Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 08-14-2005, 04:25 AM   #1
Chi_San
Member#: 53558
2002 WRX Wagon
Default EJ25 compression ratio
I've got an EJ25 that I would like to FI.
Other than complete custom everything, is there a simple, easy way to lower the compression ratio on the engine? I'm aiming for 8.5-9.1.
Chi_San is offline   Reply With Quote
Old 08-14-2005, 04:58 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Only way your gonna lower the compression THAT for is new pistons. Or else you'd need some REALLY REALLY thick head gaskets (not a smart idea there) Depending on what year that motor is, its either 9.7 or 10.0 compression.
Old 08-14-2005, 05:37 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Pull your pistons and mill out some of the piston head. Can't tell you how much, but it does work, and if you keep the PSI down to a reasonable level, it should/can work.
compression ratio of EJ257 with DOHC EJ25 heads jkjersey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-20-2006 08:06 PM
96' ej25 shortblock with 98' ej22 heads.. Whats the Compression Ratio? lotus2843 Subaru Conversions 12 02-07-2006 05:29 AM
What would the compression ratio be with a 96 ej20H shortblock with 96 ej25 heads? hotshot2109 Subaru Conversions 3 10-10-2005 11:02 AM
