Old 08-17-2005, 05:35 PM   #1
shemoves
Member#: 80663
1997 Outback
Default Part number for '94 SS oil filter?
Need to change the oil on the 1994 Legacy Sport Sedan. Also, it's got 150k on her, any oil suggestions for high mileage, turbo Subarus? (I think I am gonna get some Redline just to test it out before I put it in the STi)
shemoves is offline   Reply With Quote
Old 08-17-2005, 08:11 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
It's the same filter as on pretty much every other newer subaru. The only exception is the smaller filter for the 02 WRX & similar turbo engines. It's been discussed/questioned whether the smaller filter should be used on the older turbo legacies, and the consensus was to use the older/wider filter.
I don't know the part #, but I'm sure it's floating around somewhere on the board.
Legacy777 is offline   Reply With Quote
Old 08-18-2005, 03:53 AM   #3
shemoves
Member#: 80663
1997 Outback
bump...part # for '94 leg turbo oil filter? ...don't want a non-oem crap can
Old 08-18-2005, 10:37 AM   #4
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
Just go to your local parts store and get the Purolator that is listed for the SS. The OEM one from Subaru is a Purolator too. That's what I run and it cost about $2-3 cheaper then OEM to boot.
legacy92ej22t is offline   Reply With Quote
Old 08-18-2005, 05:05 PM   #5
shemoves
Member#: 80663
1997 Outback
I don't think they are the same though. I'll look into it.
Old 08-18-2005, 09:23 PM   #6
Legacy777
Member#: 4800
They are the same filter. If you buy a subaru OEM filter, it says puralator on it.
Old 08-30-2005, 08:58 AM   #7
subarurabbit
Member#: 4083
2006 OBS SE
regal blue
15208aa060
subarurabbit is offline   Reply With Quote
Old 10-10-2006, 01:48 AM   #8
ncskier96
Member#: 97598
1997 OUTBACK SPORT
blue over gray
I dont mean to hijack the thred but are the oil filters for something such as an 98 rs the same for the EJ20k/g/7?
ncskier96 is offline   Reply With Quote
Old 10-10-2006, 01:37 PM   #9
shemoves
Member#: 80663
1997 Outback
I am pretty sure all the four cylinder motors use the same oil filter. Part # 15208AA100. Double check though.
Old 10-10-2006, 02:17 PM   #10
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
the AA100 is for the newer turbo motors. The filter you want is the AA060.
Arctic Assassian is offline   Reply With Quote
Old 10-10-2006, 07:58 PM   #11
ncskier96
Member#: 97598
1997 OUTBACK SPORT
blue over gray
Ok thank you
Old 10-10-2006, 08:45 PM   #12
shemoves
Member#: 80663
1997 Outback
Part numbers for roof rail deletes? jgardner9000 Interior & Exterior Modification 7 06-04-2010 01:46 PM
Part number for Sti gearbox oil try/pan aus_taz Private 'Wanted' Classifieds 2 03-10-2010 12:54 PM
New Oil Filter Part Number For Turbo Wrx? obxtoy Service & Maintenance 2 09-26-2005 11:03 AM
Urgent! Part # for WRX Subaru Oil Filter?? Zoinks General Community 2 10-02-2004 04:17 PM
All the part numbers for the Subaru Oil cooler? yebokmj General Forum Archive 7 12-05-2000 12:59 AM
Message Board Statistics All times are GMT -4. The time now is 04:30 AM.
