Old 08-13-2005, 09:51 PM   #1
t.renz
Member#: 49067
2006 BMW 330i ZSP
Snob Silver
Default mech cel fix, 100 miles later the light came back, now what?
I have an up pipe and catted TB. Ideas? I need to get this thing inspected asap!
t.renz is offline   Reply With Quote
Old 08-13-2005, 09:56 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Have you gotten it scanned to be sure it's the same code? Did you do the resistor fix for the uppipe as well?
Old 08-13-2005, 10:04 PM   #3
JRSCCivic98
Member#: 67080
EM with proper CEL defeats in the map would work wonders for you.
JRSCCivic98 is offline   Reply With Quote
Old 08-14-2005, 05:05 PM   #4
t.renz
Member#: 49067
2006 BMW 330i ZSP
Snob Silver
No money for em right now...
Old 08-14-2005, 05:16 PM   #5
chrisboostinWRX
Member#: 92833
Get the MIL eliminator from Pony Express. Its $20. Just wire it in. Or if you dont have $20 you can build the circuit yourself for about $3 from radio shack.
Chris.
chrisboostinWRX is offline   Reply With Quote
Old 08-14-2005, 06:35 PM   #6
REX8
Member#: 24038
Chris.
NO!!!! The MIL will get you nothing but the CEL turned off. IT WILL NOT PASS INSPECTION!!! The MIL is USELESS.
Old 08-14-2005, 06:38 PM   #7
gc835
Member#: 78080
2001 impreza
red biatch
go mechanical dude. its the best way youll set no codes instead of covering one up
gc835 is offline   Reply With Quote
Old 08-14-2005, 06:42 PM   #8
pityr
Member#: 31719
he has the mech fix and he still has the CEL. he needs to go get the code read to make sure its the O2 sensor and not something else.
pityr is offline   Reply With Quote
Old 08-14-2005, 09:23 PM   #9
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
He has A mechanical fix, and he has A CEL, but which one? Sometimes it takes a bit of tunning. Pull the CEL, and tell us.
bofh is offline   Reply With Quote
Old 08-14-2005, 10:06 PM   #10
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
as stated above, are you sure you're throwing that code and not another one? if so, you're the first documented person that the mechanical fix did not work for...
spankaveli is offline   Reply With Quote
Old 08-14-2005, 10:13 PM   #11
REX8
Member#: 24038
There are actually plenty of people that the mech. fix doesn't work for. Make sure the mech fix is 100% correct, then reset and try again. Worked for me...
Old 08-14-2005, 10:17 PM   #12
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
odd..
Old 08-14-2005, 10:31 PM   #13
pityr
Member#: 31719
most of the ones that I have heard it not working on were the newer 04+ models. I haven't personally come across someone (who installed it right) with an 02/3 that it didn't work for.
Old 08-15-2005, 12:08 AM   #14
sheikthin
Member#: 77592
* missdawn = MILF
now with 25% less pistons
did you buy the actual mechanical fix from someone like gruppe-s or perrin? or did you make them with the spark plug antifoulers piggybacked?
sheikthin is offline   Reply With Quote
Old 08-15-2005, 12:26 AM   #15
roninwarior007
Member#: 29886
MKV GTI
Bye Bye 02 WRX....
I just pass NY state inspection this pass week with the scoobysport electronic fix. Not all electronic fixes will cause the O2 sensor to fail. Get one then find an Autozone and have them run the I/M readiness test on the scantool (they should be able to do it... same ammount of time as pulling a code ?shrug?)
roninwarior007 is offline   Reply With Quote
Old 08-15-2005, 12:50 AM   #16
pityr
Member#: 31719
I made my own using the spark plug antifoulers. Worked for ove 20K miles so far
Old 08-15-2005, 03:17 AM   #17
t.renz
Member#: 49067
2006 BMW 330i ZSP
Snob Silver
I onlt used 1 antifouler, should I have used the second??
Thanks!
Old 08-15-2005, 06:35 AM   #18
mixup52
Member#: 39691
2002 WRX Wagon
Thanks!
Yes! You need both of them to work, But only need 1 to be drilled out.
mixup52 is offline   Reply With Quote
Old 08-15-2005, 09:53 AM   #19
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
Thanks!
yes
Old 08-15-2005, 10:08 AM   #20
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Like many have already said, until the real CEL code it known, it could be anything. If you don't have or know someone with a code reader, go to Autozone and they will pull it for FREE.
I am not sure if by "catted TB" you mean no cats at all so ...
If it is still the P0420 code:
Here is another way to get rid of that CEL.
If you still have your 3rd cat, go to a competent muffler shop and have them move the rear O2 sensor from in front of the 3rd cat to behind the 3rd cat. If they do it right, the sensor wires are long enough to do this. Cost = ~$25, including the new sensor bung.
What this does is move the O2 sensor out of the dirty air (no 2nd cat) into clean air (behind 3rd cat) and the CEL goes away.
I would guess that, if you modify the length of the sensor wires themselves, you will ruin the resistance expected by the sensor and create other unwanted problems.
This DOES work (@ least, it has for me). 2 years and no CELs.
Samurai Jack is offline   Reply With Quote
Old 09-06-2005, 09:22 PM   #21
rad one
Member#: 73189
Thanks!
where does the second antifouler go? on the up pipe. where can i buy these magical items? is there a step by step somewhere? i searched but didnt find anything. thanks
rad
rad one is offline   Reply With Quote
Old 09-06-2005, 09:24 PM   #22
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
screw them together and drill out the top one 1/2", screw the o2 into the top and then screw all 3 (o2 and both antifoulers) in to the DP
Old 09-06-2005, 10:53 PM   #23
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
rad
I can't believe you searched and found nothing. Even searching for anitfouler, you would get several posts pointing you to "mechanical 02 fix" and a step by step post.
Old 09-08-2005, 08:36 PM   #24
2.oh turb
Member#: 24359
2002 wrx
blue
im goin on three years w/ a cel and the only thing i do is put a case of miller lite in the driver's seat when i drop it off for inspection. works wonders actually, my cel goes off every once in a while for like a day or two. is this normal?? seems kinda weird to me. thanks.
2.oh turb is offline   Reply With Quote
installed aftermarket DP w/ mech cel fix, bad to drive with CEL? jojotherider Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-21-2006 03:18 PM
FS MO: Helix Catted Downpipe And Mech CEL Fix wowthatisrandom MWSOC Private Classifieds 0 06-04-2006 11:25 PM
does using the mech CEL fix increase gas consumption wrxxed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-12-2006 06:51 PM
mech. cel fix on stock 3rd cat Focus4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-05-2004 02:30 PM
Help! installed mech. cel fix and car won't start Focus4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 08-09-2004 12:29 PM
