Old 08-13-2005, 03:08 PM   #1
BoardRider
Member#: 32059
1997 Legacy GT sedan
CBR600, WR400, Z50R
Unhappy Oil Leak...! (97 Legacy GT) - See picture...
My Legacy GT has 114k miles and I have never had an oil leak or a head gasket problem (yet???!). Just this week I noticed a little spot of oil where I park my car in the driveway, so I looked under the car today. This is what I saw:
If you can't see the image, try THIS LINK. (I always have problems with adding images to my posts!)
I read a lot about head gasket problems on here last year and have forgotten a lot of it, so I'm going to start doing some research now, but in the meanwhile, will someone who has experience with this oil leak please advise?!
I just bought supplies so I could change my oil today too, but I may hold off if I will need to have work done that will merit draining my oil anyway...
Thanks!!!
BoardRider is offline   Reply With Quote
Old 08-13-2005, 03:14 PM   #2
Dobes
Member#: 164
2008 Exige S240
Looks like a front main crank seal. Plan on doing a timing belt too since the existing one may be coated with oil. And maybe a water pump too while the front is apart.
IIRC, when I had my front main replaced on my RS (same motor) it was about $250.
JD
Dobes is offline   Reply With Quote
Old 08-13-2005, 03:45 PM   #3
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Originally Posted by Dobes
...Plan on doing a timing belt too since the existing one may be coated with oil....
I had the timing belt replaced at 85k miles when I bought the car. And I don't think there's any oil on the belt, but it may be a good idea to get it changed if they have to go in there anyway. I'm not sure what gets taken apart...
I'm going to have to take it to a mechanic since I don't know much about this area and don't have many tools...
Old 08-13-2005, 08:45 PM   #4
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I've never known a Subaru front main crank seal to leak unless the engine was run without oil and then refilled, even then very little leak. Lot's of rear main leaks due to the rear cover plate, but not the front main.
I'd bet that it's the "O' ring/plate seal on the oil pump. It's about the right mileage and age so that's what I'd check out. Will need to pull the front and rear timing belt covers, pull the timing belt off and do some investigating. But, that's where I'd start. Might as well replace the water pump while you've got it pulled down unless you did that when you changed out your timing belt at 100K
OTOH - it could be a cam seal starting to leak too...but, again, you've got to pull the TB covers to see. My money is on it being an oil pump leak.
Dale
Subietonic is offline   Reply With Quote
Old 08-14-2005, 11:31 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Dale
Dale, I seldom disagree with anything you say, but I have yet to have Legacy that didnt have a leaking front main seal. I replaced the one on the BF twice and the BG once. Subaru actually redesigned the seals because the old design failed a LOT. The older seals are black and the newer ones brown. Havent had a brown one leak yet but I havent put a ton of miles on them yet either.
I agree do the belt(if anywhere near time), oil pump o-ring, bolt re-tighten and re-seat(clean the port of any slag if it hasnt been done,) and the cam seals too. The cam seals seem to last a little longer than the front main seal in my experience.
ss
subysouth is offline   Reply With Quote
Old 08-15-2005, 12:55 AM   #6
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
SS - I defer to your experience then - in 31 years of Subes, I've never had any problems with the front main seal. Have had a block halve separation issue once that caused a leak in the vicinity of the front main, but fortunately never the main itself. Knock on aluminum...
Dale
Old 08-15-2005, 02:49 AM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Dale
I'll defer next time.
Just saw you have a BP GT 5-speed(sweet) and are a mod over on LegGT, congrats. I've got the Bilstein GT setup for the BP, just gotta source the car now.
ss
Sourcing an oil leak in 97 Outback GAMO Service & Maintenance 2 02-04-2007 11:14 AM
oil leak in 97 1.8L bondkiller Normally Aspirated Powertrain 7 08-03-2006 11:31 AM
Oil leak question for 1999 Legacy Limited Edition ericb49 Legacy Forum 4 09-23-2003 10:24 AM
97 OBS Oil Leak llonman Technical Forum Archive 5 08-02-2000 10:30 AM
