Welcome to the North American Subaru Impreza Owners Club Monday September 22, 2014
Old 08-11-2005, 10:21 AM   #1
turboed22
Member#: 93364
1998 Impreza RS-T
22 SM
Default My EJ257 Hybrid MY98 RS wont start!!!
Setup:
MY98 RS
New ej257 shortblock
MY98 Heads, Intake, Tranny
WRX Turbo, Intrercooler
Stock fuel system
Turboed for 1.5 years no problems w/ my stock RS block.
So I finished the swap including the timing belt and tried to crank it over. It cranked ovet the first try and ran rough for about 5 seconds the died. So we check the plugs and they were soaked with fuel, then we checked to see if it was getting spark and only the rear two would spark. With this knowledge we tried a new coil, igniter, cam sensor, and new crank sensor. We got spark in all four after this. Still wouldn't start. We checked the compression on the motor after we found a lot of gas in the oil so I changed the oil. The compression was 155 across the board. We let the plugs and cylinder wall dry out and still wouldnt start. It is still running extremely rich when we are cranking it over, if we pinch the fuel supply line it will sputter and try to start but still wont fully turn over. All of the timing marks do line up. Tried different plugs along wiht different gapping, still no luck. What are your guys thoughts?
Thanks
turboed22 is offline   Reply With Quote
Old 08-11-2005, 05:01 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Check the MAf. It may be unplugged or installed backwards.
Tim Sanderson is offline   Reply With Quote
HR: my car got flooded and wont start. JS Mid Atlantic Impreza Club -- MAIC 23 09-18-2006 08:13 PM
My 2.5 hybrid motor wont start! Help codered Factory 2.0L Turbo Powertrain 86 09-09-2005 05:51 PM
another 2.5 hybrid that wont start rjrutzky Factory 2.0L Turbo Powertrain 14 07-06-2005 12:54 AM
My 2.5 hybrid motor wont start! Help ebeck Subaru Conversions 3 06-05-2005 07:51 PM
my Brilliant Red MY98 RS and Skyline Drive in VA AJ711 Member's Car Gallery 14 11-30-2001 08:19 PM
