Old 08-13-2005, 03:10 PM   #1
FujiHeavyFreak
Member#: 5405
Unhappy Oil on spark plug boots (even after new valve cover gaskets)
Hi,
Does anyone know where oil on my spark plug boots could be coming from? I have new valve cover gaskets (including gaskets under screws) but I'm still getting sputtering & oil at spark plug boot.
Any help appreciated
99 2.2 Impreza L 5-speed w/ 120k
FujiHeavyFreak is offline   Reply With Quote
Old 08-13-2005, 04:10 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I'd check the gaskets around the plug holes on the valve cover and make sure one didn't get pinched by the cover as it was put on. There really is nowhere else for oil to come from, save from the cylinder and up past the plugs. Is a plug loose and/or are the plugs soaked with oil at the business end?
Brian
Old 08-14-2005, 12:30 PM   #3
FujiHeavyFreak
Member#: 5405
Dangit, I didn't know I had to replace those too! They never gave me those but I know which ones those are, the big round plastic ones, right? I'll pick those up next business day. (confirmed here on last post by hondaslayer: http://forums.nasioc.com/forums/show...ht=valve+cover )
Also, I noticed that on those spark plug gaskets that 3 were the same shape but the passenger side one closest to the firewall is shaped differently and isn't completely round as if its missing a chunk. I'll see if the new ones I order are all the same shape.
Thanks.
Found oil on spark plug wires rubberman Service & Maintenance 6 10-25-2011 02:38 PM
Oil on spark plug boots - WTF? poison Normally Aspirated Powertrain 14 03-16-2008 03:54 PM
STi, small amount of oil on spark plug BrandonWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-26-2005 02:31 AM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 10:27 PM
Oil on spark plug wires normal HighTachPrez Normally Aspirated Powertrain 1 05-21-2003 02:36 AM
