Welcome to the North American Subaru Impreza Owners Club Thursday December 18, 2014
Old 08-11-2005, 04:16 PM   #1
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Default Which springs and were to buy?
Hello, looking for spring for 2000 Legacy GT Sedan. These are the req, please tell me what options I have.
*Have to fit on stock struts for now, struts next summer.
*Proly 1inch drop as I will be driving car in the winter.
*Comfortable, safe, reliable ride.
*I will be getting 17inch rims, will 1 inch drop be enough for the rims to look good?
Expert, please give your advice.
Flexy is offline   Reply With Quote
Old 08-11-2005, 04:21 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
ION Performance springs are probably your best bet. Theres several threads about them if you'll use the search function.
* OK.
* Yeah, around there.
* Yep.
* Yep.
fibuz is offline   Reply With Quote
Old 08-11-2005, 04:26 PM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
^ ditto ^
there's also H&R. people seem to like them as well.
iamrazor is offline   Reply With Quote
Old 08-11-2005, 04:34 PM   #4
Flexy
Member#: 34028
2000 Legacy GT
Titanium
I was reading somewhere that I will need top hats from Impreza or something liek that, not sure for what springs. I just want to clarify, that I need springs that don't require no other parts to install them.
Thanks.
Old 08-11-2005, 04:37 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
You do not need other top hats for ION Performance springs...or most spring sets for that matter. Things only get confusing when trying to make Impreza suspension pieces work on a Legacy.
The ION Performance springs and H&R springs are specifically made for your car.
fibuz
Old 08-11-2005, 04:38 PM   #6
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Thanks for a fast reply. How easy is the install? Is there diy online somwhere?
Old 08-11-2005, 04:47 PM   #7
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Its a pretty simple process if you've got the right tools...
specifically a socket set, good jack stands/lift, spring compressor(rentable at auto parts stores).
Should be some documents out there, maybe on scoobymods.com, but basically jack the car up, secure it, remove wheels, 3 unbolts on top, LOOSEN but not remove the bolt that holds the top hat on, remove 2 bottom bolts, take off entire structure, remove top hat, remove spring, compress new spring, put on strut, and back track. Could take a 4-5 hours your first time, but is not very difficult.
fibuz
edit: remember, these are very rough instructions...you should find a DIY to base your install off, and just take my writeup as something to estimate effort/time.
Old 08-11-2005, 07:44 PM   #8
MitchGT
Member#: 73684
2012 4Runner
fibuz
somebody, i believe it was Tora, said that you need spring perches for the H & R setup.
MitchGT is offline   Reply With Quote
Old 08-12-2005, 08:57 AM   #9
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Do a search for my thread on the iON springs. IMO, they're exactly what you're looking for.
Jonathan
Teh Legacy is offline   Reply With Quote
Which EGT Probe and Gauge to buy? desiwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-15-2002 02:51 AM
turbo timers- which one and where to buy? plas Newbies & FAQs 4 04-23-2002 11:24 PM
Were to buy a Helmet? and fast! White Knight Tri-State Area Forum 4 06-21-2001 05:29 PM
Which TURBO TIMER and where to buy in Houston? metoo Texas Impreza Club Forum -- TXIC 7 03-20-2001 11:18 AM
re: turbo testimonials ..... which exhaust and clutch to buy for exhaust? shukes24 General Forum Archive 12 12-07-2000 08:50 PM
