Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-15-2001, 03:31 AM   #1
bratmantlz
Member#: 3231
88 626 Turbo
white
Default timing belt and installation?
time to do my timing belt and also get it put in. how much for the belt
1
how much for installation do you think?
2
thanks
Brat
bratmantlz is offline   Reply With Quote
Old 08-15-2001, 10:45 AM   #2
DaveK
Member#: 2338
1988 323 GTX
black
Just a guess here...but my Eclipse was $50 in parts, $500 in labor
DaveK is offline   Reply With Quote
Old 08-15-2001, 11:02 AM   #3
bratmantlz
Member#: 3231
88 626 Turbo
white
jeezuz $500 in labor i hope suby sports can do it for wayyy less than that damn! i heard once aboot $120 or so. and dont know about the installation.... funk i need this done asap......
Brat
Old 08-15-2001, 11:09 AM   #4
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
but in the eclipse you practiaclly have to pull the motor. It's definietly not an easy job. On Subaru's you have full access to the timing belt once you remove the radiator fans, accessory belts, crank pulley, a/c belt tensionor and the timing belt covers.
Strepto is offline   Reply With Quote
Old 08-15-2001, 04:56 PM   #5
phast
Member#: 7957
I just got a coupon in the mail from John Marzolf for a timing belt job. It was good for the labor and t-belt. I know on my Galant, you had to buy a new hydraulic tensioner and balance shaft belts were also a good idea. Dunno what else is under the cover on the flat motors. They will check the water pump and replace it for the cost of the parts if need be.
The coupon price was $250 for the whole shebang. I could hook you up as I wont be needing a new t-belt for about another 98,000 miles and some change. I'll have to look at it again and make sure it doesnt say my name on it or something.
They are in Pueblo, but much better than Heuberger IMHO.
-jay
phast is offline   Reply With Quote
Old 08-15-2001, 05:21 PM   #6
bratmantlz
Member#: 3231
88 626 Turbo
white
damn $250 eh. sure i can save up for it. that covers everything eh? i need the belt and the installation. does it have directions for were to go to get it done i am not a puebloian.
Brat
Old 08-16-2001, 10:41 AM   #7
phast
Member#: 7957
They got some directions on their website.
http://www.john-marzolf.subaru.com
Call em and see what all they will do.
-jay
Old 08-16-2001, 01:01 PM   #8
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
BRAT! Just call Braden and ASK, silly!
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 01-30-2002, 04:53 AM   #9
matt7102
Member#: 12051
1999 Impreza
That Silver color
Exclamation Suggestion....
Parts are cheap....I suggest you consider replacing the waterpump and front crank seal. If the area around your cam seals are showing ANY oily dampness or dust collection, do them as well. Be smart- if you are going to PAY for the surgery, do everything you can to keep 'em from opening her up again before the next belt change. If a seal fails AFTER the new belts are installed, you'll be buying another set of belts AND paying for poor foresight...
Subaruparts.com prices:
W/P=50.36
W/P gasket=1.85
W/P seal(for t-stat)=2.15
Crank seal=3.68
Camseals=38.00 (I think the $38 is right...)
Man, I wish I still had my shop and tools. Subies are the easiest cars to do routine maintenance on....
Matt
matt7102 is offline   Reply With Quote
Old 01-31-2002, 12:04 AM   #10
bratmantlz
Member#: 3231
88 626 Turbo
white
woa... this is a olllld post eh.. i just got back from some snow driftin in the subbie.
Old 01-31-2002, 12:16 PM   #11
eastbaysubaru
Member#: 4110
04 FXT
Question
Wow, this is an old post. My only question is why? It's good info though, and I think I'll probably be doing this soon, so knowing to check the W/P is good info. Thanks. But WHY?
-Brian
eastbaysubaru is offline   Reply With Quote
Old 01-31-2002, 03:52 PM   #12
Tangmere
Member#: 572
Brian,
I think the logic behind it is that if and when you end up doing your timing belt you'll have to take off 99% of all this stuff again to do the water pump. Make sense?
Mark
Tangmere is offline   Reply With Quote
Old 01-31-2002, 08:16 PM   #13
eastbaysubaru
Member#: 4110
04 FXT
No ***** Mark , I guess the question came off wrong. Why is the post being revived after all this time? The logic about the W/P was explained in the previous post.
-Brian
Old 01-31-2002, 08:52 PM   #14
bratmantlz
Member#: 3231
88 626 Turbo
white
no bc my water pump is good and my timing belt got done a while ago. i also wondered were this post popped back up from for..
Fixing Timing belt and or Accessory belt squeak Gel Mibson Newbies & FAQs 0 04-06-2010 08:43 PM
STi FUEL LINES TIMING BELT AND COVERS AND ENGINE WIRING HARNESS. OTHER ITEMS TOO! silvershadow Engine/Power/Exhaust 0 07-13-2009 12:53 PM
Removing Timing Belt For Install at 80k, Would You Replace? williaty Service & Maintenance 6 02-19-2009 11:16 AM
Timing belt and Power steering belt? Kopid Newbies & FAQs 15 02-06-2007 02:08 AM
96 impreza 2.2L timing belt and water pump installation guide sjtangb21 Normally Aspirated Powertrain 0 03-25-2005 09:36 PM
