Old 08-17-2005, 04:28 PM   #1
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
Default RS header vs. WRX header...
Okay, so it looks like my turbo is fried and I've gotta replace it. The previous owner turbo'd the car, and ran a custom up-pipe from the stock RS headers to the VF10 turbo. The up-pipe was made of mild steel, and is a rusted Piece of crap. So, as long as I'm going to replace the turbo, I'd like to replace the up-pipe.
So, my question is: How similar are the designs of the stock RS and WRX headers? Will a prefab up-pipe designed for use with the WRX headers fit the RS headers as well, or do I have to get a custom pipe made?
projectrally is offline   Reply With Quote
Old 08-17-2005, 07:28 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
I'm going to say it's more trouble than it's worth. WRX headers form my understanding are totally diffrent to the GC6 setup and require the WRX engine crossmember to use.
ai42 is offline   Reply With Quote
Old 08-17-2005, 07:43 PM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
It has nothing to do with a GCx/GDx chassis difference. All the turbo motors use a similar style of header, all the NA motors use a different style. Unless you get an upipe from the same kit that yours came off of a WRX one probably will not fit. You can use any turbo crossmember. A brand new Legacy turbo x-member is less than $200 from the dealership. Most of the aftermarket kits I have seen do not place the turbo in the stock turbo location either. Your downpipe may not fit either after you replace the up pipe/x-member
no-coast-punk is offline   Reply With Quote
Old 08-18-2005, 11:29 AM   #4
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
turbo XS mid and downpipes fit now. I'll just have to get a custom up-pipe, i suppose. Thanks, no-coast.
Old 08-18-2005, 01:05 PM   #5
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Another word of caution: If you have 99 RS with SOHC, most WRX up-pipes will not clear the rear of the cylinder head. The 98's are a little easier as the head has a notch much like the those on the WRX. It may still require a little work despite a Legacy Crossmember.
Good luck.
Joncas2 is offline   Reply With Quote
sti vs wrx headers JohnRish Newbies & FAQs 3 04-15-2010 07:14 PM
STI VS WRX Header Alex Germain Newbies & FAQs 9 01-24-2010 09:38 PM
OBX header vs. MRT header dyno results Patrick Olsen Normally Aspirated Powertrain 7 06-26-2006 08:31 AM
aftermarket header vs stock header height rubyred Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-13-2005 02:11 AM
Exhaust sound clips...header VS. non header Dynamispeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-27-2004 09:26 PM
