Old 08-18-2005, 10:45 PM   #1
2Stroke
Member#: 36712
2003 WRX Wagon
Default Toyo Proxes 4 wear report
With 24,000 miles on my 215/45-17 Proxes 4's, tread depth measures .115" deep over the wear bars, and .146" to the bottom of the tread grooves. Original depth was stated as .312".
Measurements taken with a Starrett depth micrometer near center of tread.
2Stroke is offline   Reply With Quote
Old 08-18-2005, 11:28 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....mmm....about 2/3's gone.....
Old 08-19-2005, 08:59 AM   #3
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
2Stroke, would you mind briefly describing your driving style? I need new tires soon and I'm higly the Proxes 4's are at the top of my list as 3 season tires. I just like to know what to expect. Thanks!
thorongil is offline   Reply With Quote
Old 08-19-2005, 11:36 AM   #4
Jared703
Member#: 17030
They are good tires, i've been on mine for about a year now. I haven't measured the tread left but there is a lot. I'm guessing atleast 2/3's if not more. It is a great all season tire, very quiet, good wet and dry grip, and affordable. I just picked up a set of summer wheels+tires so the proxies 4 on stocker are what held me over. The proxies 4's aren't a summer tire, and they don't grip like one. They however are pretty good in the dry, miles above the oem re-92's. Also, they performed almost as good as the re-92's in the snow also. Hope this helps
Jared703 is offline   Reply With Quote
Old 08-19-2005, 11:52 AM   #5
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
Thanks. This agrees with pretty much everything else I've read about the Proxes 4's. I don't expect the ultimate grip of a summer tire from them, but want something better than RE92s in the dry and wet (which most any tire is, I hear). The affordability of the Proxes 4's is a huge plus, too. I've thought about a summer tire, but I need a tire that won't be downright dangerous if some snow sneeks up beofre I can switch to the winter tires (which it has been known to do in Cleveland). It's going to be an expensive fall: I have to buy all season and winter tire sets!
Old 08-19-2005, 03:35 PM   #6
2Stroke
Member#: 36712
2003 WRX Wagon
The first 12,000 miles on the Proxes 4's was lots of twisty roads (actually the same 30 or so miles of twisty road over and over), a couple canyon runs, 50 or so flat-out runs up a series of switchbacks on PV Drive East with a GTech Competition meter recording the proceedings, and 30% trips to the store with the occasional 50 mile freeway run thrown in.
The last 12,000 miles has been more sedate. I've moved to an area where the roads are straighter and speeds are higher. I still slide the car frequently getting on and off the freeway, but most of the time now the tires aren't working that hard. HTH.
Old 08-19-2005, 03:49 PM   #7
Rail
Member#: 38287
2005 Honda S2000
NFR
I'm sitting just above the wear bars on mine at 19,000 miles. I had an alignment issue for about 500 miles before I noticed it, though, so they would probably last quite a bit longer if I hadn't had that problem.
Rail is offline   Reply With Quote
Tread wear on Toyo Proxes 4 Ernest Tire & Wheel 5 12-08-2007 06:18 PM
FS MA: Toyo Proxes 4 205/55-16 Tires with 4/32nds left - $30 for all 4 MYfirst00 Wheels/Tires 8 08-30-2007 04:16 PM
FS MA: Toyo Proxes 4 205/55-16 Tires with 4/32nds - $30 for all 4 MYfirst00 NESIC Private Classifieds 4 08-28-2007 12:21 PM
Toyo Toyo PROXES 4 245/45ZR17 99W tire fit ok on 05 STI stock BBS with pink springs? miwxq Tire & Wheel 0 08-28-2006 03:45 AM
Volk GT-C Set of 4 W/ Toyo Proxes 4 05WRX Private 'For Sale' Classifieds 3 11-17-2004 07:22 AM
