hydra however. Our project didn't run for 4 months while Andrew and Hydra sorted out problems with out maps and internal harware issues with the hydra losing the crank position signal due to inadequate filtering and detection schemes. The hydra is also not very resilient as far as starting battery voltage and you will find other issues as you get closer and closer to a custom tune.
I am by no means saying that its not a good unit, it just hasn't been sorted out completely yet which can be expected of a new unit. The software and tuning interface is poor - the datalogging and data display is very poor. There is no graphing capability to speak of.
lastly: Phil may say he has maps. But by that he means that he has enough tuning on Subarus that he can piece you together a map from ones he has already tuning. You WILL have to completly retune idle and peak power
Hitokiri is offline   Reply With Quote
Old 08-11-2005, 11:59 PM   #6
OB2
Member#: 51500
1999 impreza rs-t
sylver
So what should I do?? I know Link have some troble too!!!
Should I buy a Link?? I live in Quebec Canada where it make +30degre C in summer and -30 degre C in winter. Sure I use my car only in summer but the Link will it be ok for me???
Do some one a GOOD use Link for sale at a good price to try??
What do I do?????
Hydra Nemesis password? HELP!! Pi7467mp Other Engine Management 2 11-13-2004 02:41 PM
Hydra Nemesis 2.0 NeaD Other Engine Management 426 10-20-2004 09:55 AM
Hydra Nemesis knock count? STi_Drift Other Engine Management 3 10-13-2004 02:06 PM
Need help developing PNP HYDRA Nemesis 2.0 ecu for 99-02 2.5RS HydraEMS-NA Other Engine Management 1 02-17-2004 11:40 AM
hydra nemesis ecu audioize Other Engine Management 7 02-09-2004 11:35 AM
