Old 08-15-2005, 05:32 PM   #1
03MBP
Member#: 32460
2005 Forester XT
Default Race gas tune Vs water injection?
I'm debating getting either a race gas tune for my VF22 or water injection, now I understand that eventually buying race gas will creep up in cost, but water is also easier to find...that being said is there really any difference in performance between the two octane boosters? Any long terms effects that would make one better then the other?
03MBP is offline   Reply With Quote
Old 08-15-2005, 06:16 PM   #2
Funkmonster
Member#: 82114
2004 WRX
You realize you'll have to tune for the water injection right? If it were me, I'd go with water injection. That's something you can run every day without having to shell out big $$ for race gas or octane boosters. Then while you're in the shop getting tuned, have them make a race gas + water injection map for some fun at the track
Funkmonster is offline   Reply With Quote
Old 08-15-2005, 06:24 PM   #3
03MBP
Member#: 32460
2005 Forester XT
I know I would have to be tuned for WI or race gas...just wondering if there is any advantage to either other then initial price (race gas) vs price to replace (water is cheaper then c16).
Old 08-15-2005, 07:58 PM   #4
scooterforever
Member#: 55011
You might have a little more lag than before depending on the tune with WI, right as the water comes on. But that would probably be it. I would vote for water (actually, given your location, a mix of at least 25% methanol / 75% water) for the following reasons:
1. cheaper
2. can run it as a daily driver
3. daily usage doesn't actually use up that much water / alky. I have going through about a gallon of mix every two or three weeks. And I floor it whenever I can
4. water injection will steam clean your internals and lower your EGTs
scooterforever is offline   Reply With Quote
Old 08-15-2005, 08:08 PM   #5
dust12
Member#: 13417
I'll just throw this out there as PRO's for race gas.
#1 you don't have to buy or install additional hardware
#2 you don't have to worry about running out of water while your boosting and killing your engine.
#3 you don't have to worry about periodically checking your nozzles to make sure they are spraying properly.
With that being said, I'm probably going to install water injection on my daily driver. If this were a race track only car. I would probably just use the race gas...
dust12 is offline   Reply With Quote
Old 08-15-2005, 08:29 PM   #6
scooterforever
Member#: 55011
Course, there is one possibility if you're on the wild side and have $$$ to spare:
both
Old 08-15-2005, 08:43 PM   #7
dust12
Member#: 13417
Added benefits to water injection is it cleans the carbon deposits off your internals. As for dyno results, which is better then the other and by how much? I think race gas is going to produce the better results, however on a VF22 probably not by much. This is just speculation on my part and I have no proof to back it up.
Also there are different octanes of race gas as well. You have the standard unleaded 101 racegas, and then there is the 116 leaded gas. You have to be catless for the leaded gas though...
Old 08-15-2005, 08:47 PM   #8
03MBP
Member#: 32460
2005 Forester XT
I am catless...I've just been seeing alot of dynos with wi or race gas...alot of good points have been made, hopefully they keep coming. For my DD I think wi is the way I might go to squeeze a little more power out of my setup and then maybe step up to an 18G which would work even better on higher octane...but for now I'm tinkering with the VF22.
Old 08-15-2005, 08:59 PM   #9
hotrod
Member#: 14141
2002 Impreza WRX
The potential power output on WI is actually higher if you have the balls to tune for it. Most use it as octane insurance where the difference is pretty much a toss up.
The high power tune on WI is an all or nothing tune ! If you lose the WI you also lose the motor. Of course the same thing applys to race gas if you have a fuel injector problem or fuel pressure problem on an agressive race gas tune, the lean out will kill the engine too.
The potential WI power increase, can be over 50% of the engines power on gasoline alone, where race gas might be workt 40 - 50 hp.
Larry
hotrod is offline   Reply With Quote
Old 08-15-2005, 09:06 PM   #10
Funkmonster
Member#: 82114
2004 WRX
Larry
I haven't been seeing those kinds of numbers on Suby's... it definitely depends on the setup though. That may be the case on big turbo setups, but on a small(ish) turbo like a VF34 or VF22, you can't crank the boost up too high because the turbo will just run out of steam. <- atleast from what I've seen. On VF34 cars, people are running ~19 psi with WI, where I'm running 17 without. On a VF22 you might be able to squeeze out 22-23 psi so I'd be interested to see what kinds of numbers that yields.
Old 08-15-2005, 10:14 PM   #11
scooterforever
Member#: 55011
It all depends on supporting mods, timing, fueling, and boost, but:
-- I ran 20-21 lbs on the stock TMIC without WI, and
-- I now run 20 - 21 lbs on an aftermarket TMIC with a 50/50 meth mix (with more timing and less fuel)
Again, there are a number of factors that go into the tune, and WI does allow higher boost, but with the right supporting mods the VF-34 can go above 17 lbs. Course, I can now attest to the fact that 20/21 lbs is about the limit of the stock BPV. Mine screetches at WOT.
Old 08-15-2005, 10:57 PM   #12
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Or you can go strictly alky injection.
Do the good 2 map type set-up. One with alky one without and make sure you have a kill switch for the alky set-up!!
Alky rules no need for 116 leaded race gas!!
DuoMaxwell is offline   Reply With Quote
Old 08-16-2005, 05:09 AM   #13
hotrod
Member#: 14141
2002 Impreza WRX
Right, I'm talking about a setup that has the supporting mods to reach the limits of WI.
In 1943 the NACA (now NASA) researchers working with supercharged aircraft engines, achieved the following increases in MEP ( mean effective pressure) on engines using WI.
Gasoline only -- Fuel air ratios from 10.5:1 -- to 8.6:1 MEP ranged from 260 to 263 lbs/sq inch
WI at .2 x fuel -- Fuel air ratios of 12.5:1 MEP=260 psi at FAR 10.4:1 MEP reached 298 . That is a 13% increase in power.
WI at .4 x fuel -- Fuel air ratios of 14.8:1 MEP = 260 psi at FAR 12.9:1 MEP reached max of 312 psi or 18.6% power increase.
These at 27 - 30 psi boost.
If you look at the AFR that all three could run at, of 12.9:1 the increase in MEP achieved at that AFR jumped from 194 psi to 312 psi or a total power increase of about 61%.
That implies if you can make 400 hp on a 12.9:1 FAR with WI you can get up near 640 hp. (if of course you have the turbo etc to run the necessary 30 psi boost).
Bottom line most tuners are not even scratching the surface of WI's or AI's potential.
Larry
Old 08-16-2005, 09:59 AM   #14
dudical26
Member#: 37934
Is it possible to run both WI and Race Gas. What would be the result?
dudical26 is offline   Reply With Quote
Old 08-16-2005, 10:39 AM   #15
Jon [in CT]
Member#: 2992
02 WRX Sedan
C16 will require periodic replacement of the A/F sensor - not a cheap part.
Jon [in CT] is offline   Reply With Quote
Old 08-16-2005, 10:42 AM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Well.... with a turbo capable of producing the airflows that would push the limits of a quality leaded race fuel, then it would extend those limits.
But on 350-500WHP turbo's, C16 laughs at me when I throw stuff at it. (13.6:1, and all the timing you could want, where you know you're clearly not making any more power on the dyno)
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-16-2005, 11:32 AM   #17
TheMadScientist
Member#: 23717
2005 Big red
Jorge (RiftsWRX)
www.ProjectWRX.com
Wouldn't the WI reduce the charge temp? That would equate to a denser charge wich would make more power than C16 alone.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-17-2005, 01:01 PM   #18
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
TMS
Interesting spin, I can see that. Touche. But that be more a matter of W/I not so much alchy injection, or even a mix.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-17-2005, 01:17 PM   #19
TheMadScientist
Member#: 23717
2005 Big red
Jorge (RiftsWRX)
www.ProjectWRX.com
Even with 100% alchy or a mix some evaporation is going to happen. When the injected fluid evaporates it will cool the charge. The amount of cooling will vary with the mix. I guess that 100% water will cool the best but you will get some with the alchy. Wouldn't you?
I will say the same thing about the water/alchy injection that you said about C16. It is amazing how lean you can go with crazy advance.
TMS
555 Motorsports Pre-Shootout Tuning June 9-12 -Free Race Gas Tune Inside!!! Benchmark Tuning MWSOC Vendor Classifieds 25 06-13-2009 01:46 AM
Tuning for /water injection 06rexwagon Commercial ECU Reflashes 21 05-05-2007 10:04 AM
Nitrous vs. Water Injection ScreaminFast Water/Methanol Injection, Nitrous & Intercooler Cooling 13 07-20-2004 05:02 PM
C16 vs. Sunoco 104+toluene vs. water injection annointed Proven Power Bragging 8 03-09-2004 08:30 AM
Race gas tuning question. davidm_sh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-20-2002 02:25 AM
