Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 08-16-2005, 10:12 PM   #1
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
Default sti shortblock
Just wondering would a sti shotblock bolot right up to my exsisting 2.5 DOHC heads and intake manifold... ect. without having to do wireing or swapping anything ???????????
THAnX MaIn
EastsideLegacy is offline   Reply With Quote
Old 08-16-2005, 10:40 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yes, it will, obviously I am assuming you want to turbo your car if you are swapping that shortblock?
Ben
Old 08-16-2005, 10:42 PM   #3
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
THAnX MaIn
Other than the difference between a closed deck head gasket and the open deck heads, should be no problem. You just want to make sure all of your journals are open to each other and not blocked by the gasketing. Believe the STI pistons will mate well with the heads but you're going to be raising the compression (at least over a stock STI setup) so running FI may be an issue unless you get that figured out correctly.
The question I have to ask is why? STI heads flow much better than the 2.5 DOHC heads, and the STI cam profiles and valving are better/different than a NA stock 2.5L.
What are you thinking, future of the engine/drivetrain-wise?
SBT
Subietonic is online now   Reply With Quote
Old 08-16-2005, 11:07 PM   #4
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
i think he's worried about the wiring, keeping his 2.5RS heads he has hardly any wiring to worry about, and ulitmitaley it would be a good step in the way of more power, whether he was going to go FI or N/A.
~Mike
pilfflip is offline   Reply With Quote
Old 08-29-2005, 07:29 PM   #5
EastsideLegacy
Member#: 58806
2.2L legacy wagon
If i keep my engine N/A with my old heads will the sti shortblock bolt up also if i wanted to put oon the sti heads what wiring would have to be changed ?
Old 08-29-2005, 07:35 PM   #6
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
All of it...
AVCS plus FI ECU and sensors...
xcntrk75 is offline   Reply With Quote
Old 08-30-2005, 03:45 PM   #7
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
You should also note that if you plan on putting an intercooler in the mix you will need a new manifold, the N/A don't have the intake inlet pushed forward so there isn't enough room for the manifold and the intercooler, the forced Induction manifolds wrap over themselves closer to the front of the block so that the throttle body doesn't push the intercooler to far back
~Mike
Old 08-30-2005, 07:13 PM   #8
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
^^^ F M I C
ooberdoob is offline   Reply With Quote
FS : EJ257 STI Shortblock diabloadsit Engine/Power/Exhaust 7 06-19-2010 11:27 AM
v7 sti shortblock v. v8 sti shortblock neep opinions asap. DoctorNick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-22-2005 08:26 PM
What is the difference between a standard STI shortblock and a Crawford S2 shortblock keaniegenie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-16-2005 07:04 PM
USDM 2.5L STi shortblock vs EJ22T Shortblock yellowscooby New England Impreza Club Forum -- NESIC 13 07-25-2005 09:23 AM
WTT JDM v7 shortblock for USDM STi shortblock werkInProgress Private 'Wanted' Classifieds 2 05-23-2005 06:32 PM
