![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 33608
Vehicle:2003 WRX Wagon |
I've done several searches and found lots of discussion on tire pressures as it relates to performance, feel, and safety. However, I found very little in regards to durability and gas milage. I have been shocked by how quickly my car is chewing through tires. I'm running stock wheels and stock size tires on an 03 WRX. I've been running them just 1 or 2 psi higher than the recommended 32/29. While I certianly value performance, I am aghast at how quickly this car, my first AWD, goes through tires and with gas prices continung to rise I wouldn't mind some better milage either. Anybody got any recommendations? At this point I wouldn't mind sacrificing a little ride quality or corning performance if I could get my tires to last more than 20-25K miles.
#2 |
Member#: 61950
Vehicle:2008 Outback big blue wagon |
I put 33PSI in all 4 and have over 30K on my Re92's, but they are almost ready to be replaced before the winter since they are no longer snow worthy (as if they ever were). I get between 24-28 MPG with my OBS. Maybe look for a harder tire, and read consumer reviews on tirerack.
good luck, Steve |
#3 |
Member#: 50995
Vehicle:2002 WRX Wagon |
What tires have you been running?
#4 |
Member#: 33608
Well obviously I started with the OEM tires (RE92's I guess?) and I got 25K out of those. I'm now running a directional set of Dunlop SP Sport FM901's. They have an indicated max press. of 51psi. I've been much happier with the performance of these tires over the stockers, but I've got 10K on them and they are about half way through the tread depth already. I drive spiritedly on occation but not every time I get behind the wheel, and the tires only see wheelspin on rare occations when I get overzelous in the wet. Although you are limited in your ability to rotate directional tires, all 4 seem to be wearing evenly (fast).
#5 | |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
....when ya get some REAL UHP tires on yoiur car you will realize just how bad those dunlops are. ....and tires run too soft are subject to road hazards like pinch flatting and sidewall brusing and don't resist punctures well. |
#6 |
Member#: 33608
Having now researched tire reviews, I admit I should have done more reading before I bought the Dunlops. However, premature treadwear does not seem to be one of the major complaints against the FM901's, it's mostly performance issues.
I guess I'm just trying to find out if 25K mile tire replacement is just life with this car unless I put Flinstone style rocks on the corners, or could a tire pressure change help me to get more life outta these things. Last edited by oab97; 08-15-2005 at 10:25 AM. Reason: typo |
#7 | |
Member#: 14934
Vehicle:2002 WRX WRB |
If you put too much pressure in the tires, the centers will wear more than the outsides. If your tires are wearing evenly, changes in tire pressure probably aren't going to help. The only other thing that I would suggest is that you check your alignment. But really, 25k miles for a set of tires on a WRX seems about right. |
#8 |
Member#: 44168
SCIC
Vehicle:2003 Yellow WRX with too many lights... |
+1 for checking alignment. Once a year is a good interval depending on how bad your roads are and what kind of driving you do.
#9 |
Member#: 86253
Vehicle:03 WRX |
What kind of tires did 02 wrx sedan's come with? Because i have Continental Contitouring Contact CH95 tires and i cant take a turn fast at al without the tires coming loose and squeeling. Anyone know anything about the tires that are on my car?
#10 |
Member#: 44168
SCIC
They came with Bridgestone RE92s which most people consider junk.
They too would squeal on hard turns. Fortunately they'd squeal quite a bit before breaking loose which hopefully would give you enough time to correct your error (unless you intended to get sideways in the firstplace). ![]() |
| Thread Tools | |
| Display Modes | |
| HD Front and Rear Sways Vs. Tire Pressure | Sir_Xenon | Brakes, Steering & Suspension | 1 | 06-10-2004 12:30 PM |
| camber vs. tire pressure to stop rollover | rsotak | Brakes, Steering & Suspension | 3 | 05-05-2004 09:53 PM |
| tire pressure vs. size | Zman | Tire & Wheel | 5 | 01-22-2004 05:56 PM |
| Tire wear vs pressure.. ? | thrashvr6 | Tire & Wheel | 4 | 11-13-2003 11:23 AM |
| Rims for Wagon: Price vs Performance vs durability | Acadian | Brakes, Steering & Suspension | 46 | 02-16-2003 10:35 PM |
