Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 08-17-2005, 08:20 PM   #1
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
OMGHi2U my 91 legacy ej22t to ej25
so I am pulling the ej22t out of my legacy
to build a 2.5 from the 2.2.
I know that I will need rods & crank.
found out that the usdm 2.5 have the same crank
part number. the rods will be aftermarket..
already have pistons...forged..stock rings..
going to use wrx heads (since the price is right)
but 1 mm oversized valves, double springs,
ti retainers and my v8 type c cams.
plan to use vf36 with 1825 compressor wheel.
ecutek for em and either modded stockers (800cc)
or some other ones 750cc at least.
anything that I might have overlooked?
Old 08-20-2005, 07:51 PM   #2
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
don't forget that your crank will need to be a phase I crank... which I think all pre '01 EJ25 motors are that. You could also buy one from crawford... I know the 75mm cranks (EJ18/20/22) are only like $100, don't remember what the 79mm cranks are.
While you're boring your block out to fit those pistons, if you're going for serious - serious power, consider sleeving it as well. Maybe not worth your time, but hey, if you're hardcore or something... lol
Modded stock injectors flow low 700s to low 800s (in cc/min) depending on fuel pressure.
Do you think a rrfpr would be a good idea for your setup? (rising rate fuel pressure regulator) and you forgot to mention what fuel pump you are going with... the walbro runs a decent price and flows alot of fuel.
I would actually suggest getting the rod and crank setup from a company who does EJ22 to EJ25 stroking (or has the kit, which is basically what you need) look through crawford's website... check out others... ect.
JonofScio is offline   Reply With Quote
Old 08-21-2005, 11:52 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the swap is going into my wrx..
the entire fuel system will be upgraded.
rc has done some testing for the shop and they
have been around high 79x to low 80x cc..
after doing some homework..rod lengths are different.
have to check stroke..
Old 08-21-2005, 11:00 PM   #4
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
You need the center thrust crank. I'm positive a Phase I will fit but I'm not so sure about a USDM STi crank.
And you'll need a bigger turbo.
eastcoastbumps is offline   Reply With Quote
Old 08-30-2005, 10:25 PM   #5
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
i will be following this same path (block wise) so you are saying that I could not use a usdm Sti crank or my 01 rs 2.5l crank for this 2.2L block?
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 08-31-2005, 12:08 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
i thought all EJ25 cranks were 79mm?
Old 08-31-2005, 12:37 AM   #7
napphappy
Member#: 56170
95 Impreza L
Ugly
Your right all EJ25 do have a 79mm stroke but they are talking about where the thrust bearing is, I think.
napphappy is offline   Reply With Quote
Old 08-31-2005, 12:59 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Josh
That's what they're saying. You need to use a phase I Ej25 crank from a '96- early '99 crank with center thrust. Or get your block machined to accept an end thrust crank.
I have a '98 Ej25 crank available is anyone wants it. $100. And this crank has history. It is the original factory crank from Xephyr's '98 2.5RS from before it was a high psi high horsepower boosted monster. There have been like 10 engines in his car since then. But you could drive around saying," I've got Xephyr's original crank"
91 legacy ej22t -97 OBS 04trailsti Subaru Conversions 2 01-21-2010 10:11 AM
91 legacy ej22t header and downpipe fitment? WRX parts? boostedballs Pre-2002 Factory Turbo Powertrain 8 02-22-2008 10:30 PM
Parts Fitting A 91 Legacy EJ22T?? silver06wrx Pre-2002 Factory Turbo Powertrain 0 04-07-2007 10:39 AM
Problems with my 91 Legacy Dre Legacy Forum 15 04-20-2001 01:32 PM
my 91 legacy needs your help BeAn Technical Forum Archive 7 08-30-2000 09:04 PM
