Old 08-12-2005, 03:30 PM   #1
hrlydavison
Member#: 91723
Default I think I may have got the wrong wheels
I have a 2005 saab 9-2x linear.
I bought some 17x7 ADR Phantom wheels with 42mm offset off of ebay.
I went from the WRX fitment instead of the Imprezza fitment
Sooo...
Am I screwed or what? The problem being I think the wheels are made for lug bolts and I have lug nuts with bolts attached to the hub. When I drop the lug nuts inside the wheels holes their is no room for a lug wrench to get a hold of it to tighten it.
Can I get a longer lug nut that will fit(that extends ou farhter than the face of the wheel)with room left to get the wrench on?
Anyone know a good place to get these or a part# to help me out?
Thanks from a Newbie
hrlydavison is offline   Reply With Quote
Old 08-12-2005, 04:14 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
'Tuner' nuts... McGard... Gorilla... M12x1.25
WRX is the same wheel fitment as any other Impreza (barring 05 STi)... +42 is a poor choice of offset though it has nothing to do with your lug fitment problem
UkNuck is offline   Reply With Quote
Old 08-12-2005, 05:32 PM   #3
hrlydavison
Member#: 91723
my bad...I have them in +48 offset and going to run 225/45's on them
So 1.25 will be long enough for the tuner nuts? I did some searching on the Summitt site and saw the length all the way up to 1.75.
I just want to be sure...im newbie nervous
Old 08-12-2005, 05:39 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
1.25 is the thread pitch not the length
Old 08-12-2005, 05:56 PM   #5
hrlydavison
Member#: 91723
see I am a newbie...
So these are not any longer, just thinner walled so you can get a wrench on them?
As I said my stock nuts almost touch the walls of the holes of the new wheels.
Sorry if this is obvious to a lot of you but Im here to learn and I learn by the wisdom and expierence of others. No patronizing intended.
So to confirm again 12x1.25 tuner lugs are all I need?
Old 08-12-2005, 06:48 PM   #6
SeattleWRX
Member#: 10350
02 WRX Sedan
Yes. You need tuner lugs. Not just for the size, but the seat of the lugs.
12x1.25 tuner lugs. Subydude carries a lot of options, or I'm sure if you go to your local tire shop, they have them also.
SeattleWRX is offline   Reply With Quote
Old 08-12-2005, 10:49 PM   #7
hrlydavison
Member#: 91723
All right then Im ordering them
Thanks a lot for schooling me
I think I may have possibly just tested the best rifle optic ever. brucelee Off-Topic 40 07-31-2008 09:23 PM
I may have found the source of my leak. Tell me what you think! ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-07-2007 03:35 PM
Think I may have the flu, should I still get a shot? Jonathan_Yi Off-Topic 10 11-10-2003 03:21 PM
Pray for me, I think I may have won the bidding on a Garrett 500HP turbo..... GregUnd Texas Impreza Club Forum -- TXIC 4 04-24-2003 11:16 AM
I think I got the wrong Pipe YeeHa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-26-2002 11:03 PM
