Old 08-16-2005, 11:22 AM   #1
ronnyek
Member#: 60724
06 CG STI-05 g35
^ Needs trunk swap. PM ME
Default vibration after new tires
Ok...
I'm running 18x7 adr m-sports and have been more or less happy with them for quite some time... I've noticed that my car eats through the front tires pretty quick.
I've replaced the tires with some more agressive zrated tires... and notice at right around 65mph I get a bit of vibration... and until now have chalked it up to a bit of a bend in the lip of a wheel... (although I never noticed a vibration with other tires).
Could this be an alignment issue and its just now apparent because I've got more agressive tread pattern?
thanks in advance
ronnyek is offline   Reply With Quote
Old 08-16-2005, 11:38 AM   #2
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
I would have the tires re-balanced.
jweiss is offline   Reply With Quote
Old 08-16-2005, 11:42 AM   #3
Idahoser
Member#: 78147
93 impreza 4dr
280.000 and runs 100+
If its going through tires you more than likely have alignment issues. Where do they wear at? A toe in situation will sometimes create a shake at lower speeds but not 60 plus, thats usually balance. Try rotating them to the rear to pinpoint the bad one.
Idahoser is offline   Reply With Quote
Old 08-16-2005, 12:48 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
If your car is eating tires, get the alignment checked!!!!!
It is likely a toe issue.
Old 08-17-2005, 01:41 PM   #5
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Default two things
Check alignment. Get the wheels re-balanced.
John2.5RS is offline   Reply With Quote
Old 08-17-2005, 02:05 PM   #6
ronnyek
Member#: 60724
06 CG STI-05 g35
I realize thats the next item on my checklist, but its unlikely a slightly bent lip of a wheel would cause that?
brakes vibrate after new brake install brandonwrx06 Brakes, Steering & Suspension 6 04-07-2009 04:56 AM
Vibration after new brake install impreza510 Brakes, Steering & Suspension 1 03-18-2008 02:49 PM
rim inner damage after new tires mounted??? rich728 Tire & Wheel 1 08-22-2004 11:50 PM
Vibration after new flywheel & clutch install Sir_Xenon Transmission (AT/MT) & Driveline 1 11-14-2003 10:28 AM
After new tires when letting go of the wheel the car follows the angle of the road Heather Tire & Wheel 16 07-05-2003 03:06 AM
