Old 02-09-2007, 03:34 AM   #51
estefania_rous
Member#: 139971
Kenwood makes the best electronic.
estefania_rous is offline   Reply With Quote
Old 02-09-2007, 05:25 PM   #52
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I believe that JL has an impreza stealthbox now that you can add to the stealthbox section...
-- Dave
AcquaCow is offline   Reply With Quote
Old 02-09-2007, 06:21 PM   #53
BryanH
Member#: 993
Dave...why do you do this?
BryanH is offline   Reply With Quote
Old 02-09-2007, 10:47 PM   #54
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Because I love you...
.....man.
-- Dave
Old 02-10-2007, 12:10 PM   #55
JUSTA4CYL
Member#: 139737
How do I hook an amp/sub up to my stock radio? Can I run a sub off the rear channels of my head unit?
Yes, there are two common ways to do this. Some amplifiers come with “speaker level inputs” where you run the wiring that was going from your stock radio to your speakers into the amplifier. Another method, in case your amplifier doesn’t have speaker level inputs, is to buy a Line-Out Converter (or LOC for short). An LOC is a whole lot like an extra speaker level input module; you run the existing speaker wires from your stock radio to it, and then you connect the LOC to the amp using RCA cables. Both methods get the signal to the amplifier, and then you just need to run new wires from the amplifier to the speakers/subwoofer.
New to this board, all the info you have supplied is awsome. I have a sub box, amp, and the line out converter. Can you tell me for an 06 STI, were I can find the rear speaker wires to tap into for the LOC, and what color's the wires would be. Greatly appreciated.
JUSTA4CYL is offline   Reply With Quote
Old 02-10-2007, 12:26 PM   #56
Daishi00
Member#: 78952
2005 WRX
CGM
^^^^make a post in the normal portion of the forum please. The Manifesto is just to show info...not discuss it
Daishi00 is offline   Reply With Quote
Old 02-10-2007, 10:47 PM   #57
JUSTA4CYL
Member#: 139737
I tried, and so far no feedback. I tried a search, and cant find the info as well!!!!! Was hoping to get some kind of info to steer me in the right direction.
Old 04-26-2007, 03:54 AM   #58
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
Cool!!!
EBWRC#1 is offline   Reply With Quote
Old 06-23-2007, 06:33 PM   #59
blueduds
Member#: 152159
05 subaru
rainbow
One question, how to you pop off the door panals to get to the door speekers? Also do you have to unscrew your shift nob to get to your radio? Thanks
blueduds is offline   Reply With Quote
Old 07-16-2007, 05:42 PM   #60
khajja
Member#: 125216
i've always gone w/ kenwood and never had problems.
khajja is offline   Reply With Quote
Old 07-21-2007, 02:51 AM   #61
Xalt
Member#: 154565
So I have been doing countless hours of research as to whether or not the Alpine SPR-17C 6 1/2" will fit all four speaker locations on my 1993 Impreza. when I put in my car into Crutchfield.com, it had not listed this as an option but the 5 1/4" instead. The SPS-17C2 was the other option I had as a backup which Crutchfield says will fit at 6 1/2". If anyone has any clues as to this issue or suggestions of a better set of speakers it would be greatly appreciated because I'm starting to blow out the stock speakers .
Xalt is offline   Reply With Quote
Old 07-21-2007, 09:54 AM   #62
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
In the Cabin Speaker Buyer’s Guide and FAQ there is an installation guide that should spell it out. If not, you should have also read that this is a thread for general questions, so please post any further questions in a new post (but again the answer is where I just told you which is "yes, but you need a mounting ring").
offset
offset is offline   Reply With Quote
Old 09-16-2007, 06:49 PM   #63
XpandaraceX
Member#: 159390
Hey guys..new to the forum. I can't post anything yet because I'm that new. But I have a 93 impreza sport wgn. I am trying to install a new audio system, but to no avail. Could you point me in the right direction to find some online help.
XpandaraceX is offline   Reply With Quote
Old 09-17-2007, 08:57 AM   #64
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
It should all be in the thread you just replied to, along with maybe a little searching since you have an older ride.
offset
Old 10-01-2007, 09:50 AM   #65
JuSTin05Impreza
Member#: 160587
i took out the sub in my car because i didn't like it banging around
JuSTin05Impreza is offline   Reply With Quote
Old 10-02-2007, 10:16 PM   #66
Daishi00
Member#: 78952
2005 WRX
CGM
And you felt the need to post that comment in a FAQ exactly why?
Old 10-04-2007, 10:20 PM   #67
st1llet0
Member#: 157699
In reference to point #33, the fuse for the dome lamp is in the fusebox under the hood. IIRC it's a 20 amp fuse and labeled "lighting" in the manual. The radio is slot 17 under the dash. I think it's 25 or 30 amp. I'll check my manual after I get out of work. This is on my '93 impreza L btw.
st1llet0 is offline   Reply With Quote
Old 11-20-2007, 07:21 AM   #68
Sabba
Member#: 68951
2008 WRX
World Rally Blue
Now that you've selected your gear, if you're driving an '08 Imprezza [WRX anyway], take a moment and swing by: http://forums.nasioc.com/forums/show....php?t=1390628
Sabba is offline   Reply With Quote
Old 01-02-2008, 08:54 PM   #69
Marker008
Member#: 168072
2008 WRX 5-door
Does anyone have detailed information about the 08 wrx navigation unit? Otherwise, really informative links. Thanks!
Marker008 is offline   Reply With Quote
Old 02-21-2008, 08:43 AM   #70
vemplord
Member#: 172379
Thx for the link, it was very helfull.
vemplord is offline   Reply With Quote
Old 04-10-2008, 05:54 PM   #71
ROXY6997
Member#: 177131
Default Selling Subaru Stereo
HI...I need some feedback, I got a NAV system installed on my 2008 Impreza WRX- SOOOOOO, I am trying to seel my stock stereo~ I had the Clarion 6 disk (the upgraded one) in my car. It is brand new, it was taken out the day after I bought the car. So if anyone can help me...I am trying to determine how much to sell it for and if I need a security code for the new buyer or not. Sorry, I am not very tech saavy.
Thanks!!!
ROXY6997 is offline   Reply With Quote
Old 04-11-2008, 02:12 PM   #72
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Thanks!!!
I can help you get started on by being more tech savy by letting you know that first you need to start your own new post instead of interjecting unrelated questions in another person's thread and second you should learn to use the search functionality of this site to see what they have sold for in the past to get an idea.
offset
Old 04-18-2008, 12:32 AM   #73
ROXY6997
Member#: 177131
Default WOW friendly people on here...
OK...my mistake
Old 04-18-2008, 12:47 AM   #74
ROXY6997
Member#: 177131
Found the classified section...I will repost there
Old 04-19-2008, 10:19 AM   #75
christian.rogers
Member#: 177727
1997 outback 2.5i T
white / gray
Hello friends NASIOC, I from Chile.
I have a Outback turbo of all 97 original, including radio, in Ebay buying a radio 6 cd WRX and I want to install in my subaru, it is very difficult.
Here on its website that it is very good and complete what I have not managed to find specific to my question, now thank you very much for your help.
Best Regards
Christian Rogers
christian.rogers is offline   Reply With Quote
FS: Car Audio Stuff and WRB Wings West Body Kit dman918 Private 'For Sale' Classifieds 13 05-01-2005 04:57 PM
FS: IL: Tons of car audio/video and electronics up for grabs ScoobyInc Private 'For Sale' Classifieds 3 01-27-2005 11:05 AM
FS: Concept Audio Car audio Amp and subs WRXShawn Canada Region Forum 2 08-26-2004 11:55 AM
PG car audio amps and xover jeffg Private 'For Sale' Classifieds 2 08-05-2003 11:23 AM
Car Audio 101 and beyond? UncleMeat Car Audio, Video & Security 2 04-28-2003 12:16 AM
