Old 09-15-2005, 01:25 PM   #26
dbarnblatt
Member#: 7993
1997 SVX LSi
Red
So...
215/45-17 on a 7x17 rim... WRX
225/45-17 on a 7.5x17 rim... STi '01-'04 JDM and USA
225/45-17 on a 8x17 rim... STi '05-'06 USA
235/45-17 on a 8x17 rim... STi '05-'06 JDM
235/45-17 on a 8x17 rim... EVO
This is the common thinking on rim width and tire width. These are all Factory spec.
dbarnblatt is offline   Reply With Quote
Old 09-15-2005, 01:30 PM   #27
BoostinEJ20
Member#: 73710
in the near future ill be running 17X8 torques, with Falken RT-615's 225/45/17...that will not look stretched right?
BoostinEJ20 is offline   Reply With Quote
Old 09-15-2005, 01:47 PM   #28
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
dbarnblatt, that list is spot on. If all you're ever going to run is 225/45-17, there is no reason to get 17x8 wheels vs 17x7.5, unless you like the stretched look.
The '05-06 STI (with 8" wheels) has the unusually wide RE070, which is 235mm wide, despite the number printed on the sidewall, so that is a bit of an exception.
Jon Bogert is offline   Reply With Quote
Old 09-15-2005, 02:30 PM   #29
BoostinEJ20
Member#: 73710
so i think i might switch over to re070's but does anyone know a good place with good prices on these tires? thanks
Old 09-15-2005, 02:39 PM   #30
subieworx
Member#: 47769
The 225 won't look stretched on an 8" rim depending on the tire.
Here is a pick of my old setup. 8" rims 225 45 17 ES100's. Straight sidewalls, no streching. I gaurantee my 225 45 17 ST215's would not looked stretched on an 8" wheel.
subieworx is offline   Reply With Quote
Old 09-17-2005, 02:08 PM   #31
burnside
Member#: 43404
2002 WRX Wagon
Oh, I'll play:
-wagon w/ rolled fenders
-Prodrive springs
-about -1.5 F/R
-Falken (FK451)
-17x7.5, ET48
I need help deciding between 235/40 and 235/45. I think I may bend a rim with the short sidewall of the 235/40 and the car is street-bound except very infrequent HPDE or autox.
Don't mean to hijack--only to supplement.
burnside is offline   Reply With Quote
Old 09-17-2005, 02:23 PM   #32
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
Question
Originally Posted by Valhakar
Waggon or Sedan?
Suspension drop and geometry?
Alignment specs?
Brand of tire?
Size of wheel its being mounted on?
All of these are part of the "simple" answer you want.
With a 17x8 wheel, What kind of setup would facilitate the widest possible tire?
And what are the side effects of going with the widest possible tire/wheel? (possibly 8.5 to 9 in. wheels also).
KingOfSiam is offline   Reply With Quote
Old 09-17-2005, 04:22 PM   #33
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
hmm i have 225s on a 7" wide wheel
svek is offline   Reply With Quote
Old 09-17-2005, 09:01 PM   #34
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by Jon Bogert
Hmm. Those are Hankooks. The tires in the first pic are Hankooks.
Maybe Hankook's marketing plan is putting big numbers on narrow tires???
.....my 235/40 hankooks were a bit wider than the 225/45 falken 215's that they replaced....
....and the rpf-1's in 17x8 would be a great choice for a wrx
Old 09-17-2005, 09:46 PM   #35
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
Dude! If you can get the 8" wide rims with 235's (either 40 or 45's) do it! You can way tell the difference between 7.5 and 8 when using the wider tires. Way more grip, way more stable. I've been running RA1's in 235/40-17's on 8" wide torques at the track (on my wagon) and it ownes! Some of the time I leave the RA1/Torque combo on and run in the street for a few weeks if I get lazy. Then when I switch back to my street tires which are 225/45-17 on 7.5" wide torques the car just feel squirley for a few days until I get use to driving the narrower tires and rims again. I couldn't believe the difference. The one thing I can't tell is the difference in the weight.
Lowball is offline   Reply With Quote
Old 09-18-2005, 01:59 AM   #36
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Rota attacks <not useing these rims i do still own the tires.
17 x 7.5
5x100 & 5x114.3
toyo t1s
225/45/17
No stretching here.
Im planning on fitting the toyos to some 17, 8 rims which ive been told there will be some stretching im also dropped on S-techs. im giving some serious thouts to just going 17, 7.5 rims.
dingobite is offline   Reply With Quote
Do I really NEED an STi? Padge Mid Atlantic Impreza Club -- MAIC 23 03-29-2009 02:09 PM
Do I really need an O2 socket for my uppipe? WRXislander Newbies & FAQs 27 09-28-2007 12:40 AM
Do I really need an EGT and oil pressure gauge? hella_sti Interior & Exterior Modification 12 04-09-2007 10:18 PM
car just lowered, do i really need an alignment? BlowDro Brakes, Steering & Suspension 20 09-19-2006 09:21 PM
Changing springs... do i really need an impact wrench? leocookie Brakes, Steering & Suspension 3 09-16-2004 10:51 PM
