#1 |
Member#: 68666
NESIC
Vehicle:2000 Impreza 2.5RS Silverthorn Metallic |
I know it is possible to swap a usdm or jdm wrx and sti motor into a usdm legacy.
My question is, would it be possible to swap a jdm legacy twinturbo(B4?) motor into a usdm LHD legacy? If it is possible, are there any major differences/benefits? Thanks, Denigrad
#2 |
Member#: 60224
Vehicle:2008 FXT Sports 2.5 Dark Grey Metallic |
A search may yield you better results... It gets discussed a lot… The problem is specifically with the LHD as you pointed out. The brake (booster) and steering setup prohibits the twin-turbo motor from even fitting in the engine bay without MAJOR modifications.
#3 |
Member#: 68666
NESIC
thanks
#4 |
Member#: 9853
International
Vehicle:to keep your mouth shut. |
Not really major modification, but it is a bit extensive. I'm not sure if you must relocate the brake booster, but the major problem with the TT setup is the LHD steering column being in the way of the downpipe. You will most definitely have to have this, among other parts, custom fabricated. It would be easier, cheaper, and more pracitcal (read: emissions) to do an USDM WRX swap.
Jonathan |
#5 |
Member#: 56015
RMIC
Vehicle:No you're a towel! |
Steering is overrated
#6 |
Member#: 2353
Vehicle:98' LegOver GT dark whiteish pearly red |
who needs steering when you have a TT
| Thread Tools | |
| Display Modes | |
| Hood swap | gambier82 | Vancouver Impreza Club Forum -- VIC | 2 | 06-02-2010 10:31 PM |
| FS : good start to a swap. 5MT | lsito5revo | Legacy Specific Parts | 3 | 06-02-2010 09:19 PM |
| EJ25tt | BadAshSuby | Factory 2.5L Turbo Powertrain | 0 | 09-28-2007 01:46 PM |
| USDM WRX or STi swap harder than JDM STi swap??? | garface | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 01-12-2003 11:37 PM |
| Exhaust system swap....??? wheel swap..?? | Aaron'z 2.5RS | Interior & Exterior Modification | 4 | 11-15-2002 06:05 PM |
