Old 08-12-2005, 01:24 PM   #1
03GLHWRX
Member#: 30369
03 WRX SW
Default Correct Mounting of Michelin PS2s ???
I picked up a set of Michelin Pilot Sport PS2 tires yesterday. They were mounted on my loose wheels (not on car yet). All are identical but not R/L mirror images of each other as I think they should be. They've all been mounted with the heavy tread blocks to the inside (OK I think), but the curvature of the rain evacuation groove is (assuming you follow gatorback thinking) correct on one side of the car but incorrect for the other side of the car. It looks to me as if there should be two different tire part numbers - one for the RH and one for the LH. I don't see anything on the sidewall that refers to directionality or RH/LH. Is this the way its supposed to be? Also, did they do the right thing in mounting the larger tread blocks to the inside?
Thanks,
Mark
notice that in this stack of four wheels & tires all of the wheels are facing the same direction and all of the tires are the same.
03GLHWRX is offline   Reply With Quote
Old 08-12-2005, 01:59 PM   #2
fliz
Member#: 30342
The PS-2 isn't a directional tire, so it doesn't matter which way the horizontal grooves angle.
However, according to the tirerack pic (and common sense), the wider tread block should be mounted to the outside.
If you look at the sidewall, it should be marked "outside" and "inside".
fliz is offline   Reply With Quote
Old 08-13-2005, 10:38 AM   #3
CGM_WRX
Member#: 66280
2005 WRX Sedan
Crystal Gray Metalic
It is marked "outside", they need to be mounted just as shown in the picture.
CGM_WRX is offline   Reply With Quote
Old 08-13-2005, 12:05 PM   #4
vz64
Member#: 20957
2005 STi
CGM
03GLHWRX, yes, the wider/heavier tread blocks should face outside - you can't go wrong because it says on the tire "outside". Your observation re concave vs convex inner groove is true - there is a difference in the left and right groove pattern (I had the same question when I got my PS2s), but, according to Michelin rep I talked over the phone, it does not affect either wet or dry performance. My winter tires Hankook W300 have similar asymmetrical pattern of grooves from left to right. I believe there are some other tire models designed in the same way.
vz64 is offline   Reply With Quote
Old 08-15-2005, 12:44 PM   #5
03GLHWRX
Member#: 30369
03 WRX SW
Thanks guys. I'll be taking them back for a remounting to get the "outside" to the outside, and I won't be worried about gatorbackness.
Mark
socal(san diego): brand new never mounted 225/40/18 michelin ps2 riceking3 Wheels/Tires 12 06-11-2007 12:34 AM
FS: Set of 5 17" OZ Prodrive P1 with Michelin PS2 Tires C Dust Wheels/Tires 4 11-08-2006 12:29 AM
What does everyone think of the Michelin PS2 tires?? STI1981 Tire & Wheel 4 09-15-2005 03:51 PM
18 SSR Comps w/ Michelin PS2 (STi offset) ferdinand Private 'For Sale' Classifieds 36 06-05-2004 01:58 PM
Michelin PS2 and lots of camber mtb_dude Tire & Wheel 5 06-03-2004 09:49 PM
