Old 08-10-2005, 09:53 AM   #1
FriedIceCream
Member#: 84154
2005 Mom's Altima
Crusty Silver
Default Do Falkens Run Bigger than usual
do they run bigger than they say? I heard this through a friend because I want falken st115 235/45/r17 but he said they run wider than my current advan a046 235/45/r17.
is this true? do falkens run rider than other brandnames with the same sizing numbers?
FriedIceCream is offline   Reply With Quote
Old 08-10-2005, 11:09 AM   #2
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Well, in general falkens may run wider, but I think that's more the old RS Sports and the new RT615s
I have ST115 in 215/45/17 and unfortunately they're WAY narrower than any other 215 I've seen. I should have gone 225...
mrbell is offline   Reply With Quote
Old 08-10-2005, 03:36 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
.....I'd go with a 235/40.....much better gearing advantage
Old 08-10-2005, 04:34 PM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I have 225-45-17 Falken ST-115 and they are quite a bit narrower than most other 225-45 tires i have seen. However some of the other Azenis models run wider than average. Depends on which Falken Azenis model. Theres like four different Falken Azenis'
FYI I am going 235-40-17 next time. Wider tread AND better gearing.
Samirr76 is offline   Reply With Quote
Old 08-10-2005, 09:29 PM   #5
express_wagon
Member#: 68346
1996 LC
1996 960 Estate
i def know the RT215 ran wide, the stock size ones look just as meaty as the 225/50/16 rs2's i have now.
express_wagon is online now   Reply With Quote
Old 08-11-2005, 07:48 AM   #6
FriedIceCream
Member#: 84154
2005 Mom's Altima
Crusty Silver
thanks for info! i also have to have this wrapped around 17x8 wheels.
Old 08-11-2005, 09:27 AM   #7
Ace009
Member#: 70353
2004 WRX
Go 245/40/17 and the brand wouldn't matter anymore.
Ace009 is offline   Reply With Quote
Old 08-11-2005, 05:21 PM   #8
yarX
Member#: 85335
2004 WRX
i have the st115 in 235/40/17. just wondering what psi they should be, not for track or anything just "spirited" driving on the street. what's everyone else running?
yarX is offline   Reply With Quote
Old 08-11-2005, 05:34 PM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...start at 37F/35R....add a pound or 2 at a time, to both ends, until they are obviously too hard....and then back off 2-3psi
....usually 40-41F/37-38R works great.
Old 08-12-2005, 09:03 AM   #10
subieworx
Member#: 47769
The ZE512's run extremely narrow.
subieworx is offline   Reply With Quote
Old 08-17-2005, 10:22 AM   #11
Drift Monkey
Member#: 41227
2005 Legacy 2.5GT
Garnet Red Pearl
Um...like I said (his friend) don't get the ST115s. I'm telling you, get 245/40/17s ST115s. It's the closest to stock ratio as well....235 is such an odd size..
Drift Monkey is offline   Reply With Quote
Old 08-17-2005, 05:30 PM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....IF......if you have a wide enough wheel.....and 8" wheel is gonna be the narrowest wheel that you could think of using for the 245/40
Car running warmer than usual Poekin Mid Atlantic Impreza Club -- MAIC 7 05-14-2010 12:37 PM
Do Falken 452's run wide? FCPremixx Tire & Wheel 1 03-10-2009 09:36 AM
LOOKING TO BUY VF39 STI Turbo Or other bigger turbos and Bigger than STock Top Mount alieus RMIC Private Classifieds 2 08-03-2007 02:17 AM
only 70w speakers...will bigger than 18gauge REALLY do anything? IllNastyImpreza Car Audio, Video & Security 6 04-10-2007 11:29 PM
Car is running 5degC hotter than usual... Speedwagon Legacy Forum 6 04-01-2006 12:23 AM
Message Board Statistics All times are GMT -4. The time now is 09:52 AM.
