Old 08-10-2005, 07:48 PM   #1
gpfan
Member#: 72702
WR Blue
Default So I put a boost gauge in and to my suprise, I'm running only 7psi
I'm running 7 PSI !!!!!!!!!!!!!!!!!!!!!!!!!
the car has never felt any different since i have owned it but ive only had it for a year!
i really am not a wrx expert so i need some help on where to start looking for my prob!
the car is 02 WRX w/ ZERO mods!
the boost guage is a VDO Vision series in cluster bezel autometer pod
hose is 3/16 vac tapped @ BOV Hose.
7.5 PSI registered on 3-4th gear pulls
7 psi in 1st & 2nd
No boost taper in high RPM.... Holds said boost until redline
thanks for your technical expertise!
-scott
gpfan is offline   Reply With Quote
Old 08-10-2005, 07:52 PM   #2
DrtJnky
Member#: 78652
2005 WRX Wagon
WR Blue
Were is the gauge hooked up? Who's gauge is it? How are you performing your boost check, what gear, what RPM?
DrtJnky is offline   Reply With Quote
Old 08-10-2005, 07:57 PM   #3
gpfan
Member#: 72702
WR Blue
updated information, sorry for lack there of
Old 08-10-2005, 08:00 PM   #4
hondaeater69
Member#: 60324
take the hoses that come off the WG and turbo compressor outlet and switch them. Report back.
Old 08-10-2005, 08:48 PM   #5
gpfan
Member#: 72702
WR Blue
nada....
same as above mentioned
Old 08-10-2005, 08:51 PM   #6
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
The hose that comes of the wastegate actuator and the turbo, can you feel a little bump in one of those hoses like it has something hard stuck in it? If you dont then thats why. you need to buy the restrictor pill. If you do have that little bump, then that bump should be on the turbo side and not the actuator side.
darksands is offline   Reply With Quote
Old 08-10-2005, 08:59 PM   #7
gpfan
Member#: 72702
WR Blue
nothing of the sort in my hose!
does anyone have a michro-fiche diagram of the arrangements and a possible PN?
Old 08-10-2005, 09:03 PM   #8
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Old 08-10-2005, 09:04 PM   #9
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Anyone know of an AP will read live boost while unmarried to a car? Maybe you could borrow one and test with it.
waktasz is offline   Reply With Quote
Old 08-10-2005, 09:05 PM   #10
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Old 08-10-2005, 09:05 PM   #11
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
An AP will read boost without it being married to the car. It can also reset the ECU as well!
Old 08-10-2005, 09:11 PM   #12
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
where number does the boost gauge read when the car is off?
distorto is offline   Reply With Quote
Old 08-10-2005, 09:14 PM   #13
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Probibly missing the restrictor pill...
http://forums.nasioc.com/forums/showthread.php?t=682819
Here is a pic...
GLwagon is offline   Reply With Quote
Old 08-10-2005, 09:15 PM   #14
waktasz
Member#: 86356
2015 s1000r
wheelie monster
and idle
Old 08-10-2005, 09:53 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
http://tinypic.com/a0bhhl.jpg
Old 08-10-2005, 10:02 PM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
I bet he bought a used 2002 WRX whose previous owner "reverted back to stock" just prior to selling or trading it in. Maybe we should suggest a look at the wiring harnesses at the ECU to check for evidence that a Unichip or AFC (or whatever) had been previously wired in.
Jon [in CT] is offline   Reply With Quote
Old 08-10-2005, 10:15 PM   #17
WRX-CBR
Member#: 82197
03 WRX
If it is that brass restrictor damn will you be surprised when you hit full boost. I had my car without it and it sucked.
WRX-CBR is offline   Reply With Quote
Old 08-10-2005, 10:29 PM   #18
noggin
Member#: 14823
2002 WRX Wagon
first, see if there are kinks in the plastic tubing going to the boost gauge. I would make sure you are running at the correct vaccum when at idle. Sometimes the connections arent tight either. Are you hearing a hiss when at full boost?
noggin is offline   Reply With Quote
Old 08-10-2005, 11:19 PM   #19
gpfan
Member#: 72702
WR Blue
i know for a fact that the restrictor is not there!
it has std vaccuum tube for all lines in the area (they have been replaced before b/c they are cut traight tube
the car reads 0 psi when off and 18-20 hg/in when idle
i am sure now that is the prob. thanks for your help guys!!!!!!!!!
ill be going to the stealership tommorow
Old 08-11-2005, 10:01 AM   #20
hondaeater69
Member#: 60324
when the AP is unmarried you don't get menu options, the only option you have is to flash a map, or you hold the arrows to get it into sync mode. How can you read live boost with an unmarried AP?
Old 08-11-2005, 11:14 AM   #21
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I said that the AP could read boost without being married to the car. I guess thats is confusing. Let me re-phrase. You can read with the AP without the AP being married to that specific car. The AP needs to be married to a car though.
Old 08-11-2005, 11:18 AM   #22
hondaeater69
Member#: 60324
yes, that is correct, that's what i thought you meant but i just wanted to clairify. it can check DTC's without being married too
Old 08-13-2005, 05:06 PM   #23
xS2k
Member#: 85112
Here is a pic...
Is that where you hook up the boost gauge where the 'factory t-fitting' is at?
xS2k is offline   Reply With Quote
Old 08-13-2005, 06:52 PM   #24
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
I have an extra pill new in the bag.
00Maddog is offline   Reply With Quote
Old 08-13-2005, 06:57 PM   #25
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
No. You tap into the BPV (aka "BOV") vacuum hose with a new T
jblaine is offline   Reply With Quote
Where should i put my 60mm apexi boost gauge in my 2006 wrx akazempoor Interior & Exterior Modification 2 03-24-2008 02:30 AM
so i put an STI gastank in my brighton and left the pump tmeh Normally Aspirated Powertrain 6 10-04-2007 05:41 PM
God I'm so torn, bigscreen tv or stage 4 upgrade to my WRX Wraith Off-Topic 63 08-30-2004 02:01 PM
Where should I put the Boost gauge? agent007kimball Forester Forum 1 06-28-2002 02:59 PM
Got my Joe P and boost gauge in ! WRC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-21-2001 12:58 PM
