Old 08-10-2005, 01:07 AM   #1
Greg555
Member#: 814
Want engine mgmnt?
I sell ViPec's ECU's
Default noizy ver 6 engine. What short block to go with?
Any recommendations? Should I fix the stock ver6 bearings or upgrade to 2.2T or maybe 2.5T
What will work good with ver 6 heads? Can Legacy 2.2T shortblock still be purchased from dealer? If so what is the part number?
Thanks
Greg
Greg555 is offline   Reply With Quote
Old 08-10-2005, 01:30 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Very hard to still find a new replacement EJ22T block from the dealer. They have stopped making them, and there was a run on them when Crawford and Axis started doing builds with them. Your best bet is an Ej257 STi block. They are about $400 cheaper (if you can find an EJ22T block) and more displacement.
Let me know if you want to sell that v6 bottom end. I might be up to rebuilding it...
Old 08-10-2005, 01:33 PM   #3
Greg555
Member#: 814
Want engine mgmnt?
Will my ver6 heads work with 2.5 sti block?
Old 08-10-2005, 01:47 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
Yep. legos...
Old 08-19-2005, 01:25 AM   #5
JDM_Scobaru
Member#: 57809
2.5 block with forged pistons and rods and you'll be happier than a pig in the mud.
Zach
JDM_Scobaru is offline   Reply With Quote
Old 09-13-2005, 07:06 PM   #6
wuuusaa
Member#: 92894
2015 Wrx
axis makes 2.2 blocks and also crawford performance makes 2.2 closed deck blocks with piston squinters and forged internals.do ur homework their out there.
what valve train to go with? hybooststi Built Motor Discussion 14 04-03-2007 03:41 AM
what catted downpipe to go with ineedparts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-10-2007 02:52 PM
sti block sohc heads... what pistons/rods to go with? rst4me Built Motor Discussion 9 01-06-2007 07:55 PM
What block to go with? WrxRacer305whp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-11-2004 10:36 AM
what size turbo to go with WiCKeDBLuREX Newbies & FAQs 2 09-20-2002 02:20 PM
