Old 08-18-2005, 10:00 PM   #1
Davenow
Member#: 23676
Default OK EM gurus. Riddle me this
A car.
An STI
Cruising at normal highway speeds
Light throttle, as normal cruising
17.5-1 a/f's
normal EGTS
better mpg
The million dollar question
1. Is this possible
2. What EM can do this
3. How did this person do it
Old 08-18-2005, 10:08 PM   #2
robp
Member#: 18826
2002 Impreza WRX
Black w/ Scratches
Informative link stolen from another thread.
http://www.avweb.com/news/columns/182084-1.html
My guesses are
1. Yes
2. Any tunable EM?
3. By tuning for "Economy", ie, lean to the point that power and EGT's drop, as described by the airplane guy
robp is offline   Reply With Quote
Old 08-18-2005, 10:27 PM   #3
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Could also be the A/F was way off. I've never been able to run my car any leaner than about 15:1 cruising around town, 15.3:1 or so on the highway (low LOW load). After that it just starts missing and having all sorts of issues.
You'll need a standalone to make these changes though - hydra, aem... I don' think you can do it with a reflash, I seem to remember seeing "00" for 14.7 and that you couldn't go leaner than that.
DarthChicken is offline   Reply With Quote
Old 08-18-2005, 10:41 PM   #4
robp
Member#: 18826
2002 Impreza WRX
Black w/ Scratches
I've logged AFR's of 24 when off throttle with the stock ECU, maybe you are thinking of something else?
Old 08-18-2005, 10:43 PM   #5
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
you don't tune off throttle, thats fuel cut in most ECUs, including the stock ECU.
Old 08-18-2005, 11:16 PM   #6
robp
Member#: 18826
2002 Impreza WRX
Black w/ Scratches
Ah, I think I misunderstood your original statement, I didn't realize a reflash specifies a new target A/F to the stock control.
Old 08-19-2005, 01:33 AM   #7
BobR
Member#: 2567
1. Yes
2. TEC-3
3. Tec has RPM/LOAD AFR map. You can set any target for closed loop, as
long as it's measurable - so WB. 17.5 AFR at 3000 RPM - EGT are normal, but
I wouldn't go above 3500.
BobR
BobR is offline   Reply With Quote
Old 08-19-2005, 01:50 AM   #8
hippy
Member#: 36528
2002 Impreza Wrx
You should be able to adjust part throttle a/f ratio with reflashes or standalones(access tuner, ecutek, hydra, aem, tec,...). From what i've heard, the stock ecu runs 14.7 to 1 for emissions purposes(so the cats work efficiently). If ya remove the cats, there's no real reason to run 14.7 to 1 at part throttle other then lack of a/f ratio control. 14 to 1 would create more power, and 16 to 1 would be better for fuel economy. One thing to think about in case you wanna run 19 to 1(or something really lean) is that there's a point where making the a/f ratio leaner hurts fuel economy. I've heard that 17.5 to 1 is leaner then the a/f ratio for best fuel economy, so there's really no reason to run so lean unless you want to hurt power output and hurt fuel economy.
peace
Old 08-19-2005, 02:43 AM   #9
hondaeater69
Member#: 60324
except 14:1 (or higher) doesn't make more power. sure it saves gas and burns cleanest, but it doesn't make more power than a faster burning AFR (say 12.5:1). I say if you can run it that lean go for it, if MPG's is your goal.
Old 08-19-2005, 09:22 AM   #10
TheMadScientist
Member#: 23717
2005 Big red
1) Yes
2) Utec
3) Thats for you to figure out.
TMS
hint wrxhackers
TheMadScientist is offline   Reply With Quote
Old 08-19-2005, 10:11 AM   #11
happasaiyan
Member#: 37731
with a utec, i guess if youre cruising on the highway and it requires more than 19% throttle (20% is the earliest you can enter OLF) you could just tune your 10 column for leaner than stoich AFRs. not that hard.
cant do it with a reflash eloquently...you could clamp the stock O2 sensor...or remap the OLF crossover and set it to 0% throttle, and just tune the car entirely in OLF...but you wouldnt get the benefits of automatically adjusting for fuel quality, etc...
happasaiyan is offline   Reply With Quote
Old 08-19-2005, 10:17 AM   #12
TheMadScientist
Member#: 23717
2005 Big red
Check out my thread over on hackers on how to trick the Utec to go into OLF erlier than 20%TPS.
TMS
Old 08-19-2005, 10:22 AM   #13
happasaiyan
Member#: 37731
you were averaging 10mpg??? yeah, thats bad.
nice trick- good job!
Old 08-19-2005, 10:25 AM   #14
happasaiyan
Member#: 37731
tms- are you using ECU ignition advance while cruising? what are your ignition advance values like during cruising even if you arent?
Old 08-19-2005, 10:27 AM   #15
TheMadScientist
Member#: 23717
2005 Big red
Right now I have started with the stg1 Utec base map. I changed the 10% colum to read ECU. So far no det.
Boost is set to 7psi. I am building a fuel economy map.
TMS
Old 08-19-2005, 10:30 AM   #16
happasaiyan
Member#: 37731
i was just wondering if the stock ecu was advancing ignition (maybe why your EGTs were lowered)...and curious as to what they would put them at. hopefully the knock sensor sensitivity is high enough at lower rpms...but then again, knock is so much harder to even create at lower rpms.
Old 08-19-2005, 10:43 AM   #17
TheMadScientist
Member#: 23717
2005 Big red
My knock sensitivity is turned way up from the default settings. That was the first thing I tuned on this motor. 3 weeks to tune 6 numbers. I tuned the knock sens to be right at the noise floor of the motor. I know with ECU in the load colum I am running the Utec will not pull timing, but the CEL will flash letting me know something is not right.
The ECU is running ~ the same timing. I don't have a log yet but my SM3 timing display has not changed.
TMS
Old 08-19-2005, 10:57 AM   #18
happasaiyan
Member#: 37731
cool, thanks for the info!
Old 08-19-2005, 11:06 AM   #19
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
1. yup
2. any EM that has closed loop and an reads a WIDEBAND SENSOR a narrow band won't work up there
3. dunno about it working well .. seems really lean
Old 08-19-2005, 02:54 PM   #20
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
What bugs me is that apparently there is a limitation with the stock ECU such that you can't target the fueling to go leaner than 14.7:1. Thus, StreetTUNER won't let you target leaner burns either. The cool thing is that the stock near-wideband sensor is capable of doing lean burns. You don't need a full wideband. It is accurate into the 16's.
t
WolfPlayer is offline   Reply With Quote
Old 08-19-2005, 03:28 PM   #21
hippy
Member#: 36528
2002 Impreza Wrx
The stock o2 sensor might read a/f ratios richer and leaner then 14.7 to 1, but who knows how accurate it is when it's reading richer and leaner a/f ratios? From what I've heard, it was really only made to target 14.7 to 1. I know of a few people who checked the a/f ratio on the stock o2 sensor verse a wbo2 sensor while going a little richer then 13 to 1, and they weren't so close.......... I used to tell people that they could adjust the fueling of their lower load columns without a wbo2 since the stock o2 sensor could read downto 12.5 to 1(or whatever), but now I'm kinda leaning away from using the stock o2 sensor for any tuning purposes.
peace
Old 08-19-2005, 09:47 PM   #22
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
I noticed this too when I was writing and testing my logging software. I had the program keeping the stock O2 readings and adding the WB data to the logs too, so you could compare them. Boy were they WAY off from each other, and my sensors weren't that far apart from each other, so I don't think much of the deviation is from sensor placement.
I would venture to say that the further from 14.7 the stock O2 sensor gets, it logarithmically gets more and more INaccurate. From what I've seen from data logs with both stock and wideband reading taken simultaneously, I wouldn't trust the stocker with anything richer than 13.5, and even then it's not completely accurate.
-jason
jmussetter is offline   Reply With Quote
OK IT peeps; Riddle me this.... BGPunk2001 Off-Topic 7 09-18-2007 07:47 PM
Ok computer/networking peeps- riddle me this Slvrblt Off-Topic 14 09-09-2006 12:52 PM
SOA tech gurus - riddle me this blinking cruise light with no MIL or DTC? turboICE Service & Maintenance 2 01-20-2005 09:25 PM
Ok, drag racers, riddle me this Jack New England Impreza Club Forum -- NESIC 11 05-15-2004 12:09 PM
Riddle me this and riddle me that Imprezer Forester Forum 7 02-05-2001 01:10 PM
