Old 08-18-2005, 11:10 PM   #1
blackmedal
Member#: 89475
1999 Legacy GT
Quick Silver
Default Car won't start - help
Hey
I have a 1999 Subaru Legacy GT - 5/spd manual
I came back to home from work and ate dinner at home. I then tried to start the car to go to the store about 20 mins later but the car won't start. Nothing happens, it doesn't even turn over. The radio and cd player work perfectly. Interior lights also function. I have had no problems starting the car prior to this incident. Any help would be greatly appreciated.
Daniel
blackmedal is offline   Reply With Quote
Old 08-18-2005, 11:19 PM   #2
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Check for corrosion on your battery terminals. I had this happen last winter during some very damp weather, and my radio and interior lights worked fine even though the starter wouldn't turn. I cleaned the battery posts, and haven't had a problem since.
Turning the starter in draws a ton of amperage compared to your radio. If there is corrosion on your battery posts, enough current may be pass to run your radio, but not enough current to turn the starter.
BJamerican is offline   Reply With Quote
Old 08-19-2005, 12:04 AM   #3
blackmedal
Member#: 89475
1999 Legacy GT
Quick Silver
The battery terminals weren't very gunky but I cleaned them off anyways. Still no luck. Thanks for the suggestion though.
Anyone else know what could be wrong?
Old 08-19-2005, 01:49 AM   #4
TrickNipple
moon moon
Member#: 86213
Is your car making any noise when you try to start it? Also try to start the car with everything off. The lights and stereo might be pulling just enough power off the battery so that it wont start.
TrickNipple is offline   Reply With Quote
Old 08-19-2005, 02:42 AM   #5
blackmedal
Member#: 89475
1999 Legacy GT
Quick Silver
The car kind of makes a whine noise so I am assuming I need to recharge the battery. It's an Optima Redtop.
Any other suggestions?
Old 08-19-2005, 03:22 AM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I'd try to jump it to see what happens.
Any type of security system? I'd check that out next.
Then on to alternator/starter.
fibuz
fibuz is offline   Reply With Quote
Old 08-19-2005, 04:10 AM   #7
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I beleive you are suppost to press down on the Clutch pedal in order to start these cars. Perhaps the switch on your clutch pedal is not operating correctly ?
Maybe someone installed a "Kill switch" on your car somewhere that you might have accidently bumped into ?
Also if you have one of those starter "Bump switches", try running the switch from your Positive (+) battary terminal to your solinoid switch terminal on your starter motor, just to verify that there is enough power in the battary to crank the starter.
Jonathan is offline   Reply With Quote
Old 08-19-2005, 08:52 AM   #8
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
When you say you get a whine noise, is it an electrical motor whine? Is it only when you turn the key to "start" position or is it the fan motor? If it is only when you turn to the start position you probably need a starter. The starter motor is turning but the solinoid is not engaging to pull the gear into the flywheel. I do not know where the starter is on your car but you can get a hammer and hit it with a heavy tap a few times, tap not smack. If you can't reach it with the hammer find a pipe or something metal and place it on the starter then hit it with the hammer. Sometimes the solinoid will freeze-up and a bit of shock will free it. This is really just to get you going. If it works you know you need a starter.
Or is it just clicking? If you are just getting a clicking/thunk sound then it is probably just the battery.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 08-19-2005, 09:46 AM   #9
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
Try jumping it first to see if it is a battery issue, they work your way down the line. I have also seen corrosion creep up the positive cable inside of the insulation but not have much on the terminal it self.
But sounds to me like a battery or starter issue.
bhall is offline   Reply With Quote
Old 08-19-2005, 02:23 PM   #10
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Also check the posi cable at the starter, as well as the starter ground. If you can, just take the battery to Les Schwab's and have them test it. You'll know if it's bad right away. If it's not the battery, check connections, then it's the starter or solenoid, like everyone else said.
fastenova is offline   Reply With Quote
Old 08-19-2005, 02:41 PM   #11
Sleeper20t
Member#: 62824
'06 STI
I had this same problem today, although i have had problems with it over the past few weeks. I saw a bunch of corrosion on the positive terminal, took some coke to it and it worked fine for about a week until today. Everything looks clean to me, but i was told to clean it off more. The battery tests normal, i have no idea what the problem is, but its pissing me off... If you figure out what is wrong, let me know and ill do the same.
Sleeper20t is offline   Reply With Quote
Old 08-19-2005, 03:34 PM   #12
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
It sounds a lot like stuck starter solenoid contacts (which has plagued me multiple times on my '91 Turbo). If this is the problem, the temporary "workaround" is to whack the starter with something while the key is turned to the "Start" position. This will usually jar the solenoid contacts enough to come unstuck and the starter will fire. The easiest fix is just to replace the whole starter. Some of the folks on Legacy Central have found suitable replacement solenoid contacts, which makes fixing this cheaper, but it's more work as you have to disassemble the starter to fix it this way.
FWIW, the starter I used to replace mine was a reman from Advance and it died the same way about 6-months later (I guess I shouldn't have been surprised since I noticed that the brand I put in was exactly the same as the one that was coming out). I've heard that the starters you get from the Subaru dealers tend to last longer, though.
Shane
Warp3 is offline   Reply With Quote
Old 08-19-2005, 04:44 PM   #13
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Les Schwab...... Oh my Lord does that bring back memories.
I spent some time in The Dallas. Les Schwabs are awesome, talk about service.
Sorry for the hyjack.
Peace,
Greg
Old 09-21-2005, 08:50 PM   #14
Sleeper20t
Member#: 62824
'06 STI
Bump for a problem...
I have been having weird starting problems, usually when its cold it wont do anything, and ill have to turn the key a bunch of times. eventually it will slowly crank, stop, crank again, and after a few tries will start up. Well, the other day when it wouldnt start at all i replaced the battery, everything worked fine for about 2 days. I jsut went outside to start it and it wouldnt do anything. Kept at it, and it eventually started, BUT this time, the starter would not turn off. I heard this whinning noise and knew the starter was still turning, so i went to shut the car off. Motor shut down, but the starter kept on turning the motor over, WITHOUT the key in ON position, AND with the clutch pedal up!! Eventually after a couple of tries shutting the motor down, the starter finally shut down too. It was really scary that my car was just sitting there trying to start on its own. Has anyone ever heard of this type of problem? Im afraid to drive the car now, as i do not want this to happen again and grind off all my ring gear teeth/starter teeth...
Thanks in advance
Old 09-21-2005, 09:08 PM   #15
Jonathan
Member#: 4021
1999 Legacy GT Ltd
I just went outside to start it and it wouldnt do anything. Kept at it, and it eventually started, BUT this time, the starter would not turn off. I heard this whinning noise and knew the starter was still turning, so i went to shut the car off. Motor shut down, but the starter kept on turning the motor over, WITHOUT the key in ON position, AND with the clutch pedal up!!
I have not experianced this particular problem myself, although it sounds very much like a stuck Solinoid and/or starter. I would go with either a NEW or REBUILT Starter Motor (including solinoid).
Old 09-21-2005, 10:23 PM   #16
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Check this in sequence (after making sure the battery is charged):
1) Battery connections (clean, free of oil, grease and corrosion)
2) Battery cables (check UNDER the plastic cable covers/sleeves for corrosion - if present, replace the cable)
3) Ground connections (pay particular attention to the large ground cable and strap(s)
4) Starter connections (check for corrosion at the connection and under the plastic cable covers near the starter but moving backwards toward the battery - if present, replace the cable)
5) Starter connection lugs (can be checked on the car but easier with the starter out - undo the connectors and check for arcing, corrosion, or other signs of dysfunction. Replace if any of the above are present) There is a thread on the board about starter lugs, spades or connectors so a search should turn this up... it's a failure item.
6) Battery/Starter/Alternator check (jump start your car and take it to an electrical shop and have them do a quick load diagnostic on both your starter and your alternator) Voltage regulator is internal to the alternator so if that's going bad, everything else will stop working correctly.
Oh, forgot to ask if this is a an auto or a manual. The clutch lockout was already mentioned, but don't forget to cycle your shifter back and forth through PRN, NRP to make sure the auto trans lockout isn't causing this problem. I've actually had this before.
Good luck and keep us posted on what you find out.
Subietonic is offline   Reply With Quote
Old 09-22-2005, 02:43 AM   #17
Bakergtt
Member#: 59207
'05 X was 98 LGTT
its the starter. mine does the same thing. i have replaced the leads on the inside of the starter and it still does it. Im about to start looking for a new starter.
Bakergtt is offline   Reply With Quote
Old 09-22-2005, 08:49 PM   #18
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Definately most likley the starter or solenoid. First, do as others say and make sure the battery is nice and charged/clean terminals. A common problem with subies are the copper contacts inside the starter solenoid. Cheap thing to fix, only a few $$. The next thing to do is crawl under the car and check the starter mounting bolts to make sure they are nice and tight. If these are loose, it may not start. While you're under there, check out the wires to see if they are in ok shape. Replace as necessary. You can also use a screwdriver on the solenoid and bridge the battery and starter terminals. If it turns over, the starter is fine and the solenoid is most likley the problem. You can tap the starter solenoid with a small hammer a few times to see if it wakes it up. A really good (but lazy solution) idea is to find the ignition switch wire, tap it, and run the new wire up to the battery. Make sure the car is out of gear, and touch the end of the wire to the positive battery cable with the key in the on position. If this works, then the solenoid is most likley the culprit.
I have spent the past 6 or so months of this year tracing down various starting issues with a 1989 Mitsubishi Montero, and these are all things I tried. I ended up replacing about 8 inches of ignigion switch wire, put on new connections at the solenoid, and its been working flawlessly since.
kevinsUBARU is offline   Reply With Quote
Old 09-22-2005, 08:52 PM   #19
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I know its not a good practice to do often, but you could try roll starting it, if its a must to get somewhere. Since you have a 5MT, you can do this...
Wiscon_Mark is offline   Reply With Quote
Old 11-11-2005, 01:58 PM   #20
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
subscribe
Old 11-11-2005, 02:46 PM   #21
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
Originally Posted by hybrid gti 2
subscribe
Hasn't this been dead for over a month?
TRH_legacy2k is offline   Reply With Quote
car won't start Help!!! White06STI Newbies & FAQs 3 02-17-2006 05:16 PM
Car won't start. Help flp_sde Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-26-2004 03:31 AM
Rat chewed on a wire, now car won't start ! Help ! 99LegacyGT Legacy Forum 3 07-14-2003 04:16 PM
my car won't start help!!!! ChasuRamen Normally Aspirated Powertrain 4 01-12-2003 11:08 PM
car won't start- help ASAP cindergarden Normally Aspirated Powertrain 8 08-19-2002 08:16 AM
