Old 08-15-2005, 09:48 PM   #1
99SubRs
Member#: 20510
2015 STI
Default 2003 Legacy L.. springs/struts?
aftermarket springs are easy eough to find for it but i cant seem to find any adjustable struts/shocks anywhere .. heck i cant even find just better aftermarket struts period... anyone know where i can find some or are there none?
99SubRs is offline   Reply With Quote
Old 08-15-2005, 10:34 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
KYB GR2's, not a huge improvement, but an improvement. You could go STi or some of the Japanese brands but they will cost a fair penny.
tora is offline   Reply With Quote
Old 08-16-2005, 01:28 AM   #3
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
in the same boat here. cant seem to find anything. links anyone?
nyyankees003 is offline   Reply With Quote
Old 08-16-2005, 01:49 AM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
kyb gr2's are on tirerack IIRC.
fibuz is offline   Reply With Quote
Old 08-16-2005, 02:34 PM   #5
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
i went there and they dont have any suspension parts listed for MY03
Old 08-16-2005, 03:05 PM   #6
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
KYB GR2s are a bit better than stock, and are a direct replacement. On BD/BGs you can put KYB AGXs (adjustables) on if you use Impreza/WRX tophats and AGXs meant for the Impreza, but I'm not sure if that goes for BE/BHs or not.
www.boxer4racing.com has GR2s for BD for a few hundred. I got mine from TireRack.com.
Koni also makes nice struts, from what I've heard. Patrick Olsen put Koni inserts on his BD and I believe he was pretty happy with them - Pat, care to elaborate?
If you want a lot more flexibility, and are willing to spend the money, get coilovers. There are several coilover setups that would let you adjust both ride height and shock damping.
-Aaron
fastenova is offline   Reply With Quote
Old 08-16-2005, 03:08 PM   #7
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
KYB Gr-2's are avalible at Tire rack or some local auto parts stores, contact Luke, he is a tire rack rep and a vendor on this board. AGX makes an adjustable sturt for about double the price of the Gr-2's.
The Gr-2 is slightly better than stock but will handle a drop spring much better since the stocker will self destuct when dropped.
I will look for part numbers but you should be able to call Tire rack or get a hole of Luke.
Edited for part numbers:
KYB GR-2
Right Front 334273
Left Front 334274
Right and Left Rear 341275
bhall is offline   Reply With Quote
Old 08-16-2005, 03:09 PM   #8
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
edit: DAMN YOU AARON
Old 08-17-2005, 09:10 AM   #9
99SubRs
Member#: 20510
2015 STI
thanks for the part #s that helped out alot.
found they have them at summit racing for a pretty good price.. figures they would be on backorder right now though...
so the GR2s will be ok to use with drop springs? i am only looking for a mild drop because i dont want to plow snow in the winter..
Old 08-17-2005, 11:11 AM   #10
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
I do what I can!
I will be running iON springs in a few weeks with my GR2s. I've heard that GR2s work great with drop springs (usually drop springs by themselves are not too aggressive). The GR2s are also a better construction than the stockers (although I think my rear struts were KYB and the fronts were Sunco Something like that...) However, if you're looking to track the car at all I'd say get your drop springs and a slightly stiffer strut setup, AGX or better. Then again, plenty of people are tracking their rides with stock setups
-Aaron
Old 08-17-2005, 11:32 AM   #11
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
The KYB's have a bit better dampening than stock but as you said the big advantage is that they can handle the drop where the stockers can not. I have a fairly big drop on my BE and the Gr-2's are doing fine. I did both the springs and struts at the same time so I can not tell you the difference between the stockers and the Gr-2's since the entire sus changed at the same time.
FS: '97-99 Subaru Legacy GT springs/struts/rear swaybar tamadrumr88 Legacy Specific Parts 7 11-05-2009 07:27 AM
2003 WRX Wagon Springs and Struts abqkid Suspension/Brakes/Handling 2 04-26-2007 08:20 PM
2003 WRX Sedan Springs/struts, Full Brake setup PhastEddie Suspension/Brakes/Handling 22 03-22-2007 11:14 PM
2003 WRX complete suspenion - struts, springs, tophats, & swaybars jroberts Private 'For Sale' Classifieds 9 11-17-2004 12:53 PM
2002/2003 Stock Springs, Struts and Seats Vostok 7 Private 'For Sale' Classifieds 2 05-11-2004 12:35 AM
