Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
View Poll Results: Did your 225s on stock wheels wear edges early?
Yes 3 75.00%
No 1 25.00%
Voters: 4. You may not vote on this poll
Old 08-16-2005, 09:39 PM   #1
The Professor
Member#: 23183
2002 Cobb StageIIWRX
WR Blue
Default Year old Dunlops gone to hell
Got these through Luke at the Tire Rack just over a year ago. Great service by Luke all around by the way. Took the car to be inspected today (huge process in PA ) and they call me telling me I need three new tires. Of course this gets into a big back and forth "I know cars and tires and mine are fine" "Your steel belts are showing through" blah blah blah until I get enough and leave work to go verify. Sure enough the inside shoulder is worn down on both front tires with 6/32 of good tread left! . Now these were great tires (Dunlop SPsport5000 ASY) in wet, snow, and dry. Really could not have been happier from an all season stand point. I am however mystified as to how a stock suspended car could crap out it's tires like that so quickly and completely when I keep up on the maintenance. When it's time for a service I take it in and it gets done, including alignments. I've owned lowered vehicles before that never gave me a problem like this. The tires are size 225/50 on the stock wheel but I know many of you are running this set up......anyone else have this problem with the slightly oversized tire?
*edit* I need 3 because one is new two are worn so the last one gets sacraficed to save the differential.....yay....AWD + tire problems =
The Professor is offline   Reply With Quote
Old 08-16-2005, 09:53 PM   #2
waktasz
Member#: 86356
Since when is it a huge process for inspection? :/
waktasz is offline   Reply With Quote
Old 08-16-2005, 10:13 PM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
How often are you rotating your tires and checking tire pressure? I rotate my tires every 3K.
HomerJay is offline   Reply With Quote
Old 08-16-2005, 10:24 PM   #4
Karl
Member#: 13110
How many miles have you driven in a year?
Karl is offline   Reply With Quote
Old 08-16-2005, 10:37 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....get your alignment checked.....'0' toe is what ya want.
Uncle Scotty is online now   Reply With Quote
Old 08-16-2005, 10:41 PM   #6
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
And the only question that matters... How much toe do you have? Your alignment wears tires not the size of the tires or what height your car is at. Tire pressure can contribute to wear but if the inner part of your tire is on the belts and the outer part is at 6/32nds then your alignment is truly and utterly borked and it has nothing to do with your tires or your springs.
PhilC is offline   Reply With Quote
Old 08-16-2005, 11:45 PM   #7
The Professor
Member#: 23183
WR Blue
In one year about 12,000 no more than 15k on these tires by my guess.
Homer, not as often as you are.....maybe I should increase the frequency.
Uncle Scotty, yes the car will be aligned when the new tires are put on
Phil, I generally run the tires a little high on pressure to reduce sidewall flex. This feels much better in cornering and accelerating. I picked it up while autocrossing (not on these tires of course) and have done it ever since. The alignment will of course be done I just don't see what happened. No accidents or rally racing. No potholes or raised manhole covers or any of that. It's all smooth road and freeway with one train track crossing between here and anywhere I go including work. Just wondering about the size issue, glad to hear that has little or nothing to do with it.
Phil - Does low pressure wear harder or does high pressure?
Old 08-16-2005, 11:58 PM   #8
express_wagon
Member#: 68346
1996 LC
2014 JK
low tire pressures wear tires on the outside while high pressure takes more from the middle of the tread...i think
express_wagon is offline   Reply With Quote
Old 08-17-2005, 02:29 PM   #9
John2.5RS
Member#: 1140
2013 Ecoboost'd F150
Grey
Default Sound like an alignment problem
Check you air pressures, maybe bump them up a couple of PSI. I would check your alignment, The Toe and Camber are the big ones that tend to wear the inner edges of the tires.
John2.5RS is offline   Reply With Quote
Old 08-17-2005, 06:08 PM   #10
The Professor
Member#: 23183
WR Blue
Thanks John, I'm pretty fanatical about keeping the pressure correct because I have a sickness that makes me try and get good gas mileage from sporty cars and correct to slightly high pressure helps with that. It's currently anywhere between 34 and 36 PSI on 225/50 16 Dunlop Sp5000s. I am taking it to a decent place to get it aligned and I will be sure to mention the problem. I see other guys having this problem the more I look at the tire forum. I could probably rotate more often as well. I can't find any information advising how often to get an alignment. Once a year??
board has gone to hell - lock and delete this i'm sure angryoldskool Off-Topic 72 11-10-2009 07:40 PM
Democrats To Change 185 Year-old House Rule To Allow Tax Hikes Without Having To Vote zman302 Political Playground 12 05-20-2007 11:33 AM
You know the world has gone to hell when... Mud Pig Off-Topic 12 06-25-2004 04:09 PM
sti injector almost gone to hell, need help! datdudedennis Texas Impreza Club Forum -- TXIC 6 04-04-2003 11:29 PM
gas mileage gone to hell! =P Darwin Bay Area Impreza Club Forum -- BAIC 6 12-06-2001 07:53 PM
