Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 08-14-2005, 11:51 AM   #1
ShortBus
Member#: 38607
04 FXT
Default inside 2 inches gone
Hello all, I have a tire problem.
03 wrx wagon w/ tein s comp springs, 17" rota subzero and yoko avses100 235/40.
The inside 2 inches go to the tread marks after 3k.
I took it to sod and they adjusted the front end to a -1 I think but I still had the same problem.
After my first visit they would not check the adjustiment again or try to make it better so here I am.
I just saw an ad for nitto neo gen and it seems to address this problem?
Has anyone else had this problem and what did you do to fix it.
I was also wondering if it is ok to rotate the tires so that the inside is now the outside while keeping the direction the same?
Thanks in advance.
ShortBus is online now   Reply With Quote
Old 08-14-2005, 08:03 PM   #2
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
What toe are you running?
BlkWRXWag is offline   Reply With Quote
Old 08-15-2005, 11:41 AM   #3
ShortBus
Member#: 38607
04 FXT
-1 i think
Old 08-15-2005, 11:45 AM   #4
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
Originally Posted by ShortBus
-1 i think
I suggest you read the alignment stickies so you understand what toe is and how you measure it. Anyway, it is toe that rips your tires up like that, not camber. Find a decent alignment shop that will set your toe to 0 all round.
Old 08-15-2005, 11:50 AM   #5
ShortBus
Member#: 38607
04 FXT
thats the hard part. thanks .
Old 08-15-2005, 12:54 PM   #6
ripvw
Member#: 27790
plug in your zipcode and see who TireRack recommends:
http://www.tirerack.com/installer/index.jsp
or drive to Austin and see Bill Kim @ SoulSpeed:
http://www.soulspeed.com/default.asp
ripvw is offline   Reply With Quote
Old 08-17-2005, 01:44 PM   #7
John2.5RS
Member#: 1140
2013 Ecoboost'd F150
Grey
Default What about camber?
What kind of camber are you running?
John2.5RS is offline   Reply With Quote
wrx sti Custom upipipe 2.3 to 2 inch with flex joint wrxdragger Engine/Power/Exhaust 0 01-09-2008 08:55 PM
Looking for 2 90 deg 2 inch IC pipes blue-sun Mid West Subaru Owners Club Forum -- MWSOC 4 04-13-2005 05:42 PM
Is 2 inches to low for GC8? RCMM Brakes, Steering & Suspension 6 03-06-2002 05:50 PM
6-1/2 inch speaker in WRX rear passanger door Alex L Car Audio, Video & Security 17 10-22-2001 09:52 AM
yall need to check out the 1 1/2 inch drop on the MY98. AliBenn Texas Impreza Club Forum -- TXIC 5 03-10-2001 02:03 PM
