Old 08-11-2005, 02:11 PM   #1
03WREX
Member#: 38932
2003 WRX
WRB - Cobb Stg2
Default Cobb Anti-theft map for compression test?
I want to do a compression check on my motor before upgrading to stage 2.5. I've read that I want to avoid having fuel being sprayed while I do the compression check so I wanted to know how exactly does the anti-theft map will work. From what I've read it sets the rev limiter to below idle which basically causes fuel cut immediately and won't let the car start. Can anyone let me know if this eliminates fuel from being sprayed or should I just try to find the fuel pump fuse?
For future Cobb stage 2.5 reference, I've read that it's a good idea to prime the turbo with oil before I start it for the first time. I could use the anti-theft map to crank the motor to prevent a dry startup, correct?
Thanks for any help.
03WREX is offline   Reply With Quote
Old 08-11-2005, 04:29 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
pull the fuse to the fuel pump and start the car and let it die
Old 08-11-2005, 04:46 PM   #3
Rick Schu
Member#: 34661
I don't think fuel will impact the readings, but its not exactly the best thing safety wise. There is a green connector behind the passenger footwell on the right. This is the fuel pump relay. Disconnect this. Start car until dies. Then try starting it again for 5 seconds.
Rick Schu is offline   Reply With Quote
anti-theft map sleeperrex AccessPort 3 12-24-2008 12:22 PM
product inquiry: anti-theft system for my car Disoriental Off-Topic 10 10-17-2006 06:48 AM
In light of recent car crime, JGard has developed an anti-theft device for his car. SkirtBoy Off-Topic 31 07-25-2006 12:09 PM
Flashing Anti-theft map question chlnOrSlpn? AccessPort 2 03-17-2006 02:04 AM
Anti theft map on UTEC Fusionpnoy Engine Management & Tuning 11 04-29-2005 09:26 AM
