Old 08-18-2005, 01:08 AM   #1
wRxbeater11
Member#: 12682
Default "Thump" and hard to get in gear ? clutch?
Like the title says, clutch is worn out could this be the reason its doing this? having a real hard time shifting in any gear. Any help would be great.
-melo
wRxbeater11 is offline   Reply With Quote
Old 08-18-2005, 02:31 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....bent shift fork....mebbe....does it shift easily with the car off???
Old 08-18-2005, 03:09 AM   #3
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
I had a similar issue with my setup. Fix was stiffer bushings to remove excessive driveline "play" which caused teh shifting to be a lot more "forced" due to pitch angles.
MK19_ is offline   Reply With Quote
Old 08-18-2005, 08:50 AM   #4
wRxbeater11
Member#: 12682
Only have this problem at high revs. other wise it shifts fine.
Old 08-19-2005, 09:49 AM   #5
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Sorry to highjack, but what is the shift fork and what purpose does it serve. My 2002 tranny locked up(can't get into ANY gear) last night on the way home from work. It got stuck once before while still in warranty but it freed itself, and the dealer couldn't reproduce the problem. Could I have the same problem.
Acostafan is offline   Reply With Quote
Old 08-19-2005, 10:01 AM   #6
cboggess
Member#: 30804
87 Yugo
Red
Are you sure it's not the rear diff clunk? Where does the noise come from? If it's from the rear during hard fast shifts at high RPMs, and sounds like a sonic boom in the trunk then that would be the rear diff clunk, and rear diff bushings can solve that. Whiteline and Kartboy have ones that go on the outriggers for the subframe, and Turn In Concepts has ones that go in the mount.
cboggess is offline   Reply With Quote
Old 08-20-2005, 12:04 AM   #7
wRxbeater11
Member#: 12682
No, its def. the transmission I know what clunk you speak of though. Just found out that the pilot bearing in my transmission was bad, pretty much gone. This could be the cause for the thump?
What JDM body kits are hard to get in the states? JKL Interior & Exterior Modification 84 08-03-2008 02:24 AM
hard to get into gears? ousd2ndbncdr Newbies & FAQs 37 05-11-2005 06:01 PM
Pulling out, loud clank, hard to put in gear... tranny?? kschmohl Mid Atlantic Impreza Club -- MAIC 11 08-15-2004 04:17 PM
Hard to get into gear uphill mike270 Transmission (AT/MT) & Driveline 6 04-10-2004 02:47 AM
hard to get in gear phatroksek Transmission (AT/MT) & Driveline 2 07-02-2002 03:02 PM
