Old 08-16-2005, 02:33 PM   #1
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Default Attn: E-Manage users
Can you guys email me your recorded run files? Like 0-70mph power runs or something similar?
I'm most interested in comparing my air flow voltage readings to others. I'm currently maxing at 4.19 though it's usually closer to 4.1. This is with my 2.0 EJ20G with 2.2 NA heads, delta cams, 1.8 intake, 12psi. I'm about to install a 2.2 intake manifold, I'm hoping that will help out in the power delivery. I notice the runners are larger and don't have as sharp a bend in them.
Chad
[email protected]
subachad is offline   Reply With Quote
Old 08-16-2005, 10:00 PM   #2
Unsung Boxer
Member#: 37196
dude, start a database on your site.. I want to get back into tuning.
btw, remind me to chat w/ you soon about those 360cc injectors.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 08-17-2005, 07:31 PM   #3
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
My setup is totally diffrent to your setup of course. But I do have the pressure sensor so I can give you some good data showing MAF voltage vs mesaured pressure (you will have to pull the pressure sensor voltage vs. psi graph off of that emanage yahoo group).
Also what MAF are you using?
ai42 is offline   Reply With Quote
Old 08-18-2005, 01:01 AM   #4
subachad
Member#: 8488
Teal
I'm using the stock 93 MAF. I just want to know what voltage people are maxing out at. I know Unsung maxes his all the way to 5v and it feels super strong when it gets up there. Without boost I'm in the low to mid 3V area.
Unsung, what do you want me to setup on my site info wise? Are you thinking of a spreadsheet or what?
Chad
Old 08-18-2005, 09:51 AM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Sent.
-Brett
ExecNav is offline   Reply With Quote
Old 08-18-2005, 03:27 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm might be time to up to a LegacyT maf (guessing its bigger)
Old 08-19-2005, 12:26 PM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
i am making 4.4v on my car / MAF at 9psi
Hitokiri is offline   Reply With Quote
Old 08-19-2005, 12:28 PM   #8
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
I am working on eliminating my MAF with the Emanage Ultimate. Do do so I will be defineing the MAF voltage in a 16x 16 table of boost x RPM. I am taking datalogs and populating my map gradually as I get more. When I am done and have it working I will post the map for you.
Old 08-19-2005, 12:33 PM   #9
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Jaxx - the LegT MAF is actually probobly SMALLER considerably.
I worked on tuning one with an emanage and WB. We were pegging the MAF before 4700 RPM and ~11psi boost. It is my guess that they used the same MAF as the NA cars. It almost pegs at redline and ~7-8psi boost.
look here: http://bbs.legacycentral.org/viewtop...ight=zeitronix
Old 08-19-2005, 02:10 PM   #10
subachad
Member#: 8488
Teal
Can you email me your current map at a power run? I'd be curious to see how your map looks and what kind of numbers you are logging.
Old 08-19-2005, 06:11 PM   #11
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
actually I am not tuned up to the level I was before. I just looked at an old log hit actually 4.45 maf I could send you that log. And that was at much less than 9psi. I need to find the power adaptor for my old laptop to get the datalogs from the emanage at 9-10psi.
I just switched to the ultimate, and I am now doing my fuel compensation to the output of the ecu entirely. IE no MAF correction to the stock ecu at all. I am having troubles though because the ecu seems to hit a wall of fuel at 5500 rpms. I have tried pulling way more fuel over that but it doesn't seem to help. I am thinking that the ecu has a fuel wall feature triggered from a MAF level. it seems to happen around 4V maf reguardless of boost and at about 5500 rpm, I am going to try clamping at 4v and see if I get past the fuel wall. I am not limiting the MAP input to the ecu either. (MY99 RSs have a boost sensor stock that reads very accurately in boost!) But I didn't have the fuel wall issues before when I was using MAF correction such that the ecu would never see more than 4v on the maf. Now that it sees the real load its dumping fuel it seems instantly at 5500 rpm or seemingly at 4v MAF.
email me at [email protected]
Old 08-19-2005, 10:56 PM   #12
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
update:
My fuel wall issue was the ecu hitting 100% duty cycle on the injectors. It seems the ultimate's algorithm that subtracts from the IDC falls on its face if the injectors go wide open. I clamped that MAF so the EC never sees more that 4v and I was able to tune it nice and flat after that.
ATTN: Engine management forum Scooby South Engine Management & Tuning 63 03-08-2006 09:49 PM
E-manage users,"I got a questchin" 2slofouru Engine Management & Tuning 0 08-26-2005 07:01 PM
e-manage user!!!!!! AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-10-2003 09:44 PM
E-manage Users OKRS25 Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-04-2003 09:03 PM
ATTN: Adobe Premiere users UnderAgeEnthusiast General Forum Archive 1 01-27-2001 10:12 AM
