Old 01-15-2009, 03:58 AM   #51
urabus40
Member#: 199880
My User Name
Backwards and add STi
this really seems like it should be a sticky
urabus40 is offline   Reply With Quote
Old 07-09-2009, 08:16 AM   #52
johan84
Member#: 214663
i have look to the list
and i have look to the subaru pn numbers but can not find the
number on my heads, engine en block number
where are the can anybody help ??
johan84 is offline   Reply With Quote
Old 07-09-2009, 09:30 AM   #53
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
You should be able to use the tag on the front of the motor (timing cover).
Numbers are on the head between the intake ports IIRC
URABUS, this is a sticky, look in the "2.5L Powertrain forum Threads of note READ THIS FIRST".
BVM is offline   Reply With Quote
Old 07-10-2009, 07:43 AM   #54
johan84
Member#: 214663
the P/N numbers are not between the intake manifold that are oder numbers?
gr jm
Old 07-31-2009, 02:31 PM   #55
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Does anyone know the compatibility of different JDM STI ECU's to other cars? I have an 02 JDM STi Limited running the AH970 ECU. Unfortunately it's locked with an Ecutek tune and I wanted to go with opensource. I've got a line on another Ver 7 JDM STi ECU (just waiting on pics to verify what year and model it's from). Does any one know if those year ECU's are interchangeable?
subydude is offline   Reply With Quote
Old 08-28-2009, 01:39 AM   #56
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
is there any way to tell what engine i have? it does not have the timing covers, but does have big port heads, so i know its a version 8, only number i have is on the back top of the block, is there anyway to decifer that to know if i have an early or late ver 8 engine
seanathanq83 is offline   Reply With Quote
Old 08-28-2009, 04:32 AM   #57
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
what numbers/letters have casted on the heads?
I don't think there's a way to ID it under the block number, unless you are SOJ
Hyper is offline   Reply With Quote
Old 08-29-2009, 10:28 AM   #58
seanathanq83
Member#: 173241
B494174 and LHT20
just wanted to know which cam shafts i have, either from and 03 or 04 ver8
Old 08-30-2009, 01:27 AM   #59
seanathanq83
Member#: 173241
no one
Old 08-30-2009, 12:14 PM   #60
my name is joe
Member#: 171412
if only i can press control + F to find what i need on the images
my name is joe is offline   Reply With Quote
Old 09-14-2009, 01:29 AM   #61
seanathanq83
Member#: 173241
any way to find out what engine you have without the timing belt covers?
Old 10-06-2012, 07:04 AM   #62
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
so I have an jdm ej20 with a TT setup
I am not shure witch one it is as it is missing the actual engine number on the timing belt cover
here are a few numbers
beside the cast number ej20
76 ab
12212
on the bell housing
817454714817
790253
I also have the throttle body numbers
RTL60-30 1
6Y20
if someone could give me a link or something to what these numbers mean i would be extremely great full
jjppmm29 is offline   Reply With Quote
WTB:02-03 bugeye jdm hoodscoop and jdm grille/gt spec... CDW0911 Private 'Wanted' Classifieds 4 11-19-2008 05:48 PM
JDM Spec and USDM spec piping Syms-STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 09-09-2005 03:25 PM
different between JDM exhaust and US spec? STI808 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-29-2004 12:20 PM
JDM spec and US spec? hitman912 Engine Management & Tuning 2 12-01-2003 10:17 PM
Major different between JDM and US spec WRX?? wrxwing Newbies & FAQs 13 08-11-2001 06:02 PM
