Old 08-09-2005, 01:21 PM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default JDM and EUR Spec Bonanza!
As some of you have seen from some of my other posts, I have been trying to build up a library of part and model information for the JDM and European/Australian models. I recently got most of the missing information, and have compiled it together. This includes all of the production engine numbers, as well as a select number of other internal parts.
The only piece of info I am missing is the new US 06 stuff. If anyone happens to have access to a copy of the Subaru FAST update disk from July 05, drop me a line (I have the June 05 update, but it doesn't have the new 06 stuff).
Observations about different model changes:
JDM
General
The first model year of the new age style (bug eye) had two parts. The A.1 model section appears to use some parts that carried over from the Version 6 cars, while the A.2 included more new parts.
Blocks (Crankcase only in the JDM case)
The block numbers (not short block, just crank case) has stayed the same for all MY WRXs from MY01 to 05. The STI blocks changed in the MY03, so version 7 crankcases appear to be different from the
Version 8 and Version 9. Also note that Spec C crankcases are the same as the regular STI crankcases.
11008AA690: MY01,02,03,04,05 WRX
11008AA720: MY01,02 STI
11008AA980: MY03,04,05 STI
Pistons:
The WRX pistons were unique for MY01, and changed for MY03. These changed pistons in MY03(version 8) were carried all the way forward to MY05. The STI pistons changes at the MY03 (version 8), and it is said that these new pistons were Hypereutetic instead of forged. Again note that the Spec C has the same pistons as the regular STI in each model year.
12006AB190: MY01 WRX
12006AC150: MY02,03,04,05 WRX
12006AB430: MY01,02 STI
12006AC430: MY03,04,05 STI
Crankshaft:
All MY01s and 02 use the same crank shaft PN, including the STI and Spec C. Note that the crank was updated however (from 210 to 240), and all replacement cranks in all WRXs are spec'd to use this new part. All WRXs from MY01 to MY05 use this same crankshaft. In MY03 (version 8) the STI and Spec C received a new crank. This new crank was carried forward for all STIs in MY04 and MY05.
12200AA210: MY01,02,03 WRX MY01,02 STI
12200AA240: MY01,02,03 WRX MY01,02 STI [UPDATED]
12200AA270: MY03,04,05 STI
Rods:
WRX rods received an update across all of the models sometime on 03. MY01 and MY02 STIs used the same rods. MY03 STIs received a new rod. All STI model years were updated to a newer rod (x180), which is the same rod used in the US STI.
12100AA081: MY01,02,03,04 WRX
12100AA190: MY01,02,03,04,05 WRX [UPDATED]
12100AA161: MY01,02 STI
12100AA170: MY03 STI
12100AA180: MY01,02,03,04,05 STI [UPDATED]
Cams:
The MY01 and MY02 WRX used the same cam. Al MY01 STIs used the same cam. In MY02 the Spec C was given a special cam, and that special cam was used in ALL STIs in MY03. In MY03 all WRXs got a new cam, and again a new cam in 04/05. All STIs also got a new cam in 04/05. Note that all Spec Cs after MY02 use the same cam as the regular STI.
13037AA200: MY01,02 WRX
13037AA220: MY01 ALL STIs, MY02 STI
13037AA340; MY02 STI RA Spec C, MY03 ALL STIs
13037AA401: MY03 WRX
13037AA470: MY04,05 WRX
13037AA480: MY04,05 ALL STIs
Heads:
This is interesting note. All the WRXs and STIs in MY01 and 02 are the same. In looking at these motors, the Spec C in MY02 appears to have a more ported inlet, even though it is the same casting. I suspect that the 'porting' is part of the engine build process, but when you buy a replacement head, this porting is not done. From what others have told me, this is the same with the Acura Integra Type R (When you buy a replacement factory head, it is not ported like the production car ones are).
Also note that in 03, all WRXs and STIs got a new head, carried to 04 and 05. For this reason, I'm assuming that the 04 and 05 WRXs and STIs use the WRX/JDM style cam sensors (3 sensors), not the new 2 sensor system used on the fly-by-wire US STI. (Actually I checked, and the cam sensors on all of the JDM cars has remained the same, so yes, the JDM WRX and STIs still use the older style. I suspect this will change in 06 with the JDM switch to drive-by-wire.
11039AB370: MY01,02 All WRXs and STIs
11039AB660: MY03,04,05 All WRXs and STIs
Valvesprings:
Notice WRX valvesprings are the same as the USDM ones. MY02 STI Spec Cs had a unique sping, which was not used again. When subaru went to the larger Spec C cams in 02, they must have tried a new spring. In MY03, when all STIs got the same Spec C cam, they decided to go back to the regular STI
spring. Perhaps the MY02 Spec C spring was too strong. Also the MY03 and up WRX got a new spring.
13217AA193: MY01,02 WRX
13217AA202: MY01 All STIs MY02 STIs (not Spec C), MY03,04,05 All STIs,
13217AA251: MY03,04,05 WRX
13217AA280: MY02 STI Spec C
US Market Cars:
Blocks (Complete Shortblocks)
10103AB330: MY02,03,04,05 WRX
10100AB440: MY04,05 STI
Pistons:
12006AC350: MY02,03,04,05 WRX
12006AC390: MY04,05 STI
Crankshaft:
As with the JDM market, the 02 WRX crankshaft was updated, and all MY03 and greater WRXs use this new crankshaft. I personally observed that my 02 Spec C crank was double drilled, while my stock WRX crankshaft was single drilled. I suspect the double drilling may have been the change from (0x210) to (0x240). Anyone with an 04 or 05 WRX crank could confirm this.
12200AA210: MY02 WRX
12200AA240: MY02,03,04,05 WRX [UPDATED]
12200AA260: MY04,05 STI
JDM Overlap:
WRX Crankshaft is same as JDM MY01-05 WRX crankshaft, as well as the JDM MY01,02 STI crankshaft.
Rods:
WRX rods when thu several iterations, starting in the MY03 and again in MY04. MY05 received yet another rod update. All replacement rods for all series use this rod (0x240).
The STI rod is the same as the JDM STI rods. (However note that not all older JDM STI blocks uses this revision).
12100AA080 MY02 WRX
12100AA081 MY02,03,04 WRX [UPDATED]
12100AA190 MY03,04 WRX [UPDATED]
12100AA180 MY04,05 STI
12100AA240 MY05 WRX [UPDATED]
JDM Overlap:
x081 WRX rods are same as JDM WRX rods.
x190 WRX rods are same as JDM WRX rods.
x180 STI rods are same as JDM STI rods (all versions)
Cams:
WRX Cams changed in 03,04, and 05. The 03 change was likly small, as they are backwards compatible to 02. The 04 change may be related to the change in MY03 to shimless buckets. All STIs use the same cam.
13037AA101 MY02 WRX
13037AA390 MY03 WRX
13037AA391 MY03,04 WRX [UPDATED]
13037AA490 MY04,05 WRX [UPDATED]
13037AA350 MY04,05 STI
Heads:
All WRX heads have remained unchanged. The STI heads received an update in April 05 (Per Hotrods post below)
11039AB361 MY02,03,04,05 WRX
11039AB650 MY04,05 STI
11039AB910 MY05 STI [updated]
Valvesprings:
As with the heads, all valvesprings remained the same.
13217AA193 MY02,03,04,05 WRX
13217AA251 MY04,05 STI
JDM Overlap:
x193 valvesprings are the same as in MY01 and 02 JDM WRX.
x251 valvesprings are the same as in MY03,04,05 JDM WRX.
NOTE: No US cars use the JDM STI valvesprings.
Needless to say, it took many hours to compile all of this data, especially the JDM stuff since the software is in Japanese!
Cheers, and here is to datasharing on Nasioc!
Jeff Sponaugle
PDXTuning.com
PDXTuning is offline   Reply With Quote
Old 08-09-2005, 02:47 PM   #2
dmross
Member#: 2818
2000 2.5RS
Simply Awesome. Thank you so much for your work in cataloging this information!
dmross is offline   Reply With Quote
Old 08-09-2005, 02:54 PM   #3
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
WOW! talk about data
djerickd is offline   Reply With Quote
Old 08-09-2005, 03:08 PM   #4
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
And people think I've got OCD Good Job Jeff.
chrisarella is offline   Reply With Quote
Old 08-09-2005, 04:52 PM   #5
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Yea, I've been called that before. Once I get the 06 info, it will be interesting to see what has changed or been carried over from the JDM market.
It is interesting to see that the South Africa and Australian market WRX/STI get a fwe different parts from the UK market. Crazy stuff.
Jeff
Old 08-09-2005, 05:29 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Good grief
Thanks man!
jblaine is offline   Reply With Quote
Old 08-09-2005, 06:12 PM   #7
Invisiguard
Member#: 43201
04 STi
07 Corvette
Awesome! You rock, this should be sticky'd here and on 2.0 forum
Invisiguard is offline   Reply With Quote
Old 08-09-2005, 09:51 PM   #8
hotrod
Member#: 14141
2002 Impreza WRX
Jeff:
Great information! Thanks for going to all the trouble to compile this and even more so for shareing it!
I just so happens that today I was down at a dealer checking on prices for some parts and he gave me some part numbers for 2.5 STi heads that don't match the numbers you have listed.
He gave 2 different numbers for each of the right and left side head (bare castings)
11039AB650 (right hand head Jan 2004 -April 2005)
11039AB910 (right hand head April 2005 to date)
11063AB120 (left hand head Jan 2004 - Mar 2005)
11063AB330 (left hand head April 2005 - to date
Are the head numbers you list for a pair of heads ?
Larry
hotrod is offline   Reply With Quote
Old 08-10-2005, 08:42 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sweet!
Old 08-10-2005, 12:47 PM   #10
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
The cost of x180 rods just went from "can't give them away" to "$$$"
n2xlr8n is offline   Reply With Quote
Old 08-10-2005, 12:58 PM   #11
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Originally Posted by hotrod
Jeff:
Larry
Nope.. Misquote on my part, as my catalog also lists the AB650, not AB640 for the US STI RH head. My catalog does not have the AB910 part number, as I suspect the dealer has the latest update which included the 06 part numbers. I'll add that head Pn to the original sheet as well! Thanks!
If anyone else gets any other 06 part #s, let me know!
Cheers!
Jeff
Old 08-10-2005, 12:59 PM   #12
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Yes, although I thought everyone knew that the US STI rods were the same as the JDM ones (including the Spec C). They are pretty good rods!
Jeff
Old 08-10-2005, 01:37 PM   #13
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Jeff
Some did.
http://forums.nasioc.com/forums/show...ight=EJ257+rod
Start at post #17
Ebeck owes me $20 worth of pennies.
Old 08-10-2005, 02:58 PM   #14
keyser_soze
Member#: 57445
Thanks Jeff. I have one question. So the USDM STi MY04 and MY05 have exact same part number pistons. So this puts an end to the MY05s have better/stronger/different pistons? Correct? Thanks.
keyser_soze is offline   Reply With Quote
Old 08-10-2005, 05:31 PM   #15
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Well, that is a good question. Subaru will usually rev the part number if there is a change. However, I have seen three different varieties of pistons come out of EJ257 blocks. The very first production blocks (from EJ257s purchased from Japan before the US STI came out) had FULLY coated pistons. I have a set of these pistons in a block I purchased right when the STI came out. The second set of pistons have no side skirt coating of any kind, and these have occurred in some of the early 04s. The third set, from a newer 05, had the coated sideskirts. All three of these parts have the same part number, and are assumed to be compatible.
So.. It seems that small changes like this are allowed within the constraints of the part number, perhaps because it is not considered performance critical.
Jeff
Old 08-13-2005, 04:11 AM   #16
Phil Jr.
Member#: 62221
question...
shouldnt the JDM V7 piston # be different than the JDM V8/V9 piston #? I thought they went from forged to hypercast?
Phil Jr. is offline   Reply With Quote
Old 09-01-2005, 04:35 PM   #17
bboy
Member#: 56468
04 Improved STI
Dirty White
Jeff, care to comment on whether JDM crankshafts are "double drilled", and more specifically if it aids in high RPM oiling of the rod bearings?
Old 09-01-2005, 04:37 PM   #18
cronic
Member#: 9749
I think the spec c's have dual oil galleries in the crank..
cronic is online now   Reply With Quote
Old 09-01-2005, 05:41 PM   #19
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
What a great reference to have! Thanks Jeff!
Javier is offline   Reply With Quote
Old 12-11-2005, 04:20 PM   #20
crispyduck
Member#: 98680
Question Permission to post this up on Scoobypedia.co.uk?
Jeff,
What a great reference!
Seems a shame for this technical information to be locked away in this thread. Would I have your permission to post this up on my Scoobypedia.co.uk wiki-based knowledge base for many others to benefit? Perhaps under the Specifications Page would be good.
Feel free to post yourself if you're interested, just let me know if you need help or prefer I did it. Don't suppose you still have the original spreadsheet? may be convert to PDF.
Regards,
-Steve.
crispyduck is offline   Reply With Quote
Old 12-13-2005, 11:54 AM   #21
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Where's all the data for Old School JDM cars?
Version 1-6 STi, WRX, RA, Type R, etc.?
omahasubaru is offline   Reply With Quote
Old 12-13-2005, 01:23 PM   #22
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Sticky!!!
Swine is offline   Reply With Quote
Old 12-13-2005, 01:33 PM   #23
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Originally Posted by crispyduck
Jeff,
Regards,
-Steve.
No problem Steve.. I ahve a newer format that I'll send you that is a bit better..
Also, I just got all of the JDM and US 06 Data, so I'll fish all that out and get 06 charts up as well.
As for the older JDM cars, I have all the data available, I just need to compile it together! As you can imagine, it is pretty time consuming, especially with the JDM software in Japanese!
Cheers,
jeff
Old 12-16-2005, 03:46 PM   #24
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
so i can find this later
kaneda3 is offline   Reply With Quote
Old 12-17-2005, 03:29 AM   #25
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Again everyone benefits from Jeffs labor. Thanks.
Looking forward for the early cars
DoctorNick is offline   Reply With Quote
WTB:02-03 bugeye jdm hoodscoop and jdm grille/gt spec... CDW0911 Private 'Wanted' Classifieds 4 11-19-2008 05:48 PM
JDM Spec and USDM spec piping Syms-STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 09-09-2005 03:25 PM
different between JDM exhaust and US spec? STI808 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-29-2004 12:20 PM
JDM spec and US spec? hitman912 Engine Management & Tuning 2 12-01-2003 10:17 PM
Major different between JDM and US spec WRX?? wrxwing Newbies & FAQs 13 08-11-2001 06:02 PM
