Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-18-2005, 01:31 PM   #1
ADirtyLegacy
Member#: 77394
05 LGT
Default This was, well, interesting
so i'm driving back to NC last night and we stop off for dinner. as i'm coming up the exit ramp i press the clutch in and the little oil like came on and then went off. about 5mins later it does it again. after eating i check the oil level. pull the dipstick out, wipe it down, dip it in, pull it out.....nothing. didn't believe my eyes so i repeat the process, again, nothing. head over to Wally World be4 getting on the road again and i pick up 2 quarts b/c i just can't believe there is NO oil. i pour in a 1.5 and recheck to avoid over filling...nothing. poured in the rest of the 2nd quart and checked and FINALY got something just above 'L'.
i'm pretty good at checking for major leaks under the car, but i haven't seen any. are there any secret spots on the EJ25 that can leak 5 qts of oil?!?!?! i'm a little stumped, confused, and mistified.....
Kenda
ADirtyLegacy is offline   Reply With Quote
Old 08-18-2005, 01:40 PM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
With the price of oil these days, you got to watch out for the oil thieves.
That should be about 3 quarts low but thats still a lot. No obvious leaks eh?
ss
subysouth is offline   Reply With Quote
Old 08-18-2005, 02:36 PM   #3
ADirtyLegacy
Member#: 77394
05 LGT
ss
no puddles, no smoke, no smells. i'm gonna check it again today be4 i leave work to make sure it wasn't some type of "freak deal". also may try to newspaper trick over the wknd just to be sure if it still comes out low after i check today.
damn those oil thieves!
Kenda
Old 08-18-2005, 03:45 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Kenda: I'm holding your oil hostage. Please forward $1,000,000 to my swiss bank account. Otherwise, I will be cutting off your oil's fingers one by one and mailing them back to you, rendering it totally useless.
fibuz
fibuz is offline   Reply With Quote
Old 08-18-2005, 03:49 PM   #5
Dobes
Member#: 164
2008 Exige S240
Does your car smoke? Maybe your valve seals or rings are going south and you're burning the oil.
JD
Dobes is offline   Reply With Quote
Old 08-18-2005, 03:51 PM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
On another note, anyone ever have a oil-like substance come out of the boot/wires for the spark plugs?
Old 08-18-2005, 04:20 PM   #7
ADirtyLegacy
Member#: 77394
05 LGT
fibuz
again...damn you oil thieves!!!
JD, there is no smoke.
Kenda
Old 08-18-2005, 08:13 PM   #8
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
That might be the spark plug galley gaskets leaking.
ss
Old 08-18-2005, 08:18 PM   #9
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
ss
any more info on this? cost of fixing? difficulty? etc?
fibuz
Old 08-18-2005, 09:02 PM   #10
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
If its not leaking on the ground, and its not leaving a dense grey fog out the tail pipe, dare I ask about the condition of your coolant ?
I hate to suggest it, but a milky coloured yucky gloop substance in your coolant may be indicative of a failing or failed cylinder head gasket.
Jonathan is offline   Reply With Quote
Old 08-18-2005, 09:32 PM   #11
ADirtyLegacy
Member#: 77394
05 LGT
will look into that in the morning. all i can say is DEAR GOD PLEASE NO!!!! or maybe i'm not paranois enough to go check it out now!!
Kenda
Old 08-19-2005, 12:04 AM   #12
JjSwee
Member#: 75880
At first I was like 'Hah someone stole the oil' Then jonathan comes in and speaks horror. Changed the mood of this thread. 'This was, well, interesting' to 'Is my coolant supposed to be black?' or 'Wrx swap anyone?'
Good luck there Kenda.
JjSwee is offline   Reply With Quote
Old 08-19-2005, 12:22 AM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
fibuz
I may have spoken too soon. Its not showing any o-rings or gaskets on the blowup. I dont know how that joint is sealed(valve cover to spark plug galleys.) I was operating off exeprience with my Toyota and assuming their had to be something sealing that joint.
Here's the blowup:
ss
Old 08-19-2005, 01:42 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by ADirtyLegacy
... i just can't believe there is NO oil. i pour in a 1.5 and recheck to avoid over filling...nothing. poured in the rest of the 2nd quart and checked and FINALY got something just above 'L'.
Keep in mind the bottom of the dipstick is not the bottom of the oil pan, so you certainly weren't missing 5qts of oil (unless you habitually put way too much oil in the engine). If you're 1.5 - 2qts low the oil will be off the stick. My car uses oil purty good, never leaves any puddles/drips anywhere, I don't see any blue exhaust smoke, and my coolant's fine, but I'll use a quart probably every 1000-1500mi.
The first time I ever found it 2 quarts down was during a long cross-country drive, all highway. I guess it's easy to forget that although one may have checked the oil just a couple days ago, if one is putting 600-800mi on the car every day it adds up quick!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-19-2005, 03:19 AM   #15
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Here's the blowup:
[IG]https://www.parts.com/schematics/images/mechanical/F732058.gif[/IMG]
ss
Hrm....well, I'm still baffled. It doesn't look good though.
Old 08-19-2005, 08:51 AM   #16
ADirtyLegacy
Member#: 77394
05 LGT
Pat Olsen
ah ha! i put almost 2k miles on between friday and weds, all highway. coolant looked ok so no HG worries. i feel better now!
Kenda
Old 08-19-2005, 10:22 AM   #17
Dobes
Member#: 164
2008 Exige S240
Subysouth was on the right path. There are 3 valve cover gaskets on each head. There is the large one shown on the blown up picture (#4) but there are also two small ones that surround the spark plugs. Those can leak and leave oil in the spark plug galleys.
Concerning your missing oil, if it's not blowing smoke, dripping oil, or mixing coolant and oil, you must be burning it somewhere. When you start your car up in the morning, have someone else start it and check for a puff of smoke at startup. Maybe your valve stem seals are leaking.
JD
Old 08-19-2005, 11:03 AM   #18
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I was just going to suggest this, that the valve cover gasket(s) may be leaking... but I couldn't see it leaking down three quarts without some evidence. BTW - how many miles on your Leggy? And if it's still under the 5/60K warranty, recommend that your dealer do an oil-consumption test.
They change the oil and filter and set it to the proper levels, paint/mark all your access plugs/drains and then you drive it for 1K miles. They recheck and if it's lost 1 qt or more in that 1K miles, then they'll figure out what needs to be done from there...usually a short block replacement.
Good luck and keep us appraised.
Dale
Subietonic is offline   Reply With Quote
Old 08-19-2005, 11:47 AM   #19
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks for the info Dobes. Those blowups miss some key things sometimes.
ss
Well this was a beautiful thing to wake up to this morning - Hit & Run Niblaze General Community 46 08-21-2008 11:11 PM
thought this was kinda interesting TJ Texas Impreza Club Forum -- TXIC 74 05-30-2006 05:50 PM
Well this is an interesting image kaisersouse Off-Topic 17 11-06-2005 10:19 PM
Well, it was an interesting experiment deadbolt South East Region Forum 28 12-24-2004 09:00 PM
Thought this was kinda interesting... Maxtastic General Forum Archive 6 05-11-2000 10:27 PM
