Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 08-13-2005, 04:09 PM   #1
Advan 048
Member#: 84910
04 wrx
black
Default Power Enterprise 850cc Injector Install
I just recently buy these injectors for my 04 STi , Are they directly plug and play with the original or I will have to use the plugs that PE supply...?
thanks for your response
Advan 048 is offline   Reply With Quote
Old 08-13-2005, 05:19 PM   #2
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
Hi
i did a set of a customers car last week and going to do a set for my FXT shortly
its really simple. you will need to change out the plugs but it takes less than 2 min to do all of them. all you need is a really small flat blade screwdriver. from the inside of the plug there is a small little clip. pull up on that slightly and the wire will come out from the back side. then all you need to do is insert them into the new plug and push the wires in untill the click.
its that easy
Tom
Old 08-13-2005, 05:39 PM   #3
Advan 048
Member#: 84910
04 wrx
black
Thanks buddy
Old 08-13-2005, 06:43 PM   #4
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
yea a sunglass repair kit would do the trick!
SupraScooby is offline   Reply With Quote
Old 08-13-2005, 08:44 PM   #5
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
exactly.
Old 08-13-2005, 09:11 PM   #6
timeless
Member#: 46316
30R STI 440 whp/wtq
Prodrive gc010e 18x9.5+25
Its not just plug and play, with this you need tuning right?
timeless is offline   Reply With Quote
Old 08-13-2005, 09:12 PM   #7
SupraScooby
Member#: 52123
05 WRB STi
well they're plug and play as in the install but you would need tuning of course
Old 08-15-2005, 05:37 PM   #8
Advan 048
Member#: 84910
04 wrx
black
hi
Are the wires pull up from the original plug and just insert the PE plug in the same position, because i don't know which one is positive/negative, so i don't know do i need to rotate the wires..
Thanks for helping!!
Old 08-16-2005, 11:14 AM   #9
949
Member#: 58906
will the car still start up and run with out the tune tho?
what will happen if he just ran the car with out the tune?
949 is offline   Reply With Quote
Old 08-16-2005, 12:05 PM   #10
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
I Believe they're not polarity sensitive. Wires can go either way. But for neatness keep all wires oriented same way as stock!
engineerx is offline   Reply With Quote
Old 08-16-2005, 02:46 PM   #11
timeless
Member#: 46316
30R STI 440 whp/wtq
Old 08-16-2005, 03:03 PM   #12
Dodzilla
Member#: 83430
2005 WRX STI
CGM
Honestly, if you guys don't know the answers to these questions you shouldn't be working on your car (if you want it to stay running, that is).
Dodzilla is offline   Reply With Quote
Old 08-16-2005, 08:28 PM   #13
949
Member#: 58906
duude i asked that cause i would assume some people need to install them at home and hopefully they will work somewhat but if not then im not sure if the ecu is smart enough to run in limp mode till the person can get it tuned by a professional but if you dont know then its kewl.
again not sure if that is what will happen
WTT: Power Enterprise 850cc injectors for sti injectors.. mr.phil.roxass SCIC Private Classifieds 12 12-19-2009 03:52 AM
STi Turbo XS UTEC and Power Enterprise 850cc injectors Benfolio Engine/Power/Exhaust 5 10-17-2006 09:31 PM
FS: Power Enterprise 850cc Injectors Rosspbig Engine/Power/Exhaust 10 09-12-2006 12:17 PM
Power Enterprise 850cc injectors for the 04+ STi Back in stock!! NinosAutoAccesories Engine/Power/Exhaust 6 08-12-2004 03:09 PM
