Old 08-18-2005, 02:20 PM   #1
T_Rex
Member#: 83608
05 aspen white sti
fwd is for little girls.
Default 05 STi sway bar assistance
I've searched and found little or nothing on improving the 05 sway bars (sti). what i have learned:
you need endlinks with a rearsway (spherical bearings tend to make noise)
the stock size is 20mm so, would i need to go bigger or small than that? larger i'd assume.
and it would be beneficial is it was adjustable.
so let me hear it, maybe i didnt search hard enough, or maybe i'm asking too much. i want to tighten things up on the sti. whats a good deal? where can i find it? thanks!
T_Rex is offline   Reply With Quote
Old 08-18-2005, 03:19 PM   #2
subieworx
Member#: 47769
The info is out there just to let you know.
To start, what type of driving do you do and what are you interested in?
subieworx is offline   Reply With Quote
Old 08-18-2005, 06:20 PM   #3
T_Rex
Member#: 83608
05 aspen white sti
i drive 30-40 minutes to work and back everyday, but i enjoy a spirited run after work or before i go in, or on a night that we're out for a cruise. i'm looking to get into auto cross, solo 1 / 2 and i just want to eliminate what little body roll i get now. i have a set of pinks on the way, but what else could i get to stiffen things up a bit?
Old 08-18-2005, 06:43 PM   #4
subieworx
Member#: 47769
OK. I would recomend a 24mm front bar and 20mm adj rear. THis will kill the rest of your body roll and make the car very neutral. Whiteline is the company I would recommend, but their 24mm bar for the 05 sti is backordered till the middle of September.
Old 08-18-2005, 07:05 PM   #5
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
For that type of use you might also consider the Hotchkis/Cobb bars. If you are going solid (Whiteline), I'd suggest 22/22 adjustables.
jweiss is offline   Reply With Quote
Old 08-18-2005, 09:10 PM   #6
subieworx
Member#: 47769
I wouldn't bother going any smaller than 22mm in the front. Not large enough in my opinion especially if you plan on autoxing. Another thing to look into after installing the pinks is a performance alignment.
Old 08-19-2005, 03:04 PM   #7
supersport
Member#: 70337
2005 STi
What's that on your hood?
I have been searching for a front swaybar bigger than 22mm and am having trouble finding one. I am really interested in the Whiteline 24-26 adjustable but am doing an autocross on Sept. 10th and know the Whiteline will not be in before that time.
Should I wait, or is there something comparible out there? I also am planning on using the Perrin endlinks...opinions.
supersport is offline   Reply With Quote
Old 08-19-2005, 03:20 PM   #8
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
Hotchkis is a good option for your STi.
You don't need endlinks, especially not for the front. The STi endlinks are already very good.
05 STI Sway Bars on 02 WRX Timmay Brakes, Steering & Suspension 5 05-16-2006 11:02 AM
04 vs 05 sti sway bars xrocket21 Brakes, Steering & Suspension 4 11-18-2005 10:15 AM
05 sti sway bars front and rear AdamBlitzer Private 'For Sale' Classifieds 0 09-20-2005 02:30 PM
F.S. 05 Sti Sway bars tcam33 Private 'For Sale' Classifieds 0 08-19-2005 06:09 PM
05 STI sway bar verruckt32 Brakes, Steering & Suspension 6 05-07-2005 01:18 AM
