Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-15-2005, 06:04 PM   #1
Joe Pollock
Member#: 93689
Talking 1993 Subaru Impreza burning oil at idle after oil change
Hello out there. I have a 1993 Subaru Impreza L and ever since I had my oil changed the engine smokes when it is idling. I am curioius as to what this is and how I can fix it. If you have an idea what it could be please specify the location of the problem and what I need to do. Thanks for your help!
Joe
Joe Pollock is offline   Reply With Quote
Old 08-15-2005, 06:15 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Chances are, rear main seal or rear access cover. Both would require pulling the motor or tranny to fix. Look for dark brown/black staining on your exhaust Y pipe need the crook of the Y- if you find it, that's the leaking oil from the rear of the motor.
Brian
Old 08-15-2005, 07:49 PM   #3
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
It could also be that oil was spilled when filling, or someone didn't tighten the oil filter or didn't use a crush washer on the drain plug.
Did the engine smoke at all before the oil change?
RexyGirl is offline   Reply With Quote
Old 08-15-2005, 11:15 PM   #4
Max Umbarger
Member#: 1112
2006 FXT
RBP
even from main seal leaks are common. Just like Ursalia said, only it would be in from od motor.
Or give it a few more days, maybe some is on the exhaust or on top of the motor from a little spilling. It will burn off and go away (if that's the case!)
Max Umbarger is offline   Reply With Quote
Oil light flickering on at idle after warmup greenobs97 Normally Aspirated Powertrain 7 01-10-2010 01:18 PM
RPM jump at idle/minor oil burning at front of engine cbous1 Newbies & FAQs 6 09-08-2009 03:08 PM
sputtering idle after oil change. help? iRick. Normally Aspirated Powertrain 1 07-21-2009 07:40 PM
high idle after oil change. quick question before a trip. Woofy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 09-13-2008 04:35 PM
Rough idle after oil/spark plug change? Robmat Normally Aspirated Powertrain 3 01-27-2001 08:24 PM
