Old 08-10-2005, 11:05 PM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Default Eloectronic supercharger...
So whats the deal with electronic superchargers are they even worth your time, or could you slap one on and tune it with a safc2. If this isn't the worst investment ever could you beef up the supercharger with more volts or some thing to control the boost?
Plan on using it on a 98 2.5rs
2.5rsDOHC is offline   Reply With Quote
Old 08-11-2005, 01:04 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
What type are you talking about?? The $80 things that do nothing. Or the big electric units that require extra batteries and what not. Either way your better off with a belt driven supercharger if you go that route
Old 08-11-2005, 01:27 AM   #3
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
I found plans to build my own (http://www.gaprojects.com/supercharg...ric/super2.htm) something I could spend 2 or 3 hundred dollars on. That includes construction materials and a SAFC for little extra power & control. I don't intend on dishing out $5,000 or more on a jakson racing charger kit not including the $1,500
stand alone ecu you would need. No I just want to see what everyone thinks of this experiment, if it works great if not then im stuck with a $150 fan.
Old 08-11-2005, 01:33 AM   #4
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Its up to you to decide if you want to experiment with it. I don't see it creating any boost though. maybe at idle, but above that your probably stuck with $150 fan
Old 08-11-2005, 03:50 AM   #5
Kotir
Member#: 17300
'93 Impreza L Wagon
JDM Ver8 STi swap
These are the only electronic superchargers that accually work
http://www.boosthead.com/home.php
And they aren't cheap $1300+
-Tim
Kotir is offline   Reply With Quote
Old 08-11-2005, 08:20 AM   #6
Tats
Member#: 5692
WTF? YES! I am
better than you!
and they're not "Constant on" only can be used for short bursts like tha Gas.
Tats is offline   Reply With Quote
Old 08-11-2005, 04:00 PM   #7
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
The description says it all, does not require "precision work of any kind." Do you want to be attaching a chinsy piece of non precision hardware to a $20k precision car? There is a reason why turbo and supercharger kits cost what they do. It takes ALOT of precision work to get it right.
blaznc is offline   Reply With Quote
Supercharge or not to supercharge, that is the question. ScoobySean Normally Aspirated with bolt-on Forced Induction Powertrain 14 04-09-2006 12:06 PM
('93-'01) Vortech supercharger wcbjr Impreza Forum 10 06-09-2001 09:14 AM
('93-'01) Rimmer superchargers jgring Impreza Forum 5 06-06-2001 01:51 PM
Eaton Superchargers Any good Supercharging a RS Jimmy Factory 2.0L Turbo Powertrain 15 04-24-2001 06:57 AM
('93-'01) Supercharger for my 2001 RS? tnt_rocks Impreza Forum 0 04-23-2001 02:43 PM
Message Board Statistics All times are GMT -4. The time now is 04:07 PM.
